It's draining water out of the bottom of the machine. I can't even get the bottom panel off of the machine.
  • Washing Mach... Master
  • 5,569 Answers
If built as most, access to the innards will be through the back of the machine.
Remove the AC plug, disconnect hoses and drop them into a bucket or similar, remove the lower back panel.
The leak is with fair certainty from failed seals on the pump. Most pumps are a cheap, milky plastic, housing and this will need to be replaced. you can easily identify it by following hoses. There is a remote possibility that the water control valve assembly is cracked so once open, check the area (and valve) where the hoses are attached in the rear of the machine.
If you have a Johnstone Supply outlet in your area, you can save 1/3 - 1/2 of the dealer's cost buying through them. They call themselves 'wholesale' but they have never refused my business. Have your make and model number in hand when you call and they can tell you if available (rarely not) and how much. I expect the cost will be <$25 US.
Difficulty of replacement varies by machine but does not require a college degree.
Posted on Dec 12, 2009
SOURCE:
Whirlpool washer WTW5600XW the water will not drain completely out of the washer. I have to do 3 spin cycles just to drain the water out of the clothes. There is still water in the machine though. How do...
It could be that the filter is blocked and it is not leaving water out of the machine. Usually on the front of the machine right at the bottom of the front section there is a panel that you can open or pull down, behind this panel is the access to the filter, it should be a round cap facing outwards, turn this anti-clockwise to open and pull out the filter but be aware that there will be alot of water that will come out also so have a towel ready to soak up the excess water. It usually is a colour catcher or even that missing sock that is stuck in the filter. If there is no panel at the front then try looking at the back of the machine....
Dec 20, 2013 | Whirlpool Washing Machines
I have an Amana refrigerator model # ARB2217CSR with the freezer on the bottom its filling the the freezer with water and leaking on the floor even with the ice maker water supply off can someone help...
If the water is showing on the freezer side, more than likely you have a clogged drain. This occurs when the machine goes into defrost and the melted ice somehow is prevented from draining and therefor refreezing and blocking the drain for the next defrost cycle. The best way to resolve this is to unplug the machine for atleast 24-48 hours to let all ice melt. If thats not an option that you want to use the actual repair method would be to 1) unplug the machine 2) empty everything out of the freezer so you'll have room to work 3) take all the shelving and baskets out 4) locate the screws on the rear wall inside the freezer and remove them 5) take the back panel off exposing the evaporator coils ( the aluminum ) 6) directly below the coils is a trough of sorts and the drain is usually in the middle and runs out the bottom, remove the ice by carefully chipping it out or by using a hair dryer or hot water. 7) once all the ice is gone, the drain is visible and water can flow smnoothly down the drain dry the area and reassemble.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
May 28, 2012 | Amana ABB1927DE Bottom Freezer...
Miele G 870 SC dishwasher drain was plugged due to blocked sewer line, now won't stop pumping even though all water is been excavated and the drain, trap, and filter have been cleared
Check the water level valve. It sounds like it has stuck. It is in the bottom tray of the washer, sitting by itself. Tapping on it usually frees it up. It may yet stick again, if so, free it up again. Usually once is enough, though. If this doesn't fix your problem, you will need to replace the switch.
Best regards, --W/D--
Jan 26, 2011 | Dishwashers
Sometimes the water will not drain out, of my Kenmore Elite HE3 washer and it will display 02F. The door will not open, when I press the drain/spin button it makes a funny noise, won't drain, nor will it...
Hi, You pump filter screen is clogged up of you may even actually have something stuck in the pump. Unplug machine, remove the bottom front panel 2-3 screws along the bottom. look for the filter/screen housing next to the pump. place a shallow pan under it. Be prepared for lots if water and debris. Unscrew it slowly to drain then screw it back in to shut off and dump pan repeat until no longer full of water. Remove and clean all debris out screen, housing and hose.
Nov 01, 2010 | Washing Machines
Leaky bottom freezer on my kenmore elite refrigerator
defrost drain is clogged. defrost drain water is over flowing into bottom. take back panel off. remove ice to find drain hole. use very hot water and turkey baster to wash out till clear.
Jul 25, 2009 | Kenmore Refrigerators
My machine won't drain
Click on the following link and follow the steps provided:
http://www.fixya.com/support/r1484065-f21_error_code_whirlpool_duet_kenmore
Pouring water down the drain probably isn't enough to rule out the possibility of a clogged drain pump. You will need to open the bottom panel of the washer and remove the drain pump reservoir to be sure.
If you require additional assistance, please let me know before rating the solution. I hope you find this information helpful.
Jan 26, 2009 | Kenmore HE2 Plus Front Load Washer
Whirlpool LSQ9500LQ0 will not drain water
Access to the inside on this washer will require taking off the whole cabinet.
1. Remove two screws on the back side and on each end of the control panel.
2. The whole control panel will then pull forward then flip it back out of your way.
3. There are a group of wires coming from the control panel going down to a single plug, unplug them from the main cabinet.
4. Remove the two large brass colored clips on each side.
5. You can now remove the whole cabinet.
The water pump is in front and secured only by two clips top and bottom.
Dec 26, 2008 | Washing Machines
Washing Machine wont drain
remove bottom panel and check for obstructions in the pump romove cap by unscrewing but beware of water have some towels ready
Dec 19, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Water still in washer.
remove bottom panel and clean pump
Sep 08, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Washing Machines Logo
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
Marvin
Marvin
