Question about Apple Mac mini G4 Desktop
7 month old mac mini freezing & being slow
in the last 2 weeks, my 7 month old mac mini has been acting very weird.  When I start it up first thing, it has the spinning ball for several minutes and is very slow when it does start working.  I emptied all my cache today, so am wondering what else to do.  I don't run FCP or any softwear that did not come with the mac, so am a bit concerned.
  • Beameup Jan 20, 2008
    I have alot of photos in my iphoto library, could this be what's making everything haywire?
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 35 Answers
Generally there are a variety of reasons that can consequently cause the freezing or slow issues on your Mac. Meanwhile, there are certain ways through which you can do to fix one by one. However, if you prefer a more efficient way to resolve, try an all-in-one Mac speed up software as it can help resolve all issues in just a few clicks. Learn more: http://www.howtospeedupmac.com/
Hope this helps!
Posted on Sep 04, 2012
  • 667 Answers
Try running the disk tools. It is in your applications folder under utilities. The portion of the disk tools program you want to run is 'repair disk permissions'
Posted on Jan 21, 2008
Several months ago my Mac Mini G4 stopped recognizing both the internal hard drive and the optical drive. In the system profiler nor Disk Utility nothing is recognized under the ATA bus. I have been...
Hi, has this mini been opened up to add more memory?
I would suggest that before you conclude that the ATA bus is damaged, open the mini up and see if the ATA connector is still connected to the motherboard. (It's the same connector for both drives).
Dec 14, 2009 | Apple Mac mini G4 Desktop
I have a mac mini osx10.4 with a 512N syncmaster samsung monitor. The monitor worked fine for 2 years and up till the last month while I am on the computer the monitor will go black with a message saying...
samabbott, Toni, The very first thing to check is Samsung warranty.. If not valid you will need to check and see if Samsung has a cash+old unit swapout program for refurbished same model??? Will this 512N do same thing if connected to different pc? If so, then I would suspect the unit's power supply. Whenever strange or weird stuff starts to randomly take place with an LCD display, I would first check the "switch-mode-power-supply"! Have you tested the pc with different Known Good lcd unit? Try the above stuff and report back with a new comment. 12fixlouie
Nov 17, 2009 | Samsung SyncMaster 512N 15" Flat Panel LCD...
Macbook fans high speed always
Hi, this can come form a lot of things, harware or software related. Software related: The easiest solution would be to backup your data and do a "clean install". hardware related: the easiest solution is to test your hard drive using the disk utility, and repair it if needed. If you have added extra memory, take it out to be sure that they are not the cause.
Jun 10, 2009 | Apple MacBook 13"White /2.0Ghz Intel Core2...
My dryer is acting weird
your dryer motor is no longer strong enough to turn the drum,how old is the dryer?mike
Apr 04, 2009 | Kenmore Dryers
2000 s10 starter last only 2 months,
I would check current draw with a good ammeter & se how much current the starter draws when cranking. I owuld guess about 400 amps, but check with Delco. Other possibility is starter is binding on flywheel.
Did you disassemble one of the faulty staters to see if armature is rubbing on magents or coils?
Are these starters remans or new? Remans sometimes have problems.
Mar 23, 2009 | 2000 Chevrolet S-10
Scattered movement
Try using the mouse over a plain white sheet of paper and see if this helps.
Nov 06, 2008 | Logitech Cordless Optical Mouse for...
Mac Mini G4 Flickering Screen at Start Up
Did you check the wires?  Sometimes if you pull one loose it flickers.
Aug 13, 2008 | Apple Mac mini G4 Desktop
Keyboard works then doesn't
take the phone and have it service then if that does not help the issue take it to a mobile service center and have them reflash the keypad with the flash file.
Aug 28, 2007 | Motorola Mobility RAZR V3
W375 is acting weird
I have motorola w375 mobile but in this mobile How use data cable or usd drive on this mobile
Aug 28, 2007 | Motorola Mobility W375 Cellular Phone
Apple Mac mini G4 Desktop Logo
568 people viewed this question
Top Apple Computers & Internet Experts
Paul Carew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
