Question about Broderbund American Greetings Creatacard Platinum 8 for PC
I have files of cards I created on another PC and am not able to open them even though this new PC has creatacard 6 loaded
  • 581 Answers
Are you making sure that you have selected creatacard 6 as your default program for opening these file extensions? if not, then the default program you are using for graphics will attempt to open it but not be able to. Click on one of the cards and select open with and select creatacard 6 as your default
Posted on Dec 13, 2009
Micrografx creatacard 3 gold - repeat only micrografx, not american greetings
Micrografx Creatacard Gold 3 was created back in the Windows 98 days and most likely the installer is a 16-bit installer. Windows XP worked OK with 16-bit installers, but Vista, Windows 7 and Windows 8, 8.1 will not work. There is a work-around I found ( I actually found this fix for installing Photoshop 7 under Windows 7) and it works! I was able to install Photoshop 7.0.1 under Windows 7 Pro x64 edition and it works great!
Perform a search for Install-Photoshop-6-or-7-on-Windows-7 or go to this website http://www.wikihow.com/Install-Photoshop-6-or-7-on-Windows-7. Under this website, Look at Method 3 of 3 .
Stuff you will need:
1. A working Windows XP -SP3 system where you can install the Free Scalable Smart Package. You may be asking why? You will need to install the Micrografx Creatacard Gold 3 on this system with the "Discovery Program" running so it can create a new 32-bit installer
2. A CD-RW or a Memory Stick where you can copy the new .MSI file created and run it from Windows 7 x86 or x64 bit system.
3. Download the Free Scalable SmartPackager program. This used to be called WinInstall LE but they have since changed the name. You can find the program here http://www.scalable.com/smart-packager-ce-msi-package/. This is Free, but you still need to register to get the software. The latest version as of last week is v2.0.2.
4. Printed out instructions from the website so you can follow along. Once you perform this, you may end up trying this for other "older" software as well.
Basic Overview:
1. Under your Windows XP - SP3 system, install the Packaging software called Scalable SmartPackager v2.0.2
2. Once you have installed the SmartPackage program, it is a good idea to Reboot your system so all files get updated properly.
3. Start the icon called Smart Packager.
4. Under Smart Package, make sure you are under the Welcome screen and click on the Discover a new Package under Common Tasks.
5. When the Blue Discovery screen pops up, click on the Next button
6. Under the New Package Information screen, type out Creatacard Gold3 or something that you like
7. Under the Output Folder, Click the Browse button and select a folder or location where you want the new Creatacard Gold3.msi to be saved. Make sure you click on the Show advanced Options box below and Then Click Next
8. On this screen, you will now need to Click on the Start Discovery. This is what the SmartInstaller program will use to see where all the files are being installed to, etc when you run the Creatacard Gold 3 installer.
9. Insert the Micrografx Creatacard Gold 3 CD in the drive and install the program like you normally would. Please remember to install any of the Extra Free fonts as well during this time since this will be the only time you will have to create a new 32-bit installer (unless you run this process again)
10. After the Creatacard Gold 3 program has installed, verify it is working by Running the program and testing out various things within the program. (This is while the Discovery is still running in the background)
11. Once you have verified the Creatacard Gold 3 program is running properly (under the Windows XP system) then go back to the Discovery window and click on the Red Stop Discovery button and then click on the Next Button.
12. Make sure the Add new package to Smart Packager is checked and then click on the Finish button. This will now save the new "updated installer" MSI file over to the folder location you specified under option 7 above.
13. Copy this new *.MSI file you just created and either burn it to a CD-RW or copy to a Flash drive and take this file over to your Windows 7 system.
Please note, these instructions are an overview and may not contain the entire correct order. The last time I performed this was back in January 2014 when I first discovered the article about using Scalable Smart Packager to re-create an installer file into a true 32-bit installer.
For me so far, the installer has worked with Photoshop 7 and several Photshop plugins like KPT5, KPT7, etc.
I make no guarantees that this will work in your situation but it could not Hurt.
Plus, should you have problems removing this program I would recommend you try this Free program called Revo Uninstaller v1.95. This is Free for Home/Personal use only.
Hopefully you can use the above instructions I provided and get this great program to work under Windows 7.
Please let us know if this process worked for you or not.
Nov 23, 2013 | Broderbund American Greetings Creatacard...
I have changed my computer to Windows 7 Home premium with 64 bit operating system. I have creatacard 3 and have tried installing it on my system. however it is not compatible with this system , how can i...
Start the "Windows Compatibility Wizard", and tell it that you want to install a "Windows XP" program. Windows 7 will then read the CD, and install the program, and run it in "XP" mode.
Jun 25, 2011 | Broderbund American Greeting CreataCard...
I had an application called "creatacard gold 3" on my old computer with xp. I have all my important information from past 10 years is on that application. the computer crashed and i needed to buy a new...
The CreateACard Gold 3 (CAC Gold 3) will never work with Windows 7 64bit unassumingly because the software producing company has not upgraded their software for even Vista 64bit.
I recommend you to switch to " Hallmark Card Studio Special Edition" it has all the features of CAC Gold 3. You will enjoy it as there should be no problem installing it with Windows 7 64bit.
Good Luck!
Sep 21, 2010 | Computers & Internet
I have creatacard gold 4 that will not load with windows7 onto a new HP Pavilion computer. I tried the compatabiliy modes and still it will not load . the trouble shooting program says that it is...
Dear,
Your HP computer may be new, but your programs must be compatible with your operating system. If your Creatacard is older, the compatibility most likely stops with Windows Vista. Windows 7 is like a "brand new day". Read the label on your CD. It will tell you which systems it will work on. I had Windows 98 and Windows Millenium. When I upgraded to Windows XP my "create" CD's no longer worked.
Try downloading Avery cards. Be blessed.
Mar 13, 2010 | Broderbund American Greetings Creatacard...
Ds i have a r4 which already has games loaded onto
Insert your sd card into the computer/laptop using the sd card adapter and open the file then click on the file named games. Downlaod your games you want from online sites and put them into the folder named gamnes.here you can also delete the already existing games or even add music by creating a new folder called music not in the games folder though.
Feb 26, 2010 | Nintendo DS Console
I have tried several times to uninstall creatacard select 7. I can't uninstall it. I'm desperate. Please tell me what to do.
Go to Program Files in your computer's main-drive and delete the folder for create-a-card. If that doesn't work, or it says access denied, restart windows in safe mode and try it again.
Jan 25, 2010 | Broderbund American Greetings Creatacard...
How can I email a card
if it is a file drag the file to the page you want to use to e-mail
Dec 13, 2008 | Broderbund American Greeting CreataCard...
Creatacard gold 3 won't work with Vista
I just installed Hallmark Comedy Card Studio by Sierra on my Vista 64-bit machine. It works with all the saved files from Creata Card. If the Calendar and Address Book data file is fmnot32.dat, rename it to planr32.dat and then the Event Calendar will work as well.
May 30, 2008 | Broderbund American Greetings Creatacard...
Creatacard 3
i hate Vista as well. i am trying to find a solution. my whole life over the past couple of years is wrapped up in the eventminder and fmnot32 files but after installing Creatacard on my machine with Vista, it will not recognize the files.
i open my address book, it's empty. i open my calendar it too is empty. how can i get this program to recognize the files i copied from the old machine? PLEASE HELP! i've tried everything including dragging them both over at the same time (file plus .BAK). i don't know what else to do.
Apr 23, 2008 | Broderbund American Greeting CreataCard...
Broderbund American Greetings Creatacard Platinum 8 for PC Logo
62 people viewed this question
Top Broderbund Computers & Internet Experts
Martin Murray
Alun Cox
Are you a Broderbund Computer and Internet Expert? Answer questions, earn points and help others
