Question about HP Pavilion dv9000z Notebook
None of my media will connect to the server, ie: itunes, windows media, quicktime
  • 4 Answers
Who's server? Your home server, or your company's server, or your employer's server.
If it's your employer's server, they may well have controls to prevent that.
The principal role of a server is to move data and manage the movement of data. It communicates with other computers, not users. It's not uncommon for servers to not run "user" applications.
Posted on Dec 12, 2009
I want to delete movies purchased on my iPhone 4
iOS: Device not recognized in iTunes for Windows
I would start with
Removing and Reinstalling iTunes, QuickTime, and other software components for Windows XP
or
Removing and reinstalling iTunes, QuickTime, and other software components for Windows Vista or Windows 7
If you have iTunes 11 turn on the Sidebar. Go to iTunes>View and click on Show Sidebar. You can also do a Crtl+S to show the sidebar. The sidebar is where Devices appears. and Control+B to show the Menu bar
Next try another computer to help determine if you have an iPod or computer problem.
The update problem typically indicates a either a network problem or an Apple server problem. That happened to be a few times. I just retried and it work after a while.
Feb 25, 2013 | Apple iPhone Cell Phones
I have a problem with sync with itunes, anything i want to transfer or install apps ...it just get stuck on sync...even after it finishes ,,,nothing:((((
im not sure what you are referring to but it sounds like you might need some software
http://www.download.com/isynctunes/3000-2141_4-10452590.html?tag=api
iSyncTunes is used to transfer songs from an iTunes library on one computer to another one or from your iPod
hope this helps
Jul 14, 2012 | Computers & Internet
1. My 2008 MacBook Pro rejects most cd's and dvd's, has a Intel 2.5 GHz Intel core 2 processor. 2. When I downloading or streaming movies they keep re-buffering
Solving Problems with Streaming Services
If the Server Does Not Start Up or Quits Unexpectedly:
  • Check the error log.
  • Make sure the QuickTimeStreamingServer file is in the /usr/sbin/ folder.
    You must be logged in to the server computer as Administrator (root) to see the QuickTimeStreamingServer file in the Workspace Manager.
  • Use the Mac OS X Server Setup Assistant to reconfigure the Ethernet ports.
If Media Files Do Not Stream Properly:
  • Make sure the movie file is supported by the QuickTime Streaming Server. Check the list of compatible file formats.
  • Try streaming a sample movie to see if the server can stream it. You can download a sample prehinted movie from the Apple Software Updates Web site: http://www.apple.com/swupdates
    If the server streams the sample movie, the problem you're having may be with the way your movie file is prepared. Recreate the movie.
    If the sample movie doesn't stream, the problem you're having may be with the server computer or the network.
  • Try hinting the movie again with the Optimize Hints For Server option selected.
  • Check streaming server activity and if necessary, reduce the number of connections or throughput.
  • If the problem occurs on a Mac OS client computer, open the TCP/IP control panel on the client computer and make sure MacIP is not selected.
  • If the problem occurs on a client computer, make sure the user has the appropriate settings in the Streaming Proxy and Streaming Transport panels of the QuickTime Settings control panel. The administrator for the client computer's network should be able to provide the correct settings.
  • If the problem occurs for media streamed using PlaylistBroadcaster, try hinting the movies again with the RTP Payload Encoding set to QuickTime and Smooth Data Rate enabled.
  • If you are reflecting more than one live stream, make sure each stream uses a separate UDP port. Otherwise client computers will show a message with error 500. You set up ports in the relay configuration file.
If Streaming Service is Slow:
  • If you are streaming QuickTime movies, make the movies self-contained using your authoring application, and make sure hinting is optimized for streaming services.
  • Reduce the maximum number of connections or the throughput.
  • Turn off other services.
  • Place media files on other hard disks to improve server performance.
    Because QuickTime Streaming Server can use only one media folder, you need to create links from the folder you have selected in QuickTime Streaming Admin to the media files on other hard disks. To do so:
    In the Workspace Manager, press the Control key and drag the folders that contain the media from the other disks to the folder you have selected as the media folder.
Aug 04, 2011 | Computers & Internet
When I try installing Itunes half way through installing a pop up comes up saying- "Could not access network location %APPDATA%\." Can u help me fix this.
Please take note that the following steps is in assumption that you are using a Windows operating system.) As I have found out in the iTunes support in apple.com, this symptom may be caused by anti-spyware software preventing iTunes from installing correctly. One such application is SpyCatcher. Before installing iTunes, temporarily remove this software to allow the iTunes installer to complete.
If you are still having trouble installing iTunes for Windows, follow the troubleshooting suggestions described in this article.
General installation troubleshooting Important: iTunes installation is successful a majority of the time after completing these troubleshooting procedures. If one step does not resolve your issue proceed to the next.
1. Empty your Temp directory and restart
Windows XP:
  1. Choose Start > My Computer (or double-click My Computer on the Desktop).
  2. In My Computer or Computer, open the "C:" drive.
  3. Open Documents and Settings.
  4. Double-click the folder titled with your username.
  5. If you see a Local Settings folder, skip to step 10. If you don't see a Local Settings folder, proceed to the next step.
  6. Choose Tools > Folder Options.
  7. Click the View tab.
  8. Select the option to "Show hidden files and folders."
  9. Click OK.
  10. Double-click Local Settings.
  11. Right-click on the Temp folder and choose Delete.
  12. In the confirmation dialog that appears click Yes.
  13. If you are unable to delete the Temp folder, close all programs, especially those in the Notification area ("System Tray") of the Windows Task bar and repeat step 11.
  14. Restart your computer.
Windows Vista and Windows 7:
  1. Choose Start > Computer
  2. In Computer, open the "C:" drive.
  3. Open the Users folder.
  5. If you see an AppData folder, skip to step 10. If you don't see an AppData folder, proceed to the next step.
  6. Choose Organize > Folder and Search Options.
  8. Select the option to "Show hidden files and folders." (In Windows 7 this option will be called "Show hidden files, folders, and drives").
  9. Click OK.
  10. Double-click the AppData folder to open it. If Windows needs your permission to continue click Continue.
  11. Double-click the Local folder to open it.
  12. Right-click on the Temp folder and choose Delete.
  13. In the confirmation dialog that appears click Yes.
  14. If you are unable to delete the Temp folder, close all programs, especially those in the Notification area ("System Tray") of the Windows Task bar and repeat step 12.
  15. Restart your computer.
2. Completely remove iTunes and QuickTime
For Windows XP, follow instructions in Remove and Reinstall iTunes, QuickTime, and other software components for Windows XP.
For Windows Vista or Windows 7, follow instructions in Remove and Reinstall iTunes, QuickTime, and other software components for Windows Vista.
Note: Songs you purchased from the iTunes Store or imported from CDs are saved in your My Music folder by default and are not deleted by removing iTunes.
3. Install the latest version of iTunes
Once you have completed the above steps to Empty your Temp directory, Completely remove iTunes and QuickTime, and Clean up iTunes installer files on the computer, you can install the latest version of iTunes from http://www.apple.com/itunes/download.
Additional troubleshooting Make sure you have administrator-account access To install iTunes or QuickTime software, you need to be logged in as an administrator on the computer. If you're not sure if you have administrator-account access, contact the owner of the computer or your system administrator.
Get the latest Windows updates The first thing to do when troubleshooting an installation issue on a Windows computer is make sure you have the latest Microsoft Windows updates installed—to get the latest updates, go to the Microsoft Windows Update page.
iTunes and QuickTime software for Windows require Microsoft Windows XP or Microsoft Windows Vista with latest Service Pack installed.
Disable other conflicting software In Windows, some background processes can cause issues for other programs and processes. These conflicts can prevent applications such as iTunes and QuickTime Player from installing. See Using MSCONFIG to troubleshoot conflicts in Windows XP or Using MSCONFIG to troubleshoot conflicts in Windows Vista and Windows 7 for assistance disabling conflicting processes.
Additionally, some third-party security software cannot be disabled using Selective Startup (MSConfig). Because of this, it may be necessary to temporarily manually disable such software while troubleshooting installation. For assistance in configuring or disabling your security software, please contact the manufacturer.
Make sure your folder names don't contain strange characters If the iTunes installer (iTunesSetup) is not responding or appears frozen after launching the installer then the folder where the installer is stored may contain unusual characters. If you notice that the iTunes installer or stored in a folder like this, either rename the folder or move the iTunes installer to another location such as the Desktop before launching.
More help If these steps don't help, you may be able to find a solution to your issue by searching the Microsoft support website.
If the above troubleshooting steps have not helped, proceed to the following steps Solutions to common installation errors Here are some common symptoms you may see when installing iTunes and QuickTime for Microsoft Windows. If you are experiencing one of these symptoms, try the suggested troubleshooting steps:
If you only need to install QuickTime, or if iTunes installs but QuickTime installation did not complete Try downloading and installing the standalone version of QuickTime from http://www.apple.com/quicktime/download/. Be sure you download the version that does not include iTunes.
Aug 06, 2010 | Apple iTunes
Error 7 keeps coming up when oppening itunes
A number of users have experienced problems updating to the newlyreleased iTunes 8.1.1. Generally, when this issue occurs, installationappears to proceed normally but then delivers the error message “Theinstaller encounted errors before iTunes could be configured. Yoursystem has not been modified. To retry these operations at a later timeplease return to the installer again. Click Finish to exit installer.”Fix
This problem can often be fixed by reinstalling the latest version of QuickTime via the following steps:
  1. Download the latest edition of QuickTime for Windows (make sure to pick the option without iTunes)
  2. Choose to save the file to your disk, then double-click the .exe file and install QuickTime
  3. After QuickTime is successfully installed, download iTunes again, choosing to save the file. Double-click the iTunes installer .exe and proceed with installation.
Other potential fixes for this issue include:
Run a disk check Disk errors, particularly in Windows XP, can prevent proper iTunes installation. See this Microsoft Knowledge Base article for instructions on performing a disk check/repair.
Use Windows Installer Cleanup Use the Windows Installer Cleanup toolto remove any references to Apple-related installation files(QuickTime, iTunes, etc.), then re-try using the aforementionedtwo-step method to reinstall QuickTime and iTunes
Oct 22, 2009 | Apple iTunes
When I tried t osest up in itunes store it said quicktime problem. I remived qicktime and itunes from programs as instructed. Ho wdo I get my ipod synced to itunes and store for downloads?
ok i think i know what you mean. i had the sme problem. first totally remove all quicktime and iTunes. then go back to apple.com and download iTunes. Quicktime should install with it. Or it should pop up saying if you want to.
Dec 27, 2008 | Apple iPod nano
Problem downloading Itunes on Dell P.C.
try the following procedure.
first, head into your start> control panel >Add/Remove programs and uninstall your QuickTime. if it goes, good. if it doesn't, we'll just attend to it when we attend to itunes.
next, download and install the Windows Installer CleanUp utility. use it to clear any existing itunes and/or QuickTime installation configuration information from the PC.
Description of the Windows Installer CleanUp Utility
http://support.microsoft.com/kb/290301/ (Copy ans paste the link in internet explorer)
next, use the the following document as a guide for manual removal of leftover itunes and quicktime program files:
Removing iTunes and QuickTime for Windows
http://support.apple.com/kb/HT1925?viewlocale=en_US
now try to install itunes again. does it go through properly this time?
If not then also try installing latest windows installer software
(Sometimes an iTunes entry or QuickTime entry doesn't show up in cleanUp, in conjunction with a missing .msi message, if there's an older version of the Windows Installer on the PC.)
http://support.microsoft.com/kb/893803/
Dec 22, 2008 | Computers & Internet
I cannot get my itunes to work.
Remove your quicktime
Remove your Itunes
Reinstall your itunes.
Regards,
dC
Nov 30, 2008 | Apple iPod MA446LL/A MP3 Player
Itouch with windows vista problem
vista is a hassle in all my experiences, have you tried completely uninstalling itunes and reinstalling your brower
is it only the browser that cannot connect to the internet or is it other programs too?
you could try using a system restore point
Nov 22, 2008 | Apple iPod touch
Mac Media Player
Any of the following are good:
QuickTime with Perian
Real Player 10 for Mac OS
Windows Media Player for Mac OS X 9.0If you don't have Mac OS X, get the Windows Media Player for Mac 7.1 which runs on the Macintosh Classic OS.
VLC media player for Mac OS X
Hope that helps! Should you have any further questions, please feel free to post them here.
P.S. – I would greatly appreciate a FixYa! rating if the solution I provided fixed or helped you fix your problem.
Thank you for using FIXYA!
Cheers!
IrishDruid
Oct 12, 2008 | Apple QuickTime
HP Pavilion dv9000z Notebook Logo
91 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
