Question about Kogi l7eh-ta ko 17" Flat Panel LCD Monitor
Screen in color pattern when off
After a physical move the monitor screen no longer goes to black when turned off but instead cycles from all red to all blue to all green. This is very annoying.
  • kattykoi Jan 22, 2008
    Don't know what that is. I have since found out that what I am seeing is the factory test screen. Any other ideas?
  • 23 Answers
Check your signal cable
Posted on Jan 21, 2008
Dell inspiron screen is turns red while starting and shows red instead of black color
Try using a different monitor and check if you have the same issue with the other monitor. If the other monitor works great, then you would need to replace the LCD of your computer.
Mar 13, 2013 | Computers & Internet
Kogi monitor will not go black when turned off
bad cord on back try to wigle it by the plug in and by the screen it self
Jan 20, 2008 | Kogi l7eh-ta ko 17" Flat Panel LCD Monitor
Hi there, my dell projector 1800mp is not projecting an image on screen and it only black lines across. what should I do to fix it?.
After turning on the projector, press "+" and "-" buttons on the control panel
simultaneously for 3 seconds and release the buttons when screen goes blank.
2 Press "+" and "-" buttons again to exit the diagnostic mode.
3While in Self-diagnostic mode, the screen will run a seven-color-cycle test as
following:
Red--> Green--> Blue--> White--> Watchet Blue--> Dark Green--> Yellow.
Ensure that the colors of the test pattern are correct. Contact Dell if the colors are
not displayed correctly.
Mar 02, 2011 | InFocus LP 250 Multimedia Projector
My Dell E176FP 17" LCD monitor keeps cycling colors -red green blue black then colors again... (More) My Dell E176FP 17" LCD monitor keeps cycling colors -red green blue black then colors again during...
well that could be because the screen is going bad. you might want to get another one or take it in to get it fixed, no more than 100 to fix your screen.
Feb 13, 2010 | Dell E176FP 17" LCD Monitor
Dell E176FP Monitor Stuck in diagnostic mode??
See if the set has some sort of reset button. If none do a hard reset on monitor to hopefully clear the cobwebs in monitor electronics and see what happens.
Mar 12, 2017 | Dell E176FP 17" LCD Monitor
I lose picture and it's replaced by black screen w/ colored block
heat is usually the prob. sometimes when it overheats it will warp the whole cabinet inside.
Jul 01, 2009 | Samsung HLP4663W 46" Rear Projection HDTV
Dropped laptop, color on screen not natural
The problem could be that you jolted a heat sync or fan loose that cools the video adapter. If you power off the machine and let it sit for several minutes and then reboot and the same thing happens, its a heat issue. Laptops have the graphics card in a chip form soldered to the motherboard, thats not the issue. Undoubtedly you have jostled something loose. If in fact it is a heat issue, you can have someone take the laptop apart and reseat the heat sync or maybe check on the fan that cools the video adapter.
Mar 21, 2009 | HP Pavilion dv2000t Notebook
Powers up, shows test menu then black screen
This sounds like a video problem with the COMPUTER.....try the monitor on another computer. Usually, if you can see the monitor test pattern the monitor is ok.
Mar 15, 2009 | Dell E171FPb 17" TFT LCD Flat Panel...
Dell AS501 flat screen monitor
The front panel switches seem to be the culprit.
If you are technically sound you maybe able to solve problem by opening monitor and clean front panel switches or replace them.
Samir.
Feb 28, 2008 | Dell E173FP 17" LCD Flat Panel Monitor
Kogi l7eh-ta ko 17" Flat Panel LCD Monitor Logo
Top Kogi Computers & Internet Experts
Laxman Bisht
Laxman Bisht
Computer Links
jay kaye
jay kaye
Are you a Kogi Computer and Internet Expert? Answer questions, earn points and help others
