Question about Panasonic Palmcorder PV-DV102 Mini DV Digital Camcorder
My camera shuts down whenever I try to record to the video tape or switch to the camera position on the camcorder.
  • jnjacks1 Dec 12, 2009
    Yes the batter connects are clean.
  • 11,896 Answers
Either there is an internal faulty component such as overheated capacitor, bad chipset, or you could have a bad ribbon cable or connection from battery to main circuit board. They do get brittle and become loose.. How good does the battery hold charge? Are the battery contacts clean?
Posted on Dec 12, 2009
Camcorder shuts down when trying to record
Your battery is not holding the charge. Buy new battery for the camer and charge it up.
Dec 12, 2009 | Panasonic Palmcorder PV-DV102 Mini DV...
Sony camcorder has knocking noise in recording or playback
Try using tapes of different sizes. a big tape may be exerting stress on the mechanism
Feb 27, 2009 | Sony Handycam HDR-HC1E HDV Digital...
Video recording shuts down after 15 seconds
I just looked at my Sony DCR-TRV30. Not the same, but perhaps similar. My camera records lengthy videos on tape and only brief videos on memory stick. I suggest that you stick to tape for video.
Good Luck
almarc13
Feb 12, 2009 | Sony Handycam DCR-TRV730 Digital Camcorder
I CAN'T OPERATE MY CAMERA
Condensation is usually a result of a change in temperature of your camcorder. Like taking it from a warm house and shooting outside in a chilled environment. Or taking the camcorder that was in the car in a cold environment into a warm house. Condesation will make the tape stick to the revolving video head and the camcorder has sensors that know this could be a very bad thing for both the camcarder and your tape. So the camcorder shuts down. The tape also needs to be at the same temperature as the camcorder or temperature differences will create condensation between the tape and the video head.
Eject the tape. Shut off the camcorder and leave it in a room temperature place for a day. Then give it a try.
Dec 12, 2008 | JVC Cybercam GR-D70 Mini DV Digital...
We are in the middle of a production (Live, right now) and one of our XL1's is shutting down whenever we hit the record button.
It may be timing out. Is the camera in standby mode? If yes, put it in record and lock.
I have an XL1 and a GL1 that sometimes shuts down. Is there a tape in the camera? It will time out sometimes if there is no tape rolling. Even if I am capturing directly to a computer, I always roll a tape, just to keep the camera from timing out.
What does your battery guage read in the viewfinder? A low battery will shut you down without warning. Try running from the power adapter if you have one.
Dec 06, 2008 | Canon XL1S Mini DV Digital Camcorder
Tape eject door will open but tape will not eject
got door open and looked in and saw what looked like the tape head sitting very slightly proud of tape and believe it or not inserted a very thin and pointy bladed knife up as far as the head then pressed it down on top of the head very lightly and the head slid down its shaft to its original position switched camcorder back on and tape then ejected as per normal and it has worked normally since and as i did'nt touch the head (face?) no damage was done and it can record and play with no problems, a little unorthodox perhaps but it worked for me and saved me a probable fortune
Apr 09, 2008 | Samsung VP-D361 Mini DV Digital Camcorder
IN CARD POSITION
A properly functioning camcorder will report this if it has both a card for recording and a tape mechanism for recording, with a switch set "in card position" when you press the movie mode record button. If you have a camcorder like this, look for a button marked "photo" that is used specifically for snapping still photos.
May 18, 2007 | Canon MV530i Mini DV Digital Camcorder
I can't start recording.
# You may not have turned on the camcorder to record properly. For camcorders that feature both Automatic and Manual recording, make sure you press in the LOCK button while setting the POWER switch to the desired setting, either "A" (Automatic) or "M" (Manual) record mode. # Automatic recording places the camcorder into Auto Shot™ mode, while Manual recording mode allows you to control many of the camcorder's special features, including accessing the menus and setting the clock. # For many other camcorders, make sure the CAMERA/OFF/VCR switch is set to CAMERA. Make sure the Erase Protection tab is in the position that allows recording. If not, slide the tab. Some tapes have removable tabs. If the tab has been removed, simply cover the hole with adhesive tape or use another tape.
Sep 06, 2005 | RCA CC-432 Camcorder
Panasonic Palmcorder PV-DV102 Mini DV Digital Camcorder Logo
46 people viewed this question
Top Panasonic Video Cameras Experts
Kenneth Walker
Pieter Vleeshouwers
Pieter Vleeshouwers
Marvin
Marvin
Are you a Panasonic Video Camera Expert? Answer questions, earn points and help others
