Timer does not advance from cycle to cycle
What is wrong if the timer does not advance from one cycle to the next?
  • Washing Mach... Master
  • 8,404 Answers
The clock in your timer is dead for some reason. Replace it. Find parts at a FixYa.com partner or advertiser, your local appliance parts place or at www.repairclinic.com
thanks for your interst in FixYa.com
Please vote
a
Posted on Dec 12, 2009
Whirlpool dryer shuts off at the end of cycle, but timer continues to tick. It ticks through the next cycle and stops ticking at that cycles off?
follow this steps and fix it. God bless you
The timer could be the problem. To check this, turn the timer to a timed cycle say 30 minutes or so then time it. If in 30 minutes the timer hasn't moved and the dryer is still on, the timer is faulty replace it If in 30 minutes the dryer is off, the heating element is your problem
Heating Element
This is the most likely cause for some dryers timer not advancing. Some dryers have two heating elements and if one goes out the timer will not advance if you use it on an automatic cycle but you will still feel heat inside the tub. Replace it.
Oct 01, 2013 | Whirlpool Dryers
Washer will not cycle
The cycle doesn't advance When the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
  • It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer.
  • It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
Oct 24, 2008 | Kenmore 15864/15862 Top Load Washer
My Kenmore washer will not move into the next cycle unless I manually turn it to the next cycle. This just began today. What is wrong with it?
It's either the timer is faulty or the lid switch is broken. If it fills and agitates but dos not spin and drain it's the lid switch. If it spins and drains when manually advanced to that setting your timer is bad.
May 18, 2011 | Kenmore Washing Machines
My Sears washer Mod. # 110.28822791 SN CJ1904857 will not advance to the spin cycle. I replaced timer part # 3950200. It works intermittently. You have to move it to the spin cycle and then it will...
If you replaced the timer with a new one make sure its the right one with its part number listed on it if its the wrong one it wont work right. sounds like a power problem or clock problem with the timer might need a qualified service technician come look at it to rule the problem out hope this helps.
Jan 06, 2011 | Kenmore Washing Machines
My washer runs non stop on the wash cycle...it washes the clothes but doesn't past the wash cycle...doesn't drain, rinse or spins. What can I do?
Can you manually rotate the timer control to the next steps?
Will it proceed thru the cycles when you rotate the timer manually?
If so, then you can complete the cycle manually for the time being...
If so-- then the clock motor that drives the timer.control is not advancing it.
If yours is a newer machine with all digital controls, then I suspect something wrong in that controller, too-- But I do not have any idea of how to 'advance it manually!
(The blessings of modern controllers!-- Give me the old clock motor driven drum controllers! :-) )
Mack B
Dec 28, 2010 | Washing Machines
Washer will not move to next cycle; has to be done manually
It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer. Hope this helped.
Jul 16, 2009 | Washing Machines
TIMER ON WASHER MAKES A TICKING SOUND DURING CYCLE
HI, this timer is faulty and, these are early warning signs of potential failuer of this device in the near future. i would prepare to replace the timer control soon. the actual mechanism is showing signs of breakdown.
May 23, 2009 | Amana 3.2 cu. ft. Top-Load Washer
Not running through cycle
Good Luck!!!
May 06, 2009 | Indesit WA 115 Front Load Washer
Frigidaire washing machine gets stuck on cycles
Apr 01, 2009 | Frigidaire Washing Machines
Washer fills with water but does not advance to next cycle
If this is a rotary timer, nudge the timer slightly in it's normal direction of rotation. If the timer keeps going (it might hang up at the next point in the cycle, but nudge it again), I suspect the timer needs to be replaced. They get weak.
Jan 29, 2009 | Washing Machines
Washing Machines Logo
21 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
Marvin
Marvin
