Question about PfaFF Sewing Machines
The needle wont center. The whole arm wont lock into a center position for sewing, and sews on the lef when the dial says it should be in the center.
  • 96 Answers
You will need a repair for that it sounds like an internal issue with the dial setting
Posted on Dec 13, 2009
SOURCE:
Baby Lock Esante needle wont go to the center position, only the left of center. sews fine but wont sew in the center
Go into utilities and turn width control off. Then select a stitch that has the needle centered.
Mar 27, 2017 | Baby Lock Sewing Machines
Needle locked in right position
Remove the needle holder using a tool suitable for it and remove the needle and fix it again in the correct position and continue the stitching in zig zag .
Thank You
Sep 13, 2008 | Husqvarna Viking 1
I cant get my needle position to move to the left or the right
The long arm is attached to the needle arm.
1. Move the needle arm right and left with your finger. Is there any resistance? There should be. If not, a spring that is supposed to be attached to the long gray rod has came loose.
2. The spring will be attached so it pulls towards the round cogs (bumpy things).
3. Mechanical sewing machines are very similar. There is a possibility that your adjustment lever has screws came loose.
4. By moving the needle arm back and forth you can monitor what is going on to get a clue of what may be wrong.
Mar 06, 2015 | Sewing Machines
Sewing machine sews good in center needle position, why does it not stitch,when moving needle position to right f left?
Hopefully it is a bent needle. Replace the needle first. If that doesn't work you will need an adjustment made on the hook. That is when you will need to take your machine to the repairman.
Oct 29, 2014 | Sewing Machines
The 19, 20 and 21 dials on my Bernina 831 sewing machine are stuck. What should i do?
Is your button hole dial activated? Sounds like a dumb question but if the indicator on the buttonhole dial is not at the top it will lock the other dials. The only other thing is that if above is correct, you will have to find a dealer who can carefully oil and get the dials to rotate again. It is v tedious and one has to often disassemble the stitch width, needle position dials and carefully force the buttonhole dial while lubricating the mechanism to get it all working again
Aug 01, 2014 | Bernina Sewing Machines
Needle position dial not working
it's possible that theirs something wrong with the needle position
dial & it needs to be checked.
May 01, 2012 | Sewing Machines
Making a buttonhole on a Necchi 3204 sewing machine
Here's what the manual says:
Before sewing, fit the button-hold foot to the machine (long white plastic thing with red, ruler like markings).
Select the pattern selector dial that is solid green on the left hand side. Set the dial to "1" position. Sew the left side and raise the needle.
Select the pattern selector dial that is solid green on the top and bottom. Set the dial to "2" position. Sew 5-6 stitches and raise the needle.
Select the pattern selector dial that is solid green on the right hand side. Set the dial to "3" position. Sew the right side. Raise the needle.
Select the pattern selector dial that is solid green on the top and bottom. Set the dial to "4" position. Sew 5-6 stitches and raise the needle.
Hope that helps...
Nov 26, 2008 | Necchi 3537 Mechanical Sewing Machine
JANOME RX18S
If it was sewing correctly BEFORE the needle break...why did the needle break in the first place?...and what fixes did you make?
If it sewed properly...what changed?
Cut your upper thread close to the spool...make sure the presser foot is raised and pull the cut off thread section through/out of the machine from the needle area (sewing direction...do not pull the thread backwards!)
Clean out the bobbin area...remove any traces of lint or pieces of thread...look for any broken off needle pieces... brush the bobbin area out....then add a drop of sewing machine oil (but only if your manual says to oil that area).
Remove the needle plate to expose the feed dogs...brush/clean out that area too and add a drop of sewing machine oil...then secure the needle plate back on.
Replace the needle...do it again...yup...some needles arrive bad from the factory. Make sure the needle is inserted and positioned properly. Then thread the machine WITH the presser foot in raised position. (The thread needs to get seated into the upper tensions.)
..with the.presser foot down...thread the new needle.
Oh...and use the correct needle for the thread. (a universal 80/12 is standard).
Thread can cause issues too. Try a different bobbin, or maybe a different spool of thread to see if that makes a difference.
Mar 25, 2017 | Janome Memory Craft 9500 Computerized...
Sewing Machines Logo
54 people viewed this question
Top PfaFF Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
MissFixIt828
Level 1 Expert
Are you a PfaFF Sewing Machine Expert? Answer questions, earn points and help others
