Question about JVC GR-DVL300 Mini DV Digital Camcorder
Computer won't recognize Gr-DLV 300 with firewire connection
Both JLIP Video Producer and Windows Movie Maker fail to detect a connection between our Toshiba Satellite 1905-S303 our GR-DVL300. We are using a firewire cable and have followed instructions. Do we need a video capture card?
Our goal is to transfer our camcorder video to our computer.
Please help.
Thanks.
  • movieme May 25, 2008
    same problem but i have vista
  • gracegiese Nov 30, 2008
    SAme problem, computer doesn't recognize camcorder.
My Sony camcorder wouldn't work with firewire either until I downloaded a fix at: http://www.microsoft.com/downloads/details.aspx?FamilyID=CA0F2007-18B5-4112-8BD6-8BF4BD3130B9&displaylang=en
Hope that helps!
Posted on Feb 01, 2008
6ya staff
SOURCE:
I can't download video from videocam to pc.
You should be able to connect your camcorder to IEEE1394 socket on a computer, by means of a firewire cable, and capture the video with Windows Movie Maker or other software. Windows Movie Maker is part of WindowsXP and is already instaleed on PCs.
Feb 07, 2010 | JVC GR-DV800U Camcorder
Can't upload videos to computer
Hi, I am not sure why cameras dont come w/ firewire cord. May be its expensive..?
Neways, You need to use the 4 pin firewire to 4 pin firewire cable to connect PC to the camcorder.  http://www.bluejprojects.com/blog/articls/video-2-pc-gs120/firewire-ends.jpg
This camcorder model has the firewire port. Please check the manual carefully to find its location.
You need to switch on the camera. Keep it in play/ edit mode. Open movie maker. Its should detect the camera now. If not, try installing the software which came with the camcorder. It might have any drivers.
Jan 03, 2009 | JVC GR-D370 Mini DV Digital Camcorder
How to connect JVC GR-D820E camcorder to PC
Hi, connect the cam and PC using 4 pin firewire cable. Switch on the cam. Open Windows Movie Maker and import the video from device.
Dec 28, 2008 | JVC GR-D370 Mini DV Digital Camcorder
Downloading videos to a pc
here some steps on how to transfer it to your computer.
  • Install the cd driver camed with your camcorder to your pc
  • Use USB to connect your camcorder and your pc after that it should be recognize
  • If not then do step 1
  • Use Ulead movie producer or Windows movie maker or any Video editing software
  • Upload it and let it stream
  • After uploading all videos save it on any various types of videos you like
Now your videos are on your computer
thank you for using fixya
CHARCOIS
Nov 08, 2008 | JVC GR-D270 Mini DV Digital Camcorder
I have jvc GR d720 dv camcorder but unable to connect .. driver required ... i have firewire send me in [email protected]
No driver required for Windows XP. I simply plugged in the camera via FireWire. Windows automatically recognizes it as a digital video device. Then I started up Windows Movie Maker and followed the wizard to capture the movie from my digital video device. It was really easy.
Oct 24, 2008 | JVC GR-D720 Mini DV Digital Camcorder
Transferring video to PC
Check if it has the firewire port. If so, you can get a 4 pin firewire cable and connect to the PC.
Switch on the Cam.
Open Windows Movie Maker and import video from device.
4 pin firewire would look like this:
http://www.pcab.co.uk/ebay/firewire%204%20to%204.jpg
You can use the Movie maker to burn it to the Disk
Sep 26, 2008 | JVC GR-DX77AG Camcorder
My computer no longer recognizes my JVC GR-D70U mini DV cam when I plug it into a usb port.
Hi, I am not sure. But I believe the camcorder has to be on when you connect to the computer. and I assume you use firewire for this particular camcorder.
I too once had this problem when I used Windows Vista. If you too use Vista, try it with Windows XP.
cheers,
Sep 19, 2008 | JVC Cybercam GR-D70 Mini DV Digital...
My computer doesn't even recognize my camera
if you are using a desktop, you require a an addon card called IEEE 1394 firewire card, which you have to install it on your motherboard's PCI slot, then using the firewire cable which you get along with the card should be connected to the card and DV port of the camera, then using the MOVIE MAKER software of windows XP, you can download the video.
Aug 13, 2007 | JVC GR-D290 Mini DV Digital Camcorder
Windows 98'
We confirmed the following software and drivers compatibility with Windows 95, 98, and ME. Picture Navigator JLIP Video Capture JLIP Video Producer JLIP Video Player Card Navigator USB Drivers GV-PT2 Printer driver & Capture GV-DT1 Printer driver & Capture Video Navigator None of the above software will be compatible with Windows NT. At this time there are no drivers available to make these software programs compatible with Windows NT. There is an update available for the Picture Navigator software to work with Windows 2000 and XP in the Customer Support area of this site. (When executing the update be sure to have Picture Navigator closed). The following versions of software and drivers will work with Windows XP. Picture Navigator 2.1.5.1 JLIP Video Capture 3.1 JLIP Video Producer 2.0 JLIP Video Player 1.0 Card Navigator 1.0 USB Drivers Video Navigator
Sep 14, 2005 | JVC GR-D70EK Mini DV Digital Camcorder
JVC GR-DVF31 - How to transfer MiniDV to PC?
buy that wire, check ur camcorder if it has 6pin or 4pin for firewire then check ur pc if it has firewire card...if not you have to purchase the ieee1394card. install it then connect your camcorder to pc through firewire and that will be it.. u also need to have a software for video capturing and editing like adobe, roxio, pinnacle , etc...hope that helps.
Sep 05, 2005 | JVC Cybercam GR-D200US Mini DV Digital...
JVC GR-DVL300 Mini DV Digital Camcorder Logo
770 people viewed this question
Top JVC Video Cameras Experts
Ekse
Larry Stiles
Larry Stiles
Al Rush
Are you a JVC Video Camera Expert? Answer questions, earn points and help others
