Question about Endurance T3 Treadmill
I have a Trotter 535 treadmill. I need to turn
I have a Trotter 535 treadmill. I need to turn the surface under the belt over. I can't find a repair manual. Anyone Please. Thanks
  • Anonymous Mar 12, 2014
    I need owner's manual, urgently. How Can I get it?. I'm from Guayaquil, Ecuador
    New Friend:
  • 3 Answers
Visit wefixfitnessequipment.com and I will tell you how to flip the deck, tighten the belt and where to get lube. If you are planning on flipping the deck make sure you lube it with the right kind of lube!
B. Clark
Trotter/Cybex certified technician
15 years exp.
Posted on Oct 20, 2010
My trotter 510 treadmill doesn't turn on and just gives off this high pitch sound when turned on
oh, the trotter treadmill that is a workhorse of a treadmill. Question doubled edge. does it start?? or it does not Start. the sound if it does turn on may be coming from the motor which may need new brushes. Trotter is now Cybex fitness. they will have a part to make the repair
I’m happy to help further over the phone at https://www.6ya.com/expert/howard_079189dd4959a511
Oct 12, 2017 | Exercise & Fitness
Tip
How To Re-Wax a Wood Deck for a Trotter Treadmill
Following are instructions on how to re-wax a wood deck for a Trotter treadmill and a list of materials needed for this procedure
Materials Needed for Re-Wax
  • 1 lb. of Trotter deck wax
  • Clothes iron (never to be used on clothing again)
  • Belt sander with 120 grit sanding belt
  • Vibrating sander with 250 and 400 grit paper
Pre-Existing condition: If your wood Trotter treadmill deck is worn down through the first ply, it cannot be re-waxed.
  1. Using a belt sander and 120-grit belt, gently sand in the same direction as the grain the glazed layer off the top of the deck until you have reached porous wood. If, while sanding, the first layer of ply has been sanded off, the deck can no longer be re-waxed
  2. Using a vibrating sander with 250-grit paper, sand the entire top surface of the deck until it is smooth and soft.
  3. After sanding with the 250-grit paper, continue sanding with 400-grit paper until completely smooth.
  4. Heat the clothes iron to its maximum temperature. Put a handful of Trotter deck wax on the center surface of the deck and place the preheated iron on top of it until the wax melts.
  5. Work the wax into the deck surface by pushing the melted wax across the deck with the iron. Add more wax as needed until the entire top surface of the deck is impregnated with wax.
  6. Apply just enough wax until the wood is saturated with wax.
Do NOT leave wax pooling on the surface of the deck.
How To Re Wax Wood Trotter Treadmill Deck
on Mar 11, 2015 | Exercise & Fitness
Cybex 520t error 6
Replacement Parts for Fitness Exercise Equipment at SPORTSMITH
Error 6 is a motor over voltage error. Motor voltage exceeded 200 VDC for 200 milliseconds. This can be caused by a worn deck and belt due to a lack of routine maintenance. AKA adding wax between your deck an belt. You might be able to wax your machine and make the error go away. More than likely a new deck and belt will be needed. Using the link below and your model and serial number, you can find the needed items. In worse case scenario, you may also need a new motor control board.
Repair Parts for Trotter Cybex Treadmill 400T 410T 500 Series SPORTSMITH...
Apr 07, 2014 | RTO Cybex 520T Remanufactured Treadmill
Lubricating walking belt
Video about How to Wax a Treadmill Using Powder Wax
How to Wax Treadmill Using Powder Wax Video
Video of How to Lubricate a Treadmill using Liquid Lube
How to Lubricate Treadmill Using Liquid Lube Video
Apr 02, 2014 | Exercise & Fitness
Cybex 530t error 6
Jan 20, 2014 | Exercise & Fitness
I have trotter 535 - the following comes on the screen: error 4 - AC line freq out of spec - does anybody know the fix.
Error 4 is a no frequency lock or noisy line voltage. The most common fix for this to install a dedicated outlet. This is required for most treadmills out there.
Jan 08, 2014 | Exercise & Fitness
Trotter 535 treadmill auto start and stop
1) Lube the Deck belt, very well according with your instruction manual maintenance.
2) Lube the rollers bearing too
3) Measure the input voltage motor, if there are The motor need repair.
4) Measure the output voltage board, for input voltage motor, if there are NOT the board is faulty. God bless you
Jun 08, 2012 | Exercise & Fitness
Endurance T3 Treadmill Logo
1,097 people viewed this question
Top Endurance Exercise & Fitness Experts
Howard
Howard
Tom Chichester
Techmotionusa.com
Techmotionusa.com
Are you an Endurance Exercise and Fitnes Expert? Answer questions, earn points and help others
