Question about Hamilton Beach Food Mixers
Stand for bowl is broken. could this part be replaced?
  • dduhaime867 Dec 14, 2009
    Email is helpful solution. were looking for a part for electric mixer. thanks.
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. I think it might be time for a new mixer. Sometimes when things break, they're just never the same again. Plus, it could get a little dangerous if it goes haywire. That's not to say I don't sympathize with you. I think we get very attached to some kitchen supplies that we use most often. For me, a mixer brings back memories of all those years of baking Christmas cookies with my little sister. If you still want a stand you can still search for the parts on these links:
Stand for Bowl 1
Stand for Bowl 2
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Posted on Dec 14, 2009
SOURCE:
My handle on KitchenAid KT26S1X Epicurean Stand Mixer is jammed and won't lift or lower bowl. Can you advise?
I'm not familiar with that particular model but the common cause of that fault on the ones I do work on is a broken or cracked lift lever inside the stand. You need to remove the stand from the motor housing. 4 screws going up through the stand into the underside of the motor casing at the back. That will expose the lift lever mechanism for you to identify the problem.
Jul 14, 2014 | KitchenAid KT2651X Epicurean Stand Mixer
Bowl Lift Mixer does not lift!
well first you shoul read the menual to repair and then call the company and u can replace it.
Jul 23, 2009 | KitchenAid KP26M1X Stand Mixer
The lever to start the machine the one that moves to the right to select the speeds won't move
Are you sure the bowl is locked into place? If it is, also check the safety mechanism that the bowl moves in order for the mixer to turn on to ensure that it isn't broken and is moving as the mixer won't turn on if the bowl isn't turning off this safety feature which is probably broken if the mixer start arm won't move.
Benjamin
Jul 09, 2009 | KitchenAid KSM90 Ultra Power Series Stand...
Have a sunbeam heritage stand mixer model 2346-000.
Make sure the bowl is off to the side. I wouldn't get rid of a mixer just because the bowl doest't, if it's a good powerful mixer. There aren't many replacement parts available except directly from sunbeam. You need to get a replacement motor for the bowl turntable.
Jan 08, 2009 | Sunbeam Heritage 2346 Stand Mixer
I just got a new Kitcheaid Artisan 5 qt stand mixer. i can't get the bowl off of the stand. seems like its too tight, and i can't budge it. is there something i can do?!?!?
These bowls can tighten during mixing. One solution is to fill it with ice while trying to unscrew it. Soaking the base with soap is another solution. In the worst case, the bowl and the cap it fits in are replaceable.
I have had to use a homemade strap wrench on others. Be careful not to warp the bowl out of round, or it will be un-usable.
Oct 22, 2008 | KitchenAid KSM150PS Artisan Series Stand...
Bowl cannot be removed from stand - stuck
Mine is stuck too and it's so annoying. I used terry cloth and hammer the bowl to knock the bowl down (1-2 times and not too hard). I think the bowl is up a bit and over locked when doing bread dough.
Feb 21, 2008 | KitchenAid K45SS Classic Stand Mixer
Need cast iron bowl holder assembly for Hobart A-200
if your looking for the bowl yoke goto hobartcorp.com or call 18884hobart for the part number and price.
Dec 30, 2007 | Hobart A200 Stand Mixer
Food Mixers Logo
15 people viewed this question
Top Hamilton Beach Food Mixers Experts
vince
Marvin
Marvin
Andrew Taylor
Andrew Taylor
Are you a Hamilton Beach Food Mixer Expert? Answer questions, earn points and help others
