Cannot connect speakers to new monitor
Thanks so much for the reply. I have external speakers from my previous monitor, however there is nowhere to plug them in. There are only 3 plugs on the backside which connect to the computer and printer and one is unused. They are marked ac-in, d-sub, and dvi-d. The dvi-d is the one that's unused. This new monitor is an LG W2053TX.
  • 4 Answers
If these external expeakers look something like these.. http://www.kelley.iu.edu/TS/z_images/AS501ultra.jpg
those are made specifically for Dell monitors on very exclusive models and they will not fit any other, as the monitor itself provides the power and has the audio output for them.
Posted on Dec 12, 2009
No sound on PC, from external speakers - please help! :)
first thing you do is update your audio card or down load a software like(.driver identifier.) its free from google you will see an instruction to opereate that software
Feb 17, 2014 | Computers & Internet
New G215HL monitor connected to HP Compaq Presario harddrive - no sound. Previous monitor had a sound port, this one does not.
You need to connect an external set of speakers to the Audio output of the harddrive, as you put it. At the rear, or some other convenient place you should find a set of at least three, "Jacks" locate the "Green" output Jack, and use that to feed the powered speakers, you then will be able to hear sounds....
Sep 28, 2011 | Acer 22" X223w LCD Monitor
Purchased a LGE2050T monitor, wish to connect to tower to get audio; no audio points on monitor
As I can see from the monitor specifications there is no audio connectivity. This means that there is no audio 3,5mm jack for the audio from the pc to feed into the screen. So you have to use an external audio system (speakers) for the audio.
In case of a problem or clarification or further details needed, don't hesitate to post me a reply before rejecting my answer.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Thanks and regards
Please kindly rate this solution
Stelios
direct FixYa link: http://www.fixya.com/users/technical114
Aug 01, 2011 | Computers & Internet
My DVI has no signal but my VGA does! what do i do? Please help me!!!
Your HP2009M monitor supports (3) methods of accepting signals from a computer. They are: 1) VGA, 2) DVI and, 3) HDMI.
You would connect the computer to the monitor using one connection only. Generally the VGA is the least desirable as it is an analog signal. The DVI and HDMI method provide digital paths into the monitor and often perform better. Your computer may only offer 1 or 2 connection choices, so you'll have to choose a cable type that is supported by both the computer and the monitor. The HDMI choice will pass audio signals to the the speakers in the monitor without needing to run a second cable between the stereo audio jack of the computer and the audio input jack of the monitor (located next to the HDMI jack) or to a set of external speakers (unless of course you prefer the external speakers).
The message you're seeing is normal. Once the monitor is connected to your computer, there will only be one active selection; VGA, DVI or HDMI. Since you're using the analog VGA jacks and cable, it is expected that you'll see a message that there is no signal present on the DVI (and HDMI) inputs when attempting to view signals on other inputs.
I hope this helps and good luck! Please rate my reply, thank you.
Feb 26, 2011 | HP 2009M Monitor
I can't get audio from my ASUS monitor. It has an "audio in" jack, with a greenish jack and black jack. I tried plugging in external speakers to both and I still have had no success. Thanks
Your monitor has internal speakers, so all you have is to connect the greenish jack on the monitor with the same jack on your pc (at the back panel you will see a green jack, a blue one. a red one and depending on the audio card some more, so connect it at the green jack). Doing this you will get audio from your monitor's speakers.
In case of a problem or clarification, don't hesitate to post me a reply before rejecting my answer.
Thanks and regards
Stelios
direct fixya link: http://www.fixya.com/users/technical114
Dec 25, 2010 | ASUS LCD Monitor
I just bought an X223W LCD monitor for my computer and there's no sound. My previous audio cable has no place to plug into this monitor. How am I supposed to get sound?
Your previous monitor had built-in speakers. The Aces LCD monitor do not have built-in speakers, therefore you need to purchase external speakers and plug these into your computer.
Nov 18, 2010 | Acer 22" X223w LCD Monitor
I have a Sceptre X7G Komodo II 17" LCD monitor/built-in speakers
You would need to connect the speakers to your computer. There should be a little jack on the back of the monitor marked audio. This will need to be connected to your soundcard jack for front speakers. Once this cable is connected you should have sound from your speakers. Hope this helps.
Aug 15, 2009 | Sceptre X7G Komodo II 17 in. Flat Panel...
I've recently had a new power supply installed and now seem to have a spare lead for the speakers with nowhere to plug it in! Help!!!
Well without knowing what color this lead is and what you did with this power supply and the vague of the problem it would be inpossiable to suggest where that lead goes please reply before rating thanks..
May 14, 2009 | Audio Players & Recorders
I have received a new monitor as a gift for my computer. It is the W1934S and I was wondering if I should have sound with this display. I do have speakers from my previous monitor but there does not seem...
It doesn't come with speakers. see for yourself here.
If you want external speakers, connect the speakers to the back of the computer. the port will be a small, round green hole. to connect 2 speakers, you need a 3.5mm splitter.
Aug 15, 2008 | Computers & Internet
Computers & Internet Logo
161 people viewed this question
David Payne
David Payne
