No picture, but sound on tv channels and dvd player....No picture
  • 11,896 Answers
Could have a faulty picture tube, or CRT. You can get a service manual and test the componenets with an ohm and voltmeter to see which one is faulty. Placing a probe on each solder connection to test the continuity of the component. It will have to be safely discharged before replacement. You can get parts at tigerdirect.com
Posted on Dec 12, 2009
My I got sound but no picture on my DVD player
There are three coloured leads on the back of a DVD player if you use composite video - Red is Right channel sound, white is Left channel, yellow is video.
Red from DVD right output to TV right input
White from DVD left output to TV left input
Yellow from DVD video out to TV video in
Sep 03, 2012 | KLH DVD8350 DVD Player
I still have sound but get no picture on my DVD player
Chances are, that as in the issue with no sound/picture post, the Tv is the issue...dont fret, just refer to owners manual of tv, and verify which component/hdmi/s-video hookup it is and make sure you choose appropriate one on TV input setup. for more information refer to post of no sound/picture.
Aug 02, 2010 | Coby DVD-937 5.1 Channel DVD...
Just moved, hooked up DVD player to new TV. Sound
if you have a picture on the tv from normal channels and/or cable, then i would suspect the scart lead may have a bent pin at one end or both or is not inserted fully.
Feb 20, 2010 | GPX D1816 DVD Player
Tv works great, dvd is new , cant figure out the right hook up , dvd has 3 cables white yellow red
Red = right sound channel, white = left sound channel and yellow = video (picture) channel. if you have the connections matching these on the tv, then there should be an AV channel on the remote/tv control panel. Select this channel to view, if more than one AV channel on the tv, there will be a number next to the sockets you plugged into. Select the AV number and away you go.
If your tv doesn't have the correct sockets you can buy a converter to use the ariel socket on the tv.
May 28, 2009 | Televison & Video
DVD/VCR picture (and sound) are not on tv screen
Try setting the TV to AV1 & see if the dvd picture appears.There should be a button on the remote to change TV/video. Hope this helps.
Dec 24, 2008 | Sony SLV-D300P DVD Player/VCR
How to change from tv to dvd mode
the difference between tv and av, is that av has no showers on the screen. if you change to av you will notice a blue screen, connect your yellow on vedio output and white/ red on audio out of tv
note- before connecting to a vedio touch a tip of your vedio cable some lines will show on your screen, if touch your audio tip harming noise will sound on your tv. if this two happens then you know that your cables are okey. hold your channel button on your tv, channel will start runing after all rf channels finish, tv will go to av.
Oct 13, 2008 | Sony DVP-NS50P DVD Player
Need help setting up DVD-VR375 with compatible SAMSUNG TV
if it has component (red, blue, green) cables, plug one set into dvd player's "in's" and tv sets "out's'. you may have to play with the tv channels to be able to watch movie. you just change channels, go from "3" backward until you find a picture and sound.
Sep 01, 2008 | Samsung DVD-VR357
Sound with no picture
the problem is in the backlight try to measure the supply.and replace the inverter.
Dec 05, 2007 | Toshiba LCDTV/DVD Player 19HLV87
No picture/sound on tv after connecting standard dvd player and inserting dvd
how many av inputs do you have on that tv? is it more than one? make sure you choose the right input. if that is not the problem then you are having a problem with av section in the tv I suggest that you take it to a repair man to get it fixed or you can use the RF cable to connect it to your tv. it is not the best but is saloution to the problem..good luck
May 13, 2007 | Daewoo DTQ-25S2FC 25" TV
Televison & Video Logo
152 people viewed this question
Top Televison & Video Experts
