Question about Dell Inspiron 630M Notebook
My Dell Inspiron 630m Laptop LCD screen doesn,t work, all that it displays is vertical lines and nothing else. The LCD ribbon/ Lead has been changed, but that made no difference. Any ideas, will it need a new LCD panel
  • 430 Answers
Try using laptop with a external Monitor to answer your question
Posted on Dec 12, 2009
Multiple vertical screens at startup (dell inspiron 4100)
Try connecting an external monitor to the laptop (15 pin VGA connector). If the display appears normal on the external monitor then you have an issue with your laptop's LCD display. If the external monitor also has vertical screens then your video circuit on the laptop has a problem.
May 19, 2011 | Dell Inspiron 4100 Notebook
My display on my dell inspiron 630m fades and goes pixelated. If i apply pressure on the sides of the screen, the image reappears and everything is perfect. I currently have 2 clothes pegs holding the...
this is an extremely common LCD failure. Unfortunately, due to the design of laptop LCD panels, the best solution would be to replace the entire panel (usually they run between $70 - $130 on ebay depending on size, aspect ratio, etc) Its a fairly straight-forward job, but if you are not comfortable with electronics disassembly take it to a reputable repair shop to have the work done (DO NOT pay more than $50 for the labor for this repair)
Mar 23, 2010 | Dell Inspiron 630M Notebook
Vertical lines on laptop screen
There are only two issues here, one it could be the data cable on the left side of the screen has come loose from the socket on the LCD.....most likely though is your starting to have a cascading screen failure and will need to replace the LCD panel.
Jan 05, 2010 | Dell Inspiron 9200 Notebook
I have Dell Inspiron 2200 laptop. My laptop's
The lines indicate a slow failure of the LCD and it is progressive. The system can be connected to a VGA monitor and you can select the External display using Fn + F8 key combination.
LCDs are about $100 on EBay
http://shop.ebay.com/?_from=R40&_trksid=p3907.m38.l1313&_nkw=Inspiron+2200+LCD&_sacat=See-All-Categories
Dec 25, 2009 | Dell Inspiron 2200 Notebook
Good Evening, I have a HP laptop and it has a black line about 1 inch wide running vertically on the screen
To me this sounds like there is a problem with the LCD flat ribbon cable which connects the motherboard/mainboard of the laptop to the LCD screen. Does this vertical line always appear regardless whether you are in Windows? If so, then the cable
is either slightly loose or is somehow being pinched by the laptop hinge. Tap or press in the area above your keyboard to see if this goes away. If not, you may have to open up your machine and inspect the LCD cable.
Dec 04, 2009 | Dell Inspiron 9300 Notebook
Dell Inspiron 1501
If the laptop keeps working, and you can use it on an external screen, then it is likely an hardware fault.
First perform a complete system recovery, like probably already instructed by the Dell support helpdesk. This will practically exclude the possibility of a driver or system problem.
If the problem is hardware , then you may have a faulty inverter board , a bad LCD display/LCD ribbon connection, or a faulty video adapter (integrated with motherboard).
If the problem is the inverter, then the screen will go dark, and the laptop will keep working on external display. This is probably your case.
If the problem is LCD display or ribbon cable, then the display will be blank with light on , and the laptop will keep working on external monitor.
Fault concerning video adapter usually cause the the system not to work at all, and it is uncommon under conditions described.
Sep 04, 2009 | Dell C3039 Inspiron 1100, 1150, 5100,...
Display on my Dell 710M has started having vertical lines on half the screen. everthing else fine. need new display?
Vertical lines on half the screen:
Usually the display ribbon cable or the LCD display. At the shop we find out replacing ribbon cable first.
In some rare occasion it can be the display adapter built on the motherboard. You can test the video adapter connecting the laptop to an external display.
regards.
Jul 14, 2009 | Dell Inspiron 710m Notebook
I have Dell laptop inspiron 630m. I formated the laptop then the display driver is missing. Its showing all the things except its display got more wider
just check your video card model, then go online to download the video card driver.
in case you have a build-in-video card like intel .....somethings, just go back dell.com and check your model , and download the video card driver.
Jan 14, 2009 | Dell Inspiron 630M Notebook
Inspiron 1150 lines on screeN problem.
Connect an external monitor to the laptop and see if it also has the vertical lines. If the external monitor looks fine, then your laptop’s LCD display panel is bad. If the monitor has the vertical lines displayed on it, then your graphics card or motherboard is bad.
Your responses are intended to improve the level of service provided. Please show your appreciation by rating your experience.
Thank You.
Nov 10, 2008 | Dell Inspiron 1150 Latitude D600 14.1 LCD...
Dell Inspiron 630M Notebook Logo
202 people viewed this question
Alun Cox
