Question about Yamaha RX-770
It only plays sound in pure direct mode - Yamaha RX-770
Check if the Jumper at the back is in place its between the Pre out and the mains. I found this out by accident when I was fixing the Selector, I took all the Screws at the back and also removed the the Jumper.After fixing the selector I put back all the screws with out the jumpers, When I was done i Tested it, it only plays in Direct mode. When I put back the two jumpers it worked again.
Posted on Feb 04, 2010
5 Suggested Answers
SOURCE:
  • 71 Answers
SOURCE: yamaha stereo only works on Pure Direct
It sounds to me like an audio enhancement filter is malfunctioning. The pure direct on / off is a sound filter to alter the sound performance of the receiver. There is a rare possibility that there is something wrong with one of your speakers- causing certain circuits in the receiver to malfunction. A way to check for this is to connect only one speaker and an audio source. test each channel first(without pure direct) by connecting the speaker to a channel and then disconnecting it, and connecting it to a different channel repetedly, until you have gone through all of the channels. If you really wanted to pinpoint such an anomaly, then you would need to do it with every speaker through all of the channels to make cetain that this is not the case. But then again this is not very likely. I would personally just use the mode that seems to work, because something is obviously malfunctioning, or possibly burned out. And repairing it is most likely costly! I hope that you can get something out of my answer! sorry! Good Luck!
Posted on Jun 11, 2009
  • 4 Answers
SOURCE: Getting out of Pure Direct mode
One way to solve that is to use your remote. There are modes i the same area - direct mode is one of them. Chose one of the others next to it.
Posted on Mar 10, 2008
  • 151 Answers
SOURCE: Sound is working only in mode PURE DIRECT
TRY PUTTING DVD PLAYERINTO ANOTHER DIGITAL IN PUT, ALSO CHECK DVD OUT PUT IS STILL BITSTREAM.
IFF YOU STILL HAVE A PROBLEM CHANGE THE CABLE,AND IFF IT STILL FAILS 2 WORK TAKE AMP 2 YOUR DEALER.
HOPE THIS HELPS.
CABLE GUY.
Posted on May 20, 2008
ryancsmith
  • 62 Answers
SOURCE: no sound in listening modes except pure audio
Check the input mode on the reciever so that they are set for dual, rather than just digital or analog. It might be set for analog and your using a digital optical in cable. Also make sure DTS mode is turned off, unless your watching a DVD that is dts enabled.
Posted on Aug 06, 2009
What's your problem?no sound
Put your unit in Direct Mode or Pure Audio Mode. If you now have audio in your front right and left channels only then you have a problem with your DSP circuit. If you do not have audio at all, then check your + and - 15 or 12 volt lines. If the voltage is missing then you probably have a bad regulator.
May 17, 2012 | KLH R5100 Receiver
Speaker works for playing of MP3 songs but does not give direction instructions when on purely satnav. Have tried increasing/decreasing volume but no sound comes out of the unit. Have also done a factory...
spoken directions are only available when the computer generated voice has been activated. If you choose any other voice, you will no longer get spoken directions
Oct 05, 2010 | Tomtom GO 730T Car GPS Receiver
No sound from my Pure-Fi Express plus into my 4th gen Nan Ipod
Hi, while your pure express plus you just purchased is not playing out any sound is because, the speaker that enable you to play the sound when you play music through the ipod is faulty and it needs to be replaced with another one for it to function properly again.
After changing the speaker that is faulty with a new speaker, you can now start enjoying the music again through the internal speaker.
Take care.
Apr 14, 2010 | Apple iPod nano
Tx-ds747 no display light,when powering on only stand by mode and the volume knob has light ,how to fix it.
Sounds like the "Pure Audio" mode is turned on. This mode is designed to use the amps power to dedicate to audio processing and sound quality. It turns off all front panel lights and video processing. Check you remote or thr front panel of the Onkyo for a "Pure Audio" button.
Nov 23, 2009 | Onkyo TX-DS747
No sound in listening modes except pure audio and direct. Was working fine and just stopped one day. Connections are all good. Surround sound seems to be broken?
Aug 06, 2009 | Onkyo TX-SR804 7.1 Channels Receiver
Yamaha stereo only works on Pure Direct
Jun 11, 2009 | Audio Players & Recorders
RX-797 no sound output except when "Pure DIrect" button pushed
Here are some things to check:
Is the loudness control turned off or set to a very low level? If the PURE DIRECT button is turned on with the LOUDNESS control level at 0, you won't hear anything.
Have you removed the jumpers from the PRE Out/MAIN IN jacks? If so, the unit will only perform as a power amplifier.
Is the CD DIRECT AMP turned on?
If so, the unit will only make sound if the PURE DIRECT button is on.
Check the CD DIRECT AMP and the PURE DIRECT buttons are both turned off. This should produce sounds. If ti doesn't, check that the A and B buttons are on for their speakers. Both can be on.
Apr 25, 2009 | Yamaha RX-797 Receiver
No sound other than from direct stereo or pure direct. Denon AVR 2808
You can try this reset precedure below, but it sounds like you may have a DSP board problem. This is a new model of Denon, it should still be under Denon's warranrty, it has a 2 year warranty. If this does not help, you need to take it in to be serviced. If it is not under warranty, you will not like the cost of the repair. A new DSP board usualy cost about $300 and then you must pay for the labor. It is not cheap. This reset procedure has been know to work some minor miracles, lets hope it works one for you.
1. Switch off the unit.
2. Hold the following STANDARD button and DSP SIMULATION
button, and switch on the unit.
3. Check that the entire display is flashing with an interval of
about 1 second, and release your fingers from the 2 buttons
and the microprocessor will be initialized.
Note:��If step 3 does not work, start over from step 1.
�� All user settings will be lost and this factory setting
will be recovered when this initialization mode.
So make sure to memorize your setting for restoring
after the initialization.
Jul 12, 2008 | Audio Players & Recorders
HOPE THIS HELPS.
CABLE GUY.
May 19, 2008 | Denon AVR-4802 Receiver
Mar 09, 2008 | Denon AVR-2807 Receiver
Yamaha RX-770 Logo
508 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Colin Stickland
Colin Stickland
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
