Question about Angelcare Baby Care
Hand held monitor not working
My monitor that i carry with me isnt recieving a signal from the bedroom monitor. the bedroom monitor is working fine. this has happened all of a sudden... help!
    Problem Solver:
  • 9 Answers
Sounds like the units need to be paired. Start with all units off. Then turn on one of the parent units. Press and hold the menu button until it beeps. Quickly turn on the nursery unit and press and hold the button on the nursery unit that has the parent unit icon below it. After a couple of seconds the units will pair. Repeat this process with the other parent unit.
Posted on Dec 29, 2009
Testimonial: "Thanks! "
I have 2 alba tv/dvd combi's.1 in kitchen & 1 in bedroom.After digi switchover 1 in kitchen is fine after re tuning.The bedroom tv only has a few stations after numerous re tunes.Both work off
The one that does not work: have you tried to unplug it for a while from power and plug it back to see if it will reboot and allow you to program?
Apr 08, 2012 | Televison & Video
My monitor wont recieve any signal from my computer
sir your monitor's VGA cable is not fine replace it and it will work fine get a new VGA cable from market and replace it then it will work fine.
Thank you
Mar 31, 2012 | Think Computer Computers & Internet
I have anrca hdtv model # R56WH76 and I don't know how to set it up with my cable. I have the dish network box in the living room but this rca tv i have in my room with the cable coming out from the...
To watch Dish Network in your room there a couple of different ways to do it. Unless that cable coming out of your wall is connected to a Dishnetwork reciever its useless.Now if the reciever in your living room is a dual tuner dvr than you can run a cable from one of the two outputs to your bedroom. In this scenario you can watch different channels at the same time. If it isnt a dual tuner then you can actually put a splitter on the cable coming out of the box to the tv(has to be on cable coming out of the reciever) and run it to your bedroom. In this scenario both tvs will show the same channel.In both cases you need a UHF remote(dual tuner DVRs come with one UHF and one infrared) that will allow you to change channels while in your bedroom. If you want HD programing on both tvs you will need to contact Dish Network to get a second reciever. its $7 more a month for a second reciever.
Dec 19, 2010 | RCA R56WH76 Projection Television
I have 3 of them, and when i use my remote control for one bedroom ,at the same time it starts working the other fans in the other bedrooms
The code switches are very small two position slide switches. Start with one fan and open the handheld fan controller. You will see the small slide switches that set the code, they may be in the battery compartment and do not look like typical switches. However you set the code on the hand held, you need to set the same code on the fan itself. The switches on the fan are usually in the motor cage and will look very similar to the hand held switches.
Set new codes in one fan and set another code on one of the others. The third fan should be fine. Please message me if you have problems doing this.
Oct 01, 2010 | Hampton Bay 04078 Avanti Ceiling Fan
Lost video signal to monitor (TV)
I had the same problem - Onkyo had me reset the unit by holding down VCR and pushing the power button. Make sure you record your settings before doing this - as the unit will be fully reset. This solved the video problem for me.
May 26, 2010 | Onkyo TX-NR905 Receiver
Monitor not recieving signal?
If you are really sure that your monitor is working, then you would probably have to change your graphics card with a working one to see the results. That should solve your problem. If this does not solve your problem, then we are not dealing with a display problem here. In this case, you may have to check your memory.
All the best.
Jan 13, 2010 | EPoX EP-8KRA2+ Motherboard
Receiver taking a long time to transmit reciever
I assume that the HDMI works fine if you go directly from the dish receiver to the TV with either HDMI cable. And try it with a different source (DVD or x-box) in the same input port.
Take it to a Radio Shack there service centers can repair Onkyo in warranty. Most Onkyo receivers carry a two year warranty.
Nov 18, 2009 | Audio Players & Recorders
I pluged my monitor in it worked fine but today its showing no signal monitor still works but my card isnt giving a signal
throw your card out of your pc if you dont have the warranty and buy a new one
its over...................
Mar 02, 2009 | Nvidia G-Force FX5200 256M DDR 8X AGP...
All four hand held systems failed
check out override frecq see if you can change transmit and recieve switch settings ie dip switch sets sombodys overiding your freks
Dec 17, 2008 | Sennheiser Evolution G2 100 Series UHF...
Setting up home stereo/receiver
One of the shortfalls of recievers is there's no line outs from anything before signal gets to the amplifier because the amplifiers built in. This is a longshot......... but if you could hook up the eq to the tape in/ outs then send signal from cd, radio, whatever, to tape and can monitor the tape return ( if the reciever has a tape monitor button ) then it may work.
Aug 05, 2008 | Audio Players & Recorders
Baby Care Logo
1,088 people viewed this question
Top Angelcare Baby Care Experts
masud
masud
Tom Chichester
Bill Boyd
Are you an Angelcare Baby Care Expert? Answer questions, earn points and help others
