Question about Maytag Refrigerators
My maytag washer model a608 is leaking under the bottom?
4 Suggested Answers
SOURCE: leaking fridge
Its probably the defrost circuit either the heater or the timer
Posted on Oct 30, 2007
my maytag had cloged defrost drain cleaned drain all ok
Posted on Jul 03, 2009
arikrom
  • 528 Answers
SOURCE: Model PTB1953GRO Maytag Refrigerator-Water drips into
you might need to open the freezer wall and clean the drain hole.. it might be cluge... very EZ :)
take all out even the ice maker unit
take back wall out and see if the drain is cluge with ice or something...clean it and out it all back
Posted on Dec 31, 2009
Maytag clothes washer model 2500 aae leaks along bottom edge
Sounds like a hose leak inside the machine. Possibly remover front bottom cover then check all hose connections.
Nov 14, 2013 | Maytag Washing Machines
My washer is leaking water from under the washer. what could the problem be
my washer is leaking water from under the washer
model #: MAH5500BWW SERIAL #10760798YY
Mar 02, 2010 | Maytag Neptune MAH5500B Front Load Washer
I have front loader MFW9700 Maytag washer. Water
Check the door seal for tears and the drain boot from tub to drain boot for anything that might have put a hole in like a piece of metal from an under wire bra which front loads will spin so fast that the wires come out of the bras.
Feb 01, 2010 | Maytag EPIC MFW9700S Front Load Washer
Maytag Model...SAV205DAWW leaking water at bottom
there could be 2 things that i know of
first one is that someone bended the door to much and the joint's are eather lose or out of place
the second thing is that the door sealing rubber is out of place, you need to putt it back to place
Dec 27, 2009 | Maytag SAV515DE Top Load Washer
Washing machine is leaking from bottom of machine
Wow, this washer is very old. im sure the drainage hoses will need to be inspected or replaced asap. i would also check the pump housing for cracks as well. make sure the water inlet valve assembly ins in good condition as well. Replace any hose or valve that is leaking or, damaged.
Jun 05, 2009 | Maytag Washing Machines
Oil leak from bottom of maytag neptune tl - about 4 years old
sounds like seal leak in tub water is leaking onto drive unit and washing over it bring and oil it can with it couls be big bucks some parts may be under warranty call service but be sure to get estimate first
Nov 27, 2008 | Maytag Neptune FAV6800AW Top Load Washer
My daughters maytag has water leaking from the bottom.
Check the easy stuff first, fill hoses tight?- drain hose cracked?
Failing those checks, cut a piece of cardboard slightly smaller than the size of your washer. Slip the cardboard under the washer and run a short load. Look carefully at the water mark on the cardboard. The mark on the cardboard the water leak will leave, will help you tell from which side or front to back the leak is common from. This will help point you in the correct direction to look for the trouble maker.
Nov 25, 2008 | Maytag PAV2300 Top Load Washer
Washer transmission & brake bad - replace or not?
kenmore elite washer,but first if you want to try to fix it yourselt look on ebay,put make and model number and see what comes up,i got a new transmission for $70 took my time taking apart then reassemble and it was pretty easy,let me know how you do-mike
Oct 23, 2008 | Maytag Atlantis MAV6000 Top Load Washer
Refrigerators Logo
139 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
Marvin
Marvin
Carlos Alvarez
Level 1 Expert
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
