Question about Razer DeathAdder RZ01-00150100-R2M1
Hello, i wanted to know how to clean a Razer Destructor gamepad
  • 21 Answers
What you should do is take hot water and a old anti static cloth"The ones you clean your screen with"and just make the cloth damp and wipe the pad in one direction just incase of scratching it...if you want to dry it use the same but dry cloth and you should be sorted out...with no scratches or anything to your game pad .
Posted on Jan 06, 2010
I cant move my razer naga mouse top and buttom
Try cleaning the lens with some Windex or any other cleaning spray. Not too much, you don't want liquids in the mouse.
May 20, 2012 | Razer Naga MMO USB Laser Gaming Mouse -...
I need a manual for a model 1600 mouse
You could try
operatingguides.com
if you need a user manual
or
servicemanuals.co.uk
if you want the schematics etc
We've used them in the past and found them very good.
Also if it is not listed then ask via the link and they
will probably be able to get it for you.
Jul 07, 2011 | Razer Diamondback Mouse
I need replacement keys for my razer lycosa mirror keyboard
They best thing to do is try to find a broken one on Ebay, they run around $24. I did a search for websites that sell just the keys and couldn't find any. You may be able to steal a key off another type of keyboard, but without knowing the type of mount your keys have I can't be positive that will work. The Lycosa Gaming keyboard, or any specialty gaming keyboard, will be very hard to find specific parts for.
Also, check too see if you have a keyboard withing the serial numbers posted on this website. It looks like they are recalling and replacing some of the keyboards they sent out due to defects.
Link: http://www.techpowerup.com/index.php?85841
Mar 24, 2011 | Razer Lycosa Gaming Keyboard
Hello There. Just bought a Saitek P380 Dual Analog PC Gamepad. Says on the box Certified for Windows Vista - Can it be used with Windows 7? Thank You. Billy.
I have not had too many problems with using stuff for vista on 7...If you want you can go to the microsoft website and see if your hardware is on the HCL(hardware compatibility list)
Jan 03, 2011 | Saitek P380 GamePad
I have a logitech gamepad gamepad that i want to
WW3 has begun.........
None the first and only.
Jun 20, 2010 | Logitech ChillStream Game Pad
8985 360 conplete. I got a new charger & cleaner base. Unit chargers and full lights comes on. Cleaning cycle lights does not work or clean. This is third new base i tried. I think truble is razer. I...
the razor is warranted for 2 years if you want to contact Braun for replacement. You can try to tap the razor with the palm of your hand after taking off the shaver top and blades. Sometimes this will help dislodge anything that is keeping the shaver from making good contact inside razor.
Just don't beat it against anything hard.
Oct 29, 2009 | Braun 360° Complete 8985 Electric Shaver
Gigaware controller on vista
You don't (and can't) disable DEP for the controller (a gamepad controller isn't an application, it's a device which uses a driver, Data Execution Protection applies to applications ie .exe files), it's the game or emulator you disable DEP for, so that you the game can run, completely free of security bindings, and then you would be able to go into the game configuration menu and select your gamepad, and calibrate it. Calibrating means the game detects you gamepad and applies the specific functions to each button.
One way to be sure is to disable DEP for everything, then install a game, and THEN plug in your gamepad. Then start the game/emulator and go to the configuration menu within the game/emulator and set up the gamepad calibration in there.
If it doesn't work, then you haven't installed the drivers for the gamepad properly, or haven't installed the correct driver.
Before doing any of that, you would have checked in Control Panel and Gamepad Controllers, double clicked the Gamepad in the list and pressed Calibrate, to enable generic gamepad functionality.
If you hadn't done that, do so now.
If it still doesn't work, then NOW disable the DEP (either all DEP or for the game/emulator you want to play). Unplug the Gamepad and load up a game. Then plug the game pad in. Set up the gamepad from within the game/emulator config menu, which differs from game to game, of course, but is more or less the same.
If it doesn't work.. re-install the correct driver for the gamepad.
Also make sure your operating system is fully updated and you're plugging the gamepad into a usb2.0 port. and have rebooted after installing the gamepad usb driver.
That's everything you need to know..
Good Luck!
Chris (ziraffa)
Dec 27, 2008 | Video Game Consoles & Games
Configuration with windows xp
eash game sums offer controler suport sum dont ok one that do go in menu select losgitch gamepad should auto config it self for that game ok
Jan 23, 2008 | Logitech Dual Action for Pc (963292-0403:)...
Razer Diamondback
under the big plastic slide of the mouse theres a screw you just need to take out .. then gently pop it open the bottom end and pull it back.. DON"T TRY TO PULL IT OPEN COMPLETELY.. there is a little hinge that holds the top 2 buttons in place. just pry open the lower end and gently pull back.
Oct 31, 2007 | Razer Diamondback
Razer DeathAdder RZ01-00150100-R2M1 Logo
2,007 people viewed this question
Top Razer Computers & Internet Experts
Alun Cox
Sunday Ojelabi
Sunday Ojelabi
Larry Chandler
Are you a Razer Computer and Internet Expert? Answer questions, earn points and help others
