Question about MedWeigh Health & Beauty
I have a MS-2500 hand rail scale which is stuck in an endless loop of set up functions. It is about two years old and has performed well until recently. I have tried everything I can think of as described in the operators manual with out any luck. I badly need this scale to monitor my wife's weight on a daily basis. She has heart failure and other chronically serious problems. Can you help me troubleshoot the software. If not can I replace the electronic module with out purchasing a whole new scale? Allan Robb allanrobb@cox.net
  • 10,865 Answers
Hello. I have had two occassions to service these scales. What I learned is that your only option is to replace the electronic module. That will be much less expensive than replacing the entire unit. here are the contact numbers for the company: For Phone Orders, call toll-free 888-337-4684 (Monday - Friday 9 am - 6 pm E.S.T)
All other inquiries, please phone 718-339-6212
FAX 718-336-5570
Regards to you and your wife. , Joe
Posted on Dec 12, 2009
Amana washer quit agitating and also drains and fills endlessly. Only 2 years old. What part is failing?
First check the drain hose isn't too far down the drain pipe it should only be about 6 inches down too much and it will siphon out
Jun 16, 2015 | Amana Washing Machines
Calls dont go to voicemail
The "Recall" Destination of that phone needs to be voicemail. Usually 2500. You have to go inti database programming to make that happen.
Sep 08, 2014 | Inter-Tel Lands Phones
Nevers stops...
check your pump is not worn (how old is it)
or
check your brushes
Jan 12, 2014 | Siemens Washing Machines
My Takagi TK3 isn't heating as it should. Had a tech out and he adjusted the dip switches to 140 degrees, which worked for a while but now it barely heats to 100 degrees. Gas flow rate appears to be...
Is tankless computer older than 5 years? Imagine how well a 5-year old laptop computer works.
Setting temperature to 140 degrees might be the basic problem:
Read following resource:
http://waterheatertimer.org/Troubleshoot-Rheem-Tankless-water-heater.html#temperature
I doubt this Takagi computer unit was maintained as shown in product manual, and that heat exchanger was not delimed each year as shown in product manual. So the heat exchanger is probably heavily coated with un-removeable scale... since yearly deliming will not fully remove scale on tankless units, the tankless computer is designed to sprial downward in efficiency despite glossy brochures that promise endless and effortless hot water for 20 years ... as if any computer will last 20 years:
http://waterheatertimer.org/Troubleshoot-Rheem-Tankless-water-heater.html#de-lime
Since you are not getting error code, the problem might be crossover, or some other plumbing problem:
http://waterheatertimer.org/Troubleshoot-Rheem-Tankless-water-heater.html#no-error
http://waterheatertimer.org/Crossover.html
I always recommend replacing tankless computer with tank-type water heater for $385 for same-day do-it-yourself solution and to save the endless expenses that arise with computer-driven water heaters.
http://waterheatertimer.org/How-to-install-gas-water-heater.html
Gene
h
Aug 30, 2013 | Takagi T K3 OS P OnDemand WaterHeat
Locked account
You could try to reset the password, this is also able to activate the normally deactivated Administrator default account. Note that any encrypted files will be unavailable until the original password is restored.
A bootable utility is available:
https://pogostick.net/~pnh/ntpasswd/
More information on that site.
Oct 31, 2017 | HP Compaq nc6400 Notebook
Flash is turned off. How to turn it back on
Set the record/review selector to one of the record modes and the exposure mode dial to the desired function.
By repeatedly pressing the flash mode button you can set the various function types. They scroll through in an endless loop.
The corresponding symbols appear in the data field and the monitor.
The above is from the "Taking photographs with the built-in flash unit" section of the manual (page 131 in my copy). If you need a manual, you can download one here.
Oct 06, 2011 | Leica Digilux 1 Digital Camera
Pioneer turntable PL443 hangs in endless start/stop loop
there are 2 little sheet metal parts mounted on the big center spur wheel. The upper sheet metal part is moved by the lower one. To do this, there has to be some friction between both sheet metal parts, but not to o much.
Dec 30, 2009 | Pioneer Audio Players & Recorders
Pls help me for power on fail
If your Treo loops or freezes during a soft reset, a system reset may help. Performing a system reset allows you to get out of an endless loop in order to uninstall a third-party application causing the looping: 1. Press the Battery Door Release button and slide the battery door downward to remove it from your Treo. 2. While pressing and holding Up , use the tip of the stylus to gently press the reset button on the back of your Treo. 3. When the Palm Powered logo appears, release Up . 4. Delete the third-party application that you suspect is causing the problem. 5. Perform a soft reset. The wireless features of your phone are not available until you complete this step. Good luck!
Nov 23, 2005 | Palm Treo 650 Handheld
Health & Beauty Logo
59 people viewed this question
Top MedWeigh Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a MedWeigh Health and Beauty Expert? Answer questions, earn points and help others
