Question about Optimus STAV-3680 Receiver
No sound in right channel either a or b - Optimus STAV-3680 Receiver
    Problem Solver:
  • 16 Answers
The right channel on the amp in your reciever is bad the only way to fix this is to replace it im sorry for the bad news
Posted on Dec 12, 2009
When i turn the bar off it automaticly comes back on right away
Samsung HW-F450 2.1 Channel 280-Watt Soundbar
www.amazon.com/Samsung-HW-F450-Channel...Sou...
Amazon.com, Inc.5) If you use sound share to connect samsung tv to sound bar, it uses bluetooth. I dont know if ... The subwoofer is wireless though it requires power connection.
Amazon.com: Samsung HW-J550 2.1 Channel 320 Watt ...
www.amazon.com/Samsung-HW...Channel...Soundba...
Amazon.com, Inc.
Rating: 4.5 - ‎104 reviews
Sony HT-CT370 2.1 Channel 300W Sound Bar with Wireless Subwoofer, Bluetooth, ...Samsung HW-J650 4.1 Channel 320 Watt Wireless Audio Soundbar (2015 ... 2.1-channel sound system with 320 watts of total power. .... bar away from the TV, there's not gonna be a lag or cutting off of the signal. .... Right To Your Door.
Samsung HW F450 Sound bar Problems with arc connec ...
? 5:25
https://www.youtube.com/watch?v=e46odUZ71tE
Aug 4, 2013 - Uploaded by DUGLESSM
Samsung HW F450 Sound Bar hdmi hook up. ... How to connectSound Bar to TV, Blu-Ray Player, DVD ...
Question about new Samsung HW-F450 setu
Jan 05, 2016 | Samsung HW-F450 2.1-Channel Soundbar...
Preamp intermittent channel
Getting the connections right is a problem. One thing I find helps is the THX DVD discs that certain movies have on them. They have a sound set up to get it right. It makes a tone for each channel so you can hear which channel is working. It should help you set up the system right and determine if any channel has a fault on it.
Feb 08, 2014 | Adcom GTP-870HD 7.1-Channel Amplifier
Four wires coming from needle to cable, two are shield and two are left and right channels. Which color goes where
Actually it's not to hard to connect them. All you need is a stereo record where you know a sound of something is on the right or left channels. I use to have a Goodies LP where a one of them would say "bounce to the left" and the other said "bounce to the right" these coming on the respective channels.
To set it up just stick the red (right) on one of the cartridge pins and white - left on the opposite side - not underneath it. Then connect the other two to the pins below them. Play your test record. And if the sound which is supposed to be on the right channel come on the left - swap the two red and white wires around.
If the sound sounds (tinny spaced) out then swap the same side wires around.
So if you have say Red Green, Make it Green Red. If it is tinny only on one channel, don't switch the other channel around.
For example the right is tinny - do the above - but leave the other White Blue.
By the way some cartridges do have L and R marked on them and + and - for the channel types. " -" being for the green or blue wires.
Feb 08, 2014 | JVC Audio Players & Recorders
No right channel on AV2
First, does TV sound without external sources work on both channels?
With the one RCA connected and getting sound, unplug it and plug into other channel. Any sound? If not, remove it and plug the other RCA by itself into the left channel. Sound? If yes, plug it into the right channel. No sound? If not, bad TV input.
If you do get sound on that other channel with a single RCA, then you have either a bad cable or bad source. Reverse RCA's on source and try same test, plugging each RCA into each input on TV one at a time.
If the TV is bad, you will get sound on just the left channel regardless of which RCA you use.
Dec 16, 2013 | Blaupunkt Car Audio & Video
Technics 1310 turntable has left channel (white
There are just two causes, one is the preamp, which can be easily checked by putting the right channel jack in the left terminal. If the sound is normal, then it's likely that the cartridge in the deck is bad, or some wire is loose. However if the sound is still poor then the magnetic cartridge preamp in the amp has a fault. These are normally a single IC, which will have failed. Find the preamp by tracing the wires from the imput socket to the PC board, which may be alone.
Mar 21, 2010 | Audio Players & Recorders
Only the right channel working on the amplifier
first check on all your cabling, speakers and input sources for loose/defective cables. can you tell me what brand is your amp and model? does it employs digital source switch or mecahnical switches only.
Aug 12, 2008 | Audio Players & Recorders
Problem with sound
Its easy. Jus from task bar click on that Speaker Icon of sound. In that you can select the left channel, right channel or both! Keep the pointer in middle and you will get sound in both the channels! Enjoy
Jan 16, 2008 | Audio Players & Recorders
Only left/right have sound during the test
all of the channel are resonding to the test. but you cant notice it bec 5.1 speakers, each channel are designed to respond to a certain frequecies.  the L/R channel your talking about have the mid-range frequecies so it responds clearly compared to other channels...
hope that helps...
Oct 16, 2007 | Logitech Z-5500 Computer Speakers
105 people viewed this question
Top Optimus Audio Players & Recorders Experts
Larry Stiles
Larry Stiles
Craig Butler
Craig Butler
Are you an Optimus Audio Player and Recorder Expert? Answer questions, earn points and help others
