Question about Microsoft Windows XP Professional
Please, i need help. i dont know how it happened but i was in the computers start menu and i moved some things and now it wont get internet.. i tried all i could but still nothing. what can i do?
    Problem Solver:
  • 4 Answers
Have you tried system restore? just go back to the most rescent one and you should be fine
All program/Accessories/System Tools/System Restore
Posted on Dec 12, 2009
Testimonial: "it works.. but it tells me that i need to close and save changes. i dont know what to do."
  • Microsoft Master
  • 5,569 Answers
Open 'Help' and look for 'network connections.' You'll find information there and if you have deleted a connection, you will need to set up a new one. I suspect it still exists but you just can't see it.
You can also go through the Control Panel, open 'Network Connections' to check the contents. If you see one that looks familiar, right click on it and and choose 'Create shortcut.' Once you have one you can place it on the Desktop or the Toolbar by clicking and dragging.
Posted on Dec 13, 2009
SOURCE:
Acer xc-215 blinking power bottom wont turn on
Please remove the battery and try to turn on the computer with the power supply. If the notebook is turned on with power, the fault is from the battery. I await your response, regards.
Feb 08, 2018 | Acer Computers & Internet
The power went out of My place last night... I woke up and my Mother board was flashing orange... I tried to restart my computer. Nothing happened can somebody help me? It is a Dell computer
Steps:
1. Unplug all the cables from the computer. (If you are not sure then make a note of which cable goes where)
2. After you've unplugged the cables. Press and hold the power button on your computer for about 3-5 secs.
3. It wont start the comp :). This steps is done remove any left over power in the comp...
4. Re-connect all cables and check.
Let me know if this helps, If not, then i'll tell you what to do next. :)
Also, please let me know if you use Dial or ADSL Internet. Because if previous steps dont work then we need to try anther steps.
Dec 21, 2012 | Computers & Internet
ERROR MESSAGE 0XC00000E9
Please restart your machine and keep tapping F12 key from the keyboard
It will display a menu with options
Press enter on DIAGNOSTICS option
Let's confirm if the hard-drive is not gone bad
It will confirm if all tests are passed, you don't necessarily need to run the extended memory tests
Or you can also check in F2 menu (BIOS menu) during reboot
if the Hard-drive/SSD is detected on your XPS 13 notebook
Try to load BIOS defaults too.
Please reply back with the results.
Dec 27, 2017 | Dell Studio XPS 13 Laptop Computer (Intel...
Internet explorer wont let me connect to the internet at all!!
dont use internet exp. instead mozilla.. i hope it may help..try it..
Jul 31, 2009 | Microsoft Internet Explorer 8
Keyboard wont work.
i had the same problem and called hp i was told to turn off my notebook and unplug the charger from the notebook take the battery off and hold down the power button for 30 seconds then reattach everything my keyboard started working again. i was told this happens because i donot let the battery die on my laptop or i keep it plugged in all the time which is true the notebook has to much static and the keyboard stops working. hope this helps
Feb 15, 2009 | HP Pavilion dv2715nr Notebook
Menu
is the button sticking,, you can try lightly wiping it with rubbing alchohol
Oct 05, 2008 | Samsung DVD-V4600 DVD Player/VCR
Internet connection
connection is OK, try to move the router or the computer close. till you have a good connection. then start move away, till you start to have problem. that is the max distance you can go away from the router.
Aug 05, 2008 | Verizon Communications Ethernet/Wireless-G...
PLZ!!! i rele need help!!! ='(
There are two ways to format an Mp3 player - one on the computer itself, and one in Windows Media Player. Both methods will end up erasing all the songs on the player, but the player will be "good as new" after that. Sometimes reformatting in this manner will override the player's native formatting and cause problems - this can be reversed in most cases by updating the player's firmware. Firmware upgrades are available from most manufacturers' websites.
WARNING: The following procedures will erase all songs on the player.
Check if the file system is NTFS. If yes, format it to FAT or FAT32. - Connect player to computer, double-click my computer, right click on icon of mp3 player and select format. This only applies to Windows-based computers.
You can also format the player in Windows Media Player itself:
Connect your Mp3 player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "name of Mp3 player here 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
-Tha Mp3 Doctor
Jun 03, 2008 | GPS
My guitar wont work properly
my scroll bar does the same thing sometimes, it moves up and down uncontrolably without me doing anything. i just recomend restarting and making sure the connections are all right. after i did that it seemed to work fine, but maybe if it keeps happening then you may need to replace it!!
Jan 09, 2008 | Activision Guitar Hero II for Xbox 360...
Taskbar and start menu
do a system restore to a point before that happened:
restart in safe mode and follow these tips.
http://www.howtogeek.com/howto/windows-vista/using-windows-vista-system-restore/
Nov 29, 2007 | Microsoft Windows XP Home Edition
Microsoft Windows XP Professional Logo
Top Microsoft Computers & Internet Experts
micky dee
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
