Question about Maytag MDB7130 Dishwasher
My dishwasher mdb7130 dishwasher panel light are flashing. Dishwasher is not turning on
  • 11,896 Answers
Check drain and screen for clogs, check the door switch to make sure it isn't broken or any disconected wires. You can test wiring to and from the switch with an ohmmeter.
Try disconnnecting from power source for a few hours, in the meantime, press and hold a start button for 3 seconds, wait half hour more, plug back in and see if resets itself.
If none of these work, you could have a fualty control board but testing with an ohmmeter will need to be done to verify
Posted on Dec 12, 2009
My Hotpoint DWF40 Dishwasher flashes wash and rinse lights. Water fills and drains fine. How do i fix it?
test this and fix it. God bless you
Heating Element
If lights are flashing on the control panel, the heating element might have burned out. The heating element heats the water up to operating temperature. After a set amount of time if the temperature isn't reached a light on the control panel might start flashing. The heating element can be checked for continuity with an Ohm meter.
Enter your model number to see parts for your dishwasher.
Help me find my model number
Heating Element Assembly
If lights are flashing on the control panel, the heating element assembly might have burned out. The heating element assembly heats the water up to operating temperature. After a set amount of time if the temperature isn't reached a light on the control panel might start flashing. The heating element assembly can be checked for continuity with an Ohm meter.
Check Fault Codes
If the display lights are flashing and there is an error code in the display window, check the wiring diagram and tech sheet in the dishwasher that will provide information on the fault.
Drain Pump
If lights are flashing on the control panel, the drain pump might not be working properly. For two-wire drain pump motors check them for continuity using an Ohm meter. If it's defective You'll need to replace it. Drain pumps are not repairable.
Touchpad and Control Panel
If the lights are flashing on the display the entire touchpad and control panel assembly might be defective. If the display works but the dishwasher functions are all out of synch, or some of the buttons don't respond properly the entire touchpad and control panel might need to be replaced.
Touchpad
If the display lights are flickering for no reason, the touchpad might need to be replaced. Sometimes when the touchpad is defective the display lights are flashing randomly.
Jul 24, 2013 | Dishwashers
Kitchenaid dishwasher KUDS01DJ Rinse only light is flashing. control panel is frozen with only rinse only light flashing. does not respond to pressing of any buttons. I flipped the breaker switch,...
Ok, Turn breaker off at breaker panel. Just off then on. The rinse only light should be on.....not flashing. Now press the start button first and hold; then press the cancel button. That should cancel all lights. Then press wash button then start. If the light is still flashing after you turn off breaker....you might have a bigger problem. May need new control panel.
Aug 19, 2011 | KitchenAid KUDS01DJ - Multiple Color...
MY DISHWASHER TRIPPED THE BREAKER AND WILL NOT COME BACK ON.
Hello- This series MDB7130 is involved in a recall. Check Maytag website for details. If affected, they will offer 75$ toward a new maytag.... or a free service call to 'retrofit' a new wiring harness. These units have caused a number of  fires so disconnect power until issue is resolved.- Let me know if this info helps. Thanks- Ed
Mar 12, 2010 | Maytag MDB7130 Dishwasher
The "clean" button is flashing & none of the other cycles work.
heated dry and high temp wash
toggle till all the lights light up
then hit cancel
you should be able to turn dishwasher back on
you probably have a bad heater
is it flashing 7 times
take kick panel off and look to the rear of the dishwasher
is anything burned
if the clean light keeps blinking replace your heater
Feb 09, 2010 | Dishwashers
We have a dishwasher that flashes clean light on front panel and will not allow a new cleaning cycle. Mod GU3200XTPS3 TYPE 577-0
Make sure the control panel is not locked. If you press any pad while your dishwasher is locked, the light flashes 3 times and the selection is ignored. If the lock symbol is lit, press and hold HEATED DRY for 4 seconds. The light turns off.
If the control panel is not locked and the problem still occurs press the Cancel/Drain button to drain all water and clear all indicators. (It might take 2 minutes to complete this action.)
Jul 08, 2009 | Whirlpool GU3600XTSY Stainless Steel...
DISHWASHER WON'T START,ALL LIGHTS ON PANEL FLASH RED
how to download the game gat4 (i don't know ENGlish )
Feb 15, 2009 | Kenmore 24 in. 17052 / 17054 / 17059...
Asko 1805 ALL lights flashing and no water coming out
High water level is often in the pan under the dishwasher.
  1. Unplug or turn off breaker.
  2. Remove kick panel.
  3. Remove water from pan.
  4. plugin/turn on breaker.
  5. watch for leaks.
May 30, 2008 | Asko 24 in. 1885 Built-in Dishwasher
Flashing LEDs
When doing some floor work, I had taken off the front bottom panel of the dishwasher and there was a pamphlet which had electronic information. Dummy me threw it away, but I remember it had code information on it. I am now having this flashing light problem. So check behind the front bottom panel (remove the 4 screws to get behind it) and the piece of paper should be in there. Please let me know if you find it!
Jan 20, 2007 | Maytag 24 in. MDB6100A Built-in Dishwasher
Maytag MDB7130 Dishwasher Logo
150 people viewed this question
Top Maytag Dishwashers Experts
Charles T Nevin
Charles T Nevin
Mike
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
