Question about Garmin nuvi 200W GPS Receiver
How do i charge garmin nuvi 260 it doesnt chare while plugged into car lighter which is the only power source it comes with
  • 486 Answers
TRY CHECKING THE FUSE IN THE END ON THE GPS CHARGER, THE TOP WITH SPRING LOADED TIP UNSCREWS TO LOCATE IT, THAT IF YOUR CAR LIGHTER IS WORKING, TRY A USB /MINI USB FROM YOUR PC/LAPTOP TO SEE IF THE GPS UNIT IS ACCEPTING CHARGE
Posted on Dec 12, 2009
Garmin nuvi 260 battery does not hold a charge
If a wall powered charger is used it could be bad or the connection from it to the unit damaged---happens if the charger is connected/disconnected a lot----same thing can happen if using the lighter plug adapter for charging.
Nov 06, 2012 | Garmin nuvi GPS
Battery
The unit will take a very slow charge via your computer. I tell most people no it doesnt charge VIA your PC just because it takes soooo long. I recommend getting a new power cable from GPSCity. Just call them up or follow the like to the cable you need.
** This cable is for the Nuvi 200 series GPS units
http://www.gpscity.ca/garmin-mini-usb-12v-cigarette-lighter-adapter-for-nuvi-in-web-packaging.html
Cheers
Jul 13, 2010 | Garmin nuvi 260W GPS Receiver
Hi i have garmin nuvi 205w i was showing me ,accessory not suppor
maybe it is not charging
does the charging light come on?
both on the unit and on the car power plug.
does your cigarette lighter in the car power other things?
you can charge it with a mini-b usb cable connected to a computer.
Jan 14, 2010 | Garmin nuvi 750 GPS Receiver
I havew a Garmin nuvi. Yesterday I was driving
Check the fuse in the lighter end of the cord.....it may be blown and the unit is not getting power.
Oct 26, 2009 | Garmin nuvi 260W GPS Receiver
My garmin charges with my computer but stopped charging in the car
The most obvious answer is a possible blown fuse in the cigarette lighter socket or the in the tip of the charger plug. Most charger plug fuses are accessed by unscrewing the metal tip. Check both for good fuses.
If this doesn't solve the problem, make sure the points of contact between the charger, cradle and GPS are all free of dirt and grime. Don't forget to vacuum the cigarette lighter socket - especially if it is used as a lighter, too.
Sep 16, 2009 | Garmin nuvi 200W GPS Receiver
New Garmin 260 W won't do anything when plugged in.
Your PC may not be able to charge it. If it does it's only a trickle charge. May take a day or two
The Garmin cigarette lighter charger take 4 hours.
Dec 26, 2008 | Garmin nuvi 200W GPS Receiver
When I attach my garmin nuvi 760 to the car mount and plug it in the car charger it will not power off and on when the car turns off and on. For example if I turn the car off the garmin continues to charge...
This is telling me that your cigarette lighter socket has +12VDC applied to it all the time EVEN when the ignition is turned OFF. This is not the fault of your Nuvi. On some cars, like Hondas, the cigarette lighter socket powers off when your ignition is turned off.
If you want it to turn off with the ignition, then you will have to power it from a +12VDC source that is controlled by the ignition.
- Jim
Dec 04, 2008 | Garmin GPS
Garmin NUVI 660 power problem.
To charge a nuvi, use one of the following methods:
  1. Connect the nuvi to the suction cup mount and the vehicle power cable.
  2. Connect the USB cable to the nuvi and the computer. The computer will charge the nuvi as long as the computer is on. However, the unit will be in Mass Storage Mode and normal operation is not possible.
  3. Connect the AC power cable and the nuvi to a wall outlet.
Please note: All of the nuvi series will come with a suction cup mount and vehicle power cable to charge the nuvi. However, only some of the nuvi models will come with an AC power cable and/or USB cable. If they did not come with the nuvi, they would be optional cables and would be a separate purchase. Garmin only recommends using an AC power charge that is purchased from Garmin. Third party power cables may not charge the nuvi. These cables may be purchased from Garmin or Garmin's dealers.
Oct 11, 2008 | Garmin Nuvi 660 GPS Receiver
My Garmin Nuvi (200 I think) freezes..
My recomendation is to use the original accesory for cigarete lighter. I'll give you an example: when I connect my Nuvi 200 to any other USB cable (computer or home charger) its behaviour is like you said - it "says" that is connected to a computer and remains in stand by. But when I connect it to cigarette lighter (but note - the original one) the nuvi 200 recognize it as a car power source and works. The battery symbol disappear from screen and it works perfectly. When I turn off the engine or simply unplug the device from cigarette lighter (not from nuvi !) it recognizez that and ask me if I want tu turn it off on remains on on own battery. If I make no option the nuvi will turn off automatically after some seconds. So it recognize perfectly the car adapter and its behaviour is adapted to a car.
Oct 08, 2008 | Garmin Nuvi 350 Car GPS Receiver
Garmin nuvi 200W GPS Receiver Logo
167 people viewed this question
Top Garmin GPS Experts
Marvin
Marvin
Steve
Will Halftowaite
Are you a Garmin GPS Expert? Answer questions, earn points and help others
