my webcam microphone is not working. have checked the webcam mic and diagnostics show it is working but not working when I attempt to go into a Chatroom on Yahoo! Messenger.
-   Even after sorting it out in control panel it still doesn't work. The sliders don't move but the mic doesn't work.
-   Guest
Mar 12, 2009
-   This solution does not work for me. On Windows XP with VX-6000
When I run the Sound Hardware Test Wizard, the volume drops down to the bottom, and if I try to slide the volume up, it maxes out and slides back down.
When it runs the speaker test, the microphone volume flickers up, maxes out, then immediately after the playback volume maxes out, and the speakers buzz, until the microphone volume slides back down.. this repeats..
-   jonob
Jan 11, 2009
-   my microphone worked until 2 days ago!!! nothing to do, re-installed 2 times( 1 disk, 1 MS website), sound bar drops to the bottom, if I raise it, it drops again!
-   mrisebastien
Normal
0
Go to Control Panel and Click on Sounds, Click
on Audio, then Click on the Microphone. Then Click on the drop
down and select Camera Microphone.
Click OK and it should work.
Hope this helps. Bud
Comments:
Feb 05, 2009
Normal
0
We are looking for a basic web cam for outside use that we can record/monitor from a computer. Any...
(More)
We are looking for a basic web cam for outside use that we can record/monitor from a computer. Any suggestions?
I cannot get Lifecam VX-3000 working with SKYPE. When I try to make the test call, it tells me there...
(More)
I cannot get Lifecam VX-3000 working with SKYPE. When I try to make the test call, it tells me there is a problem with the microphone inside my computer, and ends the call. I'm using Windows XP.
