My philips vcr/dvd shuts itself of after 3-4 seconds - won't play, let me reset clock, OR eject my tape. I've only used it a few times in 2-3 mos, with no problem before. Remote works, no other electronic problems with the old-school tv/vcr/ converter box/antenna system. As usual, no help from the manufacturer. Any ideas? thanks
  • kkaand Dec 12, 2009
    I'm apparently in over my head. 1) would this still allow the machine to turn on, and 2) is ita fixable issue/at what level of repair? thanks...
  • 10,515 Answers
Sounds like problem in the power supply. 1.check the connection from the starting point. 2.Check the voltage fluctuations. 3.Check for power overload. 4.Check for loose contact for in the external power supply. 5. Try plug in the power from another plug.
You need to open the Player and get the Fuse, Circuit and make sure nothing is burnt and the capacitors are not swelled.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Dec 13, 2009
  • 11,896 Answers
Very likely you have either an overheated and burnt out capaictor, or a faulty power supply/voltage tranformer. You can test it with a voltmeter to see if there is power from supply to main board. It is common.
Posted on Dec 12, 2009
  • Nate Stansfield
    Nate Stansfield Dec 13, 2009
    This requires a bit of electronical knowledge. You will need to use an ohm and volt meter to find the faulty component. Then you will have to buy a discharge tool to draw out the rest of the power that is inside. Then solder off the old piece and order a new one, and install the new one, and then adjust the new one. It is quite a bit of work, and you really should have a repair/service manual for your specific tv.
SOURCE:
Our Toshiba VCR won't play tape. It ejects tape after a few seconds.
If you are trying to play older VHS tapes, you may have to run them through some fast forward-rewind cycles to condition them and relieve stress
Jul 20, 2013 | Toshiba D-VR4 DVD Recorder/VCR
I have the Philips DVP3150V/37 DVD Player / VCR Combo. The DVD player works fine, but when putting in a VCR tape, it plays for a few seconds then shuts itself off. Any suggestions on what to to?
The 3150 has two belts or bands that can slip when old, just like the old days. One is for loading the cassette and the other is for providing take-up torque for the tape. Have also seen the tape loading arms get out of sync and don't put the tape around the heads..... working on one now but dont have a fix yet..it has the loading problem.
Nov 01, 2011 | Philips DVP3150V/37 DVD Player/VCR
Power goes off when a cassette is inserted. Tried cleaning heads but it won't even run that. When power is turned back on the cassette is immediately ejected.
Good day!!!
Most common problems
  • VCR refuses to FF or REW and shuts off.
  • VCR shuts off entering PLAY or REC or at random during PLAY or REC.
  • VCR eats tapes.
  • VCR doesn't accept tapes or ejects them without cause.
  • Sound is wavery, fluctuating, or muddy.
The cause for all of these is very often a bad idler tire or other dirty, worn, or tired rubber parts
Sep 12, 2011 | Philips Magnavox DVD/VCR Dual Player
System will not eject video tape and is locked
This unit is confused. The timing may be messed up. Try unplugging the unit for 1/2 hour. This will force a system reset and make the unit go through a complete startup check/reset. This may clear it up. If not, hopefully the symptoms will change slightly. Please post the results of the "reset".
Thanks,
Dan
Nov 03, 2009 | GoVideo DVR4000 DVD Player/VCR
Vcr/dvd combo, vcr no longer will play tape, when I press play, after a few seconds will eject tape.
Hi
Thanks for using FixYa. Please check the eject mechanism and the drive motor connected with the tape mechanism. Try and align the drive motor. Also check the push-pull arm of the tape mechanism and make sure that the springs connected with the mechanism are fine.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Sep 15, 2009 | Philips Magnavox DVD/VCR Dual Player
Magnavox zv450mw8 Walmart VCR/DVD recorder. shuts off
on vcr's if the tape is hard to turn the tape will sense this and reject the tape. Try to get a tape that you can feel turn free eaiser. I would rewind it to the middle of the tape so each side is equal and it would make the tape run easier. If it runs ok then the unit is bad and is too sensitve to the pull on the tape. This is all designed in the electronics and there is not much you can do about it then get return it if you can.
Jan 01, 2009 | Philips Magnavox DVD/VCR Dual Player
T.v. ejecting vcr tape and turning self off after being turned on
If VCR mechanism doesn't load or unload properly, TV will shut off. VCR machnisam in your TV requires cleaning/ service. Spacialy belts and pulleys.
Jun 22, 2008 | Philips Magnavox DVD/VCR Dual Player
Philips DVP 3150V
saida horizontal com deficiencia faz com que a fonte aciona circuito de proteção.
Feb 09, 2008 | Philips CCB092AT 9 in. TV/VCR Combo
What do I do when my Emerson TV keeps turning off by itself?
I had the same problem with mine turning off after 3-5 seconds. After much research I found a suggestion that on some combo units the vcr part could have a power supply cutout if it is not working correctly. I tried to insert a tape and found that the tape mechanism would not accept a tape. I used a little bit of force and managed to insert a tape. I then played the tape forwards and backwards and the power stayed on! I ejected the tape and found the TV then worked just fine. The power has now been on for over one hour. I hope this give you another avenue to try and fix your problem.
Nov 30, 2007 | Televison & Video
Televison & Video Logo
21 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
