Question about Sears Craftsman 7-1/4 in. Circular Saw with LaserTrac and 5 Bonus Blades
Blade needs changing. nut is hard to get at
I have a seard compound miter saw serial #137 245100 blade makes noise when turned on. i think the blade is bent. i need to changing the blade. Then nut is hard to get at and hard to turn. I tried getting the guard off but am afraid i will break the plastic. any suggesions on this saw.
  • 8,404 Answers
With the saw unplugged, retract the guard with the base plate extended so there is minimum teeth showing below. Place the blade of your saw on your wood top workbench. Press it down. Using the wrench that came with the saw or other appropriate size box or open end wrench or socket, turn the nut backward (this is a left hand thread not standard right hand thread). It will be tight.
Alternatively, there may be a shaft lock that you can press to lock the shaft to facilitate unbolting the blade.
Alternatively, there mau be a small hole in the blade. Insert a phillips screw driver in the hole to facilitate blade removal.
Key is knowing the thread is backward to what you expect. The reason for this is to cayse the nut to tighten as you turn on the saw, not loosen.
When you put on the new blade, make sure the nut is properly secured.
I hope this is clear for you.
If you have need for more information, please post a comment to this quesiton
thanks for your interest in FixYa.com
Please vote
thanks
a
Posted on Dec 12, 2009
Kobalt SM2505LW 10 sliding compound miter saw makes grinding noise and slow saw stop
a bearing ,brushes or brake broke more likely the brake mechanism if blade coasts
Jul 07, 2016 | Saws
Northern Tool 10" compound miter saw. How do I change the blade?
remove the power cord from the socket in the wall first
if there is a small hole in the blade , place a phillips screw driver in that hole and turn until the driver is locked against the depth guard
use the correct size spanner /socket and undo the spindle nut holding the blade on
if there is no hole ,then place the screw driver in the teeth of the blade to lock it
the motor will spin so that the teeth cut against the direction of cut ( up into the guard or up through the depth guard ( blades normally have a arrow for rotation direction)
tighten the spindle nut and if no hole in the blade use a hammer and hit the spanner with a hard rap
Sep 30, 2015 | Saws
Bosch gsm 10 compound mitre saw. which way does the screw turn to undo blade
On the Bosch compound sliding miter saw, turn the blade nut clockwise to remove it.
I’m happy to assist further over the phone at https://www.6ya.com/expert/bill_f6ca18ca1db028ed
Jul 26, 2010 | Bosch 12" Dual - Bevel Compound Miter Saw...
HOW TO CHANGE BLADE
Do you have the wrench that came with the saw? It should be slid in the back somewhere, there is a lock on the top that you hold the motor locked with, unplug the saw, turn the nut on the blade, start the saw down and grab the guard with your thumb to hold it and then lift it up all the way to slip the blade out. You should be all set.
Jun 20, 2010 | Makita 10" Compound Miter Saw LS1040
I've been using dewalt miter saw dw715 for several years and it's been working great. I just moved and today I used the saw in the new place, on an uneven concrete tiled ground. After several cuts, I...
This is common IF the blade clamping nut becomes loose... the blade will free wheel on the arbor after the motor stops. It can tear up the arbor so investigate this possibility immediately.
Feb 19, 2010 | Dewalt DW715 Heavy Duty 12" Single -...
How do i change the blade on my delta 10" mitre saw
Exploded diagram for your SM100M miter saw is here.
User manual is here.
Page 20 covers blade change operation.
Make sure you unplug your saw! You need to remove a screw from the cover and rotate the cover to the rear. Use a hex wrench in the motor shaft to keep the saw blade from turning, and loosen the arbor nut with a 1/2" wrench. The arbor is reverse threaded, so you'll turn it clockwise to loosen, then counterclockwise to tighten it up after you have swapped the blade.
Rotate the cover back after that's done, and replace the screw.
If this was useful, please vote. Thanks.
Nov 23, 2009 | Delta SM100M 13 Amp 10" Compound Miter Saw
Changing the blade
there is a nut holding the blade in the center , it is left handle thread , there should be a locking mechanism to hold the blade while you unscrew the nut
Oct 31, 2009 | Makita 10" Compound Miter Saw LS1040
Change blade miter saw
Un-plug the saw. Remove the screws holding the side saw guard in place. Look at the center of the saw blade for the nut holding it in place. Take a socket wrench that fits the nut and loosen it. You'll need to take a scrap piece of wood 2x4, and jamb the teeth of the blade into it while loosening the nut. The nut will come off first and then a washer/spacer.
Reverse the order for installing the new blade. Make sure you use the proper size diameter blade (10 inch) and mounting hole in the replacement blade. Also, use the provided washer/spacers that were on the original blade and secure the nut. Spin by hand to see if everything clears. Mount the protective guard back on. Plug in the saw and test cut .
Good luck. If you are still unsure - ask a handy neighbor to help. It takes about 5 minutes to complete this task.
Oct 05, 2009 | Delta Cycle Rothko Rolling Bicycle Stand
Solution for "changing blades on a milwaukee miter saw
Have you removed the old blade yet?
The blade lock my be broken off -- it should be a button on top of the motor.
This saw has left hand threads -- turn clockwise to loosen the bolt/nut.
If you can't find the blade lock, lower the saw onto a piece of wood llike a 2x4 to keep the blade from turning.
May 02, 2009 | Milwaukee Tool 10" Magnum Compound Miter...
How do I remove the guard?
Lift the guard up and you will see a nut holding the blade. You should not have to remove guard to change blade. Make sure unit is unplugged before working on it.
Dec 24, 2008 | Ryobi ZRTS1342L Factory-Reconditioned 14...
Sears Craftsman 7-1/4 in. Circular Saw with LaserTrac and 5 Bonus Blades Logo
143 people viewed this question
Top Sears Saws Experts
Mike Squire
john h
Mike
Are you a Sears Saw Expert? Answer questions, earn points and help others
