Question about Creative Labs ZEN V Plus MP3 Player
Creative zen I have a creative zen v plus which has turned itself into recovery mode have tried to reset but unsuccessful also tried clean up option.
    President:
  • 4,402 Answers
Detach your player from the PC if it is connected, and turn off the player.
If the player stops responding, you can reset the player. To reset the player, gently
insert a thin object into the Reset hole located below the power switch.
Booting straight to the Recovery menu
I decided to open it up to check out the hard drive to see what kind I would need so I could try replacing it. The data plug that attaches to the hard drive itself was partially unplugged. So, I pushed it back in all the way, put it all back together again, and turned it on just to see if something different might happen. (I had it set in my mind that the hard drive failed and I would need a new one, so I didn't expect anything different to happen) And to my surprise, it worked just like new again.
Before you go off and invest in a new hard drive, I suggest opening it up and make sure that plug is in all the way. Since you'll be opening it up in any case, it wouldn't hurt.
Posted on Jan 21, 2008
Creative Zen Firmware Problem
There's an updated firmware download: Firmware 1.32.01. Try downloading that.
Aug 13, 2008 | Creative Labs ZEN V Plus MP3 Player
Creative Zen V plus has frozen
i have a problem with my creative zen v plus. every time i shut it down it comes back on by itself. And when it comes on i have no control. can you help me. thank you
Jul 28, 2008 | Creative Labs Zen Micro MP3 Player
Creative Zen Touch stuck in "recovery mode"
Hi! I think you should try this (i've already tried it and it works):
1- Unplug your Zen from your Computer.
2-Turn off your Zen (if you can't do it, press the "Reset" button)
3- BEFORE turning on your Zen, press your "Play" button and hold it while you turn on.
4-When a format menu appears, select the "Format All" option (you'll loose all your Zen data).
5-When the format menu reapears, select the "Reboot" option and listo! You have your Zen as new and should not have problem. Good luck!
Jun 30, 2008 | Creative Labs Zen MicroPhoto MP3 Player
Have you tried to load the firmware? First you'll need to download the firmware to your PC from Creative's website: Click here. After you've downloaded it, connect your Zen via USB to your PC and open the firmware icon, then click "Upgrade."
For more detailed instructions on how to troubleshoot your Zen, click here
Jun 03, 2008 | Creative Labs Zen Touch MP3 Player
When i turned my creative zen v plus mp3 on it said firmware problems.and i t had a choice to clean up delete firmware and reload firmware . 1 more it was reboot and i tried all of them and none of them...
my 8gb black white creative zen microphoto mp3 gets to the recovery mode screen and has the four options i tried every thing and it wont work wat do i do???????
May 20, 2008 | Audio Players & Recorders
Help
I just got done fixing my daughter's Zen V 1GB which was frozen by holding down and keeping the play/pause button pressed and then powering it up. This will put the unit into recovery mode.
I selected "Clean Up" and this fixed the problem. I will assume the other options are a little more destructive to the stuff you've uploaded to it. Hope this helps!
Apr 20, 2008 | Creative Labs ZEN V Plus MP3 Player
Creative zen stuck
Replace hard drive
http://www.hardwarezone.com/articles/view.php?cid=9&id=1331
Apr 14, 2008 | Creative Labs ZEN V Plus MP3 Player
Recovery Mode
2. Press and hold the Play button while powering on your player.
3. When the player displays the Creative logo, release the Play button.
It will display the following options:
Clean Up
Scans the player and removes invalid links from its music library.
Does not affect music files themselves.
Format (All)
Caution! Erases all content!
Save a copy of your player's content before formatting.
Reload OS/ Firmware
Caution! Erases your player's firmware.
DO NOT select the Reload Firmware option unless you have access to a PC and you have downloaded the necessary firmware to install.
Reboot Reboots the device.
Dec 28, 2007 | Creative Labs ZEN V Plus MP3 Player
Recovery Screen, take 2.
If your Zen is not responding or in a "reboot loop" the following information from creative explains how to access the players recovery mode
Hope this helps, and good luck.
Zen V Plus and Zen V
1.
Clean Up
Format (All)
Reload OS/ Firmware
you might want to verify that your new player has the latest firmware available, as this might address the unresponsive-button issue you're having. Firmware updates are surprisingly easy - you just download the firmware file from Creative's website, plug in your player, and double-click the downloaded file. It's that easy.
Dec 27, 2007 | Creative Labs ZEN V Plus MP3 Player
Creative Labs ZEN V Plus MP3 Player Logo
37 people viewed this question
Top Creative Labs Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Mohamed Ismail
Mohamed Ismail
Are you a Creative Labs Audio Player and Recorder Expert? Answer questions, earn points and help others
