Question about Singer 7462 Mechanical Sewing Machine
Machine beeps and won't sew when buttonhole foot is attached - I have followed directions very carefully
I just figured out how to use the buttonhole feature today. Make sure where you insert the button is towards the back of the machine. Pull down the button hole lever and make sure it's between to two plastic notches. The buttonhole lever will actually be pressed against notch B as described in the instructions. Insert your material and let the bottonhole foot down. You will to play with the stitch width and length to get the right size opening. I hope this helps!
Posted on Jan 12, 2010
2 Suggested Answers
SOURCE: machine beeps three times when buttonhole foot is
does your manual mention anything about a buttonhole lever that must be pulled down each time you make a buttonhole & then pushed back up afterwards
Posted on Aug 06, 2011
Hi can’t make the button hole big enough using the special one step Pfaff foot . Won’t go bigger than 8mm
It could be that 8mm is the limit for the buttonhole foot. You can try making buttonholes manually with the sewing machine. Not really difficult. Just need to be careful marking the buttonhole and stitching. Recommend practicing on scrap fabric before trying it on the project.
How to Make Buttonhole on Your Sewing Machine Sew4Home (several methods)
Creating Buttonhole Using Sewing Machine
how to sew buttonhole without buttonhole foot Google Search
Jan 26, 2018 | Sewing Machines
Singer confience stylist beeps four time and won't let me sew
The beeps usually indicates that your machine is not ready to sew which probably means a function has been left in the activated mode, ie bobbin winder, buttonhole function, etc. . Here are some ideas:
Why does the electronic beeper beep and the sewing machine won sew Sewing...
20 Most Recent Singer 7467S Confidence Stylist Electric Sewing Machine...
Mar 05, 2018 | Singer 7467S Confidence Stylist Electric...
Machine beeps three times when buttonhole foot is on and pedal depressed. will not sew buttonhole. i have followed the directions in the manual for attaching presser foot and inserting button
Aug 06, 2011 | Singer Confidence 7467 Mechanical Sewing...
I have temporarily misplaced the instruction manual to my White 979 sewing machine. I need to put this shirt in todays mail and I have forgotten the direction to make a buttonhole. I s there a place I...
Automatic BUTTONHOLE making with 979:
  1. Carefully mark the position of buttonhole on your garment.
  2. Slide the button carrier and insert the button.
  3. Attach the buttonhole foot.
  4. Place the garment under the foot so that the needle pierces the fabric at the beginning of buttonhole.
  5. Lower the buttonhole lever and the presser foot lever.
  6. Push the buttonhole lever away from you.
  7. Start machine to complete entire buttonhole.
NOTE:
  • While making buttonholes, maintain an even sewing speed for uniform buttonholes.
  • When buttonholes are completed, be sure to push up the buttonhole lever as gar as it can go.
Feb 11, 2011 | White Sewing 979
I am trying to make a buttonhole using the buttonhole foot and everytime i go to sew the machine beeps and will not let me sew?
if you have a automatic buttonhole , then you should have a buttonhole lever that you have to pull down, before you start to do the buttonhole,, my machine will not let me do a buttonhole unless I pull down the buttonhole lever
Nov 16, 2010 | Singer 7436 - INGENUITY
I have a Singer model 9910 and am not able to make a buttonhole on the setting for #61. The buttonhole seems to be inserted properly and the foot is lowered but the machine just beeps and will not sew.
Re your buttonhole foot - please note the following:
- This foot comes with a metal underplate.
- Place the fabric between the foot and the underplate.
- I am assuming that you have the buttonhole lever pulled down.
-Note: The silver coloured buttonhole lever is directly behind the needle threader. Pull it all the way down.
-When u have all the above in place, start the buttonhole. When it finishes the first side, gently push the foot back, so it reverses. I know this sounds strange, but if you have slightly bent the underplate you will need to do this.
- The directions are in the manual on page 60.
May 15, 2010 | Singer Quantum 9910 Computerized Sewing...
I get a beeping sound when I try to make button holes
Ensure that your buttonhole foot is attached, and that your buttonhole guide is slid all the way down(It is a small, flat-tabbed bar just behind your needle threader.)
Ensure that once the bar is down, that it is able to sit between the two buttonhole foot guide tabs, and is not pushed by either of the tabs in either direction yet.(The pushing of the buttonhole guide bar is what causes the machine to stop, sew sideways, and start going the other way)
Nov 30, 2009 | Singer 7444 Mechanical Sewing Machine
How do i use the automatic buttonhole on kenmore 19233??
Your machine should have a special buttonhole foot which has a place to insert a button, You will probably have to pull on opposite ends of the foot to open it. Place the button in the foot and then squeeze it together to make the button secure. Attach the foot to the machine. It should snap on.
looking at the left side of the machine you will see your needle bar at the front and the presser foot bar at the back. You should also see another lever which needs to be pulled down so that it rests in the buttonhole foot.Select buttonhole on your machine and it should sew. The button determines how long the buttonhole is.
Sewman7
Jun 04, 2008 | Kenmore 11206 / 11306 / 11506 / 11606
Buttonhole instructions needed for Singer 7422 Advance
These are the exact instructions from the Manual. 1. Select one of buttonhole patterns.
2. Replace the presser foot with the buttonhole foot. (Install presser foot with little red mark towards the front)
3. Insert the button into the buttonhole foot. (the part located in the back crescent shaped)
4. Lower the buttonhole lever (to the left of the needle) so that it drops down vertically between the stoppers A and B.
5. Carefully mark the position of buttonhole on your garment.
6. Place the fabric under the foot. Pull out the bobbin thread underneath the fabric to a length of about 4 inches to the rear.
7. Align the buttonhole mark on the fabric with the mark on the buttonhole foot, and then lower the buttonhole foot.
8. While holding the top thread, start the machine.
*Sewing will be completed automatically.
9. When sewing is finished, use a buttonhole opener to open up the frabric in the center of the buttonhole. Be careful not to cut anyt of the seam thread.
I hope this helps.
Mar 28, 2008 | Singer 7422
Singer 7462 Mechanical Sewing Machine Logo
226 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
