Question about AT&T BlackBerry Curve 8310 Cell Phone - Red
My 8310 shuts off at 80% battery power and has been for about two weeks. Also to turn it back on it must be hooked into a wall outlet. I had a problem with an incompatible battery sign showing up but the battery is the original on that came with the phone.
  • 112 Answers
I would really recommend replacing the battery in the handset. Keep in mind retail stores usually are much more expensive than online ordering...
I’m happy to help further over the phone at https://www.6ya.com/expert/brandon_156682b88afabb53
Posted on Dec 12, 2009
SOURCE:
Dell Inspiron 5720
F-8 is the key, Try to "cold start" the computer, meaning remove the power plug from wall outlet or uplug from computer, remove battery, now replace battery and plug computer into wall outlet. Push the on button while "TAPPING" the F-8 key repeatedly Tap, tap, tap, until you hear a beep or it load the black menu with safe mode options. IF THAT DOES NOT WORK: shut down the laptop,remove AC supply, remove battery. Plug the AC power back in,DO NOT INSTALL BATTERY, Start the machine, without battery installed, and tap F-8 repeatedly. If it still fails, PULL THE PLUG OUT OF THE WALL OUTLET WHILE THE COMPUTER IS STILL RUNNING. NOW PLUG THE LAPTOP BACK INTO THE WALL AND START, THAT SHOULD TAKE YOU TO A BLACK PAGE WITH WHITE SCRIPT WITH OPTIONS YOU ARE LOOKING FOR.
Oct 31, 2012 | Dell Computers & Internet
My blackberry curve had a low battery & shut off & won't turn on.
We suggest you to visit the service provider outlet to check the battery status and condition.
Oct 13, 2009 | AT&T BlackBerry Curve 8310 Cell Phone -...
Tv shut off, and wont turn on. It flashes when you press the power button. NO clue at what is wrong.
is the tv on a power strip? unplug the tv from the power strip or wall outlet wait one minute then plug back into the wall outlet and not a power strip. TV should power back on.
Oct 12, 2009 | Sabre LCT371BKA LCD TV
My blckberry curve 8310 shut its self off and i can not turn it back on. the LED is blinking red
Try charging it for about ten minutes then turning it back on.
If this does not work, try a battery replacement.
It is something to do with the power though, whether with charging or with the battery.
Oct 02, 2009 | RIM BlackBerry Curve 8310 Smartphone
LCD TV is hooked thru cable box. When you use the
Try this (may not work):
1. UNPLUG power from TV at wall outlet.
2. Turn ON the TV (with no power cable plugged in).
3. Plug power cable back in (at wall outlet)
4. Turn ON TV (don't use remote this time).
Hope this works!
Sep 03, 2009 | Televison & Video
RCA D52W23 has shut off twice within the last week..
Try a power drain and monitor if the TV continues to do this or not:
1. Unplug the product's power cable so the device is not grounded to the house. 2. Press and HOLD the product's own power button for 1 minute to drain the capacitors. 3. Plug the product back into a wall outlet and try to turn it on.
Note: This procedure works with battery operated devices as well so remove the batteries and hold down it's power button.  Electricity can remain in capacitors and on circuit boards enough to prevent normal functionality. By clearing the residue electricity, your product will have a fresh start and many times this will resolve a buggy or non-responsive device that appears to be dead.
If this doesn't resolve the issue, it's possible the power supply is on it's last legs.
Mar 26, 2009 | RCA D52W23 52" HDTV CRT TV
Computer shut down
The sparking has probably caused your circuit protection inside the AC adapter to turn off the current.
Also, when you are plugging an adapter in,,do not have it plugged into the wall power outlet when plugging into the laptop,,,plug into the laptop first and then plug into the wall.
Jan 29, 2009 | Compaq Presario Notebook
Have power cord plugged into asus eee machine and wall outlet. light has been blinking all day. when asus eee gets unplugged it shuts off.
lets try this ---
* turn of your computer
* remove the plug from your computer.
* Remove the battery from your computer
* Let it sit for 3-5 minutes
* Replace the battery
* Plug your computer back in (Make sure the wall outlet is working as well, seems simple, but have seen it before)
* Let it sit for about 3-5 minutes
* Boot your computer
* go to
Start -> Control Panel -> Power Options -> Power Meter
Note the Total Battery Power Remaining
* Let your computer sit for 15-30 Minutes and see if the Total Battery Power Remaining has gone up.
If so problem solved
if not you may be time for a new battery.
Dec 26, 2008 | Computers & Internet
Hp c7280 all-in-one printer will not shut off
I'm assuming your printer power button will not shut the printer off. You can unplug the power connector from behind the printer if it won't shut off via the power button or power switch.
Performing a power reset
  1. Press the On button to turn off the HP All-in-One.
  2. Unplug the power cord from the back of the HP All-in-One.
  3. Unplug the power adapter from the wall outlet and wait for 30 seconds.
  4. Plug the power adapter back into the wall outlet.
  5. Plug the power cord to the back of the HP All-in-One.
  6. Press the On button to turn on the HP All-in-One.
Apr 20, 2008 | Office Equipment & Supplies
Shuts off
It sounds like the battery is flat - I realise that you've probably already thought of this, and charged up the battery, however batteries have a finite life and number of charge cycles they can go through, and may appear to be fully charge (According to the charger, at any rate), but they are unable to hold any decent charge. My suggestion would be to head down to the local camera shop, and ask if you can try a new battery in-store.
Sep 14, 2007 | Quasar VM-L450 Camcorder
AT&T BlackBerry Curve 8310 Cell Phone - Red Logo
Top AT&T Cell Phones Experts
Vincent_G
Vincent_G
Bobby G
Bobby G
Are you an AT&T Cell Phone Expert? Answer questions, earn points and help others
