Question about Frigidaire FEX831F Top Load Stacked Washer / Dryer
I am replacing the washer timer and do not unserstand how to remove the front dial knobs FEA831FS
    President:
  • 704 Answers
Hello HmKm, You should be able to just pull the knobs straight off the control stems. Once you have them off, there are a couple of screws on the angled section just above the washer lid. Remove them and you will be able to access the washer controls.
Before you go working on the parts, to remove the control timer, please unplug the stacked washer/dryer combo and turn the water offl. Now you can remove the two screws (that are behind the timer knob) to free it from the metal control panel. Depending on your model, there might be another mounting strap inside the unit that holds the timer in place. If so, remove those screws and you shoud be able to drop the timer down and remove the wiring connection plugs and take out the faulty timer. Now simply push the wiring plugs onto the new timer and reinstall.
Close everything up, reversing the procedures above and turn the power back on and the water and you should be able to use the washer/dryer as normal.
Hope you find this Very Helpful and best regards!
PS: I was one of the folks that was trying to conect with your request for a live chat, but the system wasn't responding, so I aplogize for that technical glitch. Anyway, this is what I would have provided you during the chat session, so best of luck to you in undertaking the repairs.
Posted on Dec 12, 2009
I want to replace a timer on a Whirlpool washer Model# LSN1000KQW
Good day Mr.james dant..
Whirlpool manufactures many types of washing machines. Whirlpool's top load models rely on an analog timer that controls the cycle used to wash the clothes in the washing machine, rather than a digital control board found in most front load models. The timer contains a number of moving parts and is physically turned to choose the wash cycle. Because of the high usage of the timer, it will eventually break, requiring replacement. Rather than calling a service technician to repair the timer, replace the timer yourself to save both time and money.
Instructions
1. Unplug the washing machine from the wall outlet
2. Turn the dial to the "Off" position and then unscrew the knob from the timer. To unscrew, hold the dial with one hand and turn the knob counter-clockwise.
3. Lift the dial off of the washing machine.
4. Remove the two mounting screws securing the timer into position. 5. Remove the two screws from the bottom left and right sides of the control panel, then rotate the control panel up 180 degrees.
6. Remove the wire harness from the old timer and remove the old timer
7. Connect the wire harness to the new timer.
8. Place the timer into the control panel. Hold the timer post with one hand and rotate the control panel back down. Secure the timer into place using the mounting screws that were removed from the old timer
9. Place the dial back onto the timer post and then screw the knob onto the post.
10. Plug the washer back into the wall outlet
Try to watch this video:
Nov 25, 2011 | Washing Machines
How do i replace the timer part number 3351744
This video will show you how to open the control panel(and remove cabinet) disregard the cabinet part but it shows how to open the console. To replace the timer,push in timer knob and unscrew knob ina counterclockwise direction and use a small screwdriver behind dial to remove it.under the dial will be the screws the hold timer to console remove those.
Good luck i hope this helps,
Gene
Aug 09, 2011 | Roper RAS8445KQ Top Load Washer
Need directions on replacing the knob-Timer Assembly for the WSXH208V1WW. Bought the replacement part but can't find any instructions for removing and replacing it.
Remove top of washer then Remove timer knob then (2) screws behind knob, un- plug timer connector and replace of course always unplug machine First
Sep 27, 2010 | GE WSXH208A Front Load Washer
How to remove timer knob from Kenmore washer, model #29422800
I can't remember if the timer has to be pushed in or pulled out to remove it, but the timer knob comes off by turning it in a counter-clockwise direction. Once the knob is off, the clear plastic dial underneath should pull off. There is a single screw under the dial that holds the timer in place. You can access the timer by popping the operator console up. There is a release tab in the front corner of the console on each side. Simply slide a putty knife under the console at each front corner and push straight in from the front. The console will lift up after each tab is released.
If you have questions, or need further advice, please let me know.
PS Is there a particular reason why you are trying to remove the knob? Do you suspect a defective timer? Some problems may give symptoms that make it appear to be timer related, but it may not. I just don't want you to spend money on a timer unnecessarily, if the problem is attributed to something else that is less expensive.
Feb 06, 2010 | Washing Machines
Recently replaced the electrical control for my Frigidaire GLTF2940ES Front Load Washer. Now the settings dial is not properly aligned; that is, the selection on the knob does not correspond to the wash...
The dial knob itself has slipped on the shaft. You need to remove knob from timer switch shaft and realign it. to current running cycle.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
Aug 01, 2009 | Frigidaire GLTF2940ES Front Load Washer
Wash cycle dial wont turn...will still push in and pull to start
We have a GE WJRR4170 washer, with the same problem. At first I thought I might have to unscrew the entire control panel just to replace the knob. However, replacing the knob turns out to be easy.
Right behind the knob, holding it in place, is a nylon/plastic retainer clip. If you pull out the knob (into the "start" position), you will get easier access to the retainer clip. You can use a flathead screwdriver to push the clip out. The knob then will slide easily off the metal stem. A GE replacement knob costs $9 or $10, depending on the source.
Shame on GE, but the knob is designed terribly. The part of it that engages the dial has eight, flimsy plastic teeth. At any time, four of these are supposed to engage four little slots in the dial. However, the way the knob is designed, there will be a lot of wear and tear on these plastic teeth, so they'll wear out on every single machine.
Good luck to the many people who will have this problem!
Jul 26, 2009 | GE WJSR4160DWW Top Load Washer
Kenmore washer model no. 110.26904692 I am replacing the Dial and guard timer and can not remove the knob. How do I get the knob off?
With the knob pulled out, rotate it counter-clockwise. If that doesn't work, rotate with the knob pushed in (I can't remember which position it should be in, but do know that it comes off by turning it counter-clockwise). With the knob off, the dial guard should lift off the center post of the timer.
Jun 26, 2009 | Washing Machines
Can not get the upper right dial off. It needs to be replaced.
remove console by taking 2 screws from the rear of it out, timer knob can be removed by squeezing pin at the center of the timer and pulling knob forward. Probably the timer needs replacing
Dec 13, 2008 | Kenmore 24032\24036 Top Load Washer
RRemoving the washer starter dial
Yes, stop pulling on it. Axcess the rear of the timer there will be a smaller hole with a black piece of plastic inside where the knob shaft would be if it went all the way through. use needle nose pliers to grab the plastic piece and pull out. it is easier if the knob is pushed in is gets recessed a little more when you pull out the knob. The new timer comes with a new plastic piec pull it out then push back in to lock on the knob again.
Nov 23, 2007 | Kenmore 98702 Stacked Washer/Dryer
How do i remove a rear control knob on a hotpoint wma50s machine
to replace your timer dial take the lid of by unscrewing 2 screws at the back of the lid were your dial is look down a small oval shape opening u will see a screw undo it and the dial will come off m8
Feb 18, 2007 | Hotpoint Aquarius WMA52 Front Load Washer
Frigidaire FEX831F Top Load Stacked Washer / Dryer Logo
Top Frigidaire Washing Machines Experts
Gerry Harvey
Gerry Harvey
Jason Harris
Jason Harris
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
