Question about Texas Instruments TI-84 Plus Calculator
How to get rid of the triangle and vertical bar sign befor the Y1= in the y= button.
  • Texas Instru... Master
  • 8,080 Answers
I suspect (no, I am sure that) you ran the dynamical graphing application called "Transfrorm" and since you did not terminate it, it is still in the memory of the calculator, having taken over certain functionalities of the Operating System.
Press [APPS], and scroll UP to reach the bottom of the list of applications more quickly. Locate the "Transfrorm" application, point to it and press [ENTER].
In the display you are prompted
  1. To Uninstall .or
  2. To continue
Press [1:Uninstall]. And do not worry this will only kick it out of memory, it will not delete it.
Now you recover the usual Y= function editor.
Hope it helps.
Thank you for rating the solution.
Posted on Dec 12, 2009
Testimonial: "Thank you you are a God send! I needed that fixed for my upcoming Linear Algebra Test & Finals. You did it. Yeah. God Bless and Happy Holidays."
In the Y= button, there is a triangle and a vertical line next to all of the Y=. How can i get rid of it?
The transform application is still in memory. Press APP, then Transform. Choose Uninstall.
Apr 18, 2014 | Texas Instruments TI-84 Plus Calculator
In the Y= menu, instead of a line in front of de Y1= there's a triangle with a bar. when i click on the triangle w bar it turns into a triangle, when clicked again into 2 triangles and when clicke
You executed the Transform Application and it is still loaded in memory taking over the graphing duties from the native OS. You must unload it from memory.
Press the APPS key. Scroll and find Transfrm, then press ENTER. In the new screen select 1:Uninstall and press Enter.
Go to your Y= function editor to type in up to 10 functions.
Oct 30, 2012 | Texas Instruments TI-84 Plus Calculator
Program to graph shaded heart
What are the question marks in the two equations? Get rid of them or replace them with numbers and you'll get rid of the error.
Apr 28, 2012 | Texas Instruments TI-83 Plus Graphing...
What button do i put on to start my dvd
If it's powering up the DVD usually it's the button labled POWER or the one with a O with a vertical bar in the middle, if it's to play a DVD it't the button labled PLAY, or the one with one triangle pointing to the wright :)
Aug 09, 2011 | Televison & Video
I am getting vertical bars moving up on my screen
vertical bars in video can be caused of poor filtering of voltage on the power supply,you need to open the back of the tv to repair the power supply.replace all bulging capacitor this causes the problem.Tnx
hope this help.
please rate my help.
Jun 05, 2010 | ViewSonic VA1912wb 19" LCD Monitor
Why do i get ERR: Undefined when i try to graph anything?
The easiest way to get you started is to reset the calculator RAM.
Press [2nd][MEM][7:Reset][1:All Ram][2:Reset] [ENTER]
If the Ram Cleared message is still displayed press the [CLEAR] button.
Open the Y= editor.
On the Y1= line, enter 2*[X,T,theta,n] +1. The [X,T,theta,n] key is just below [MODE] and to the lright of the [ALPHA] key.
Press [ENTER]
Verify that the = sign to the right of Y1 is still highlighted.
After you finish entering the function Y1, press [GRAPH].
Jan 31, 2010 | Texas Instruments TI-83 Plus Calculator
How to find perimeter of the triangle whose vertices are the ff.points A(6,2)B(4,3)C(0,1)
I'm sure there are easier ways to do this but the "brute force" method is to label point A as x1, y1; point b as x2, y2 and point c as x3,y3. Then just do square root of the sum of: (x2-x1)squared+(y2-y1)squared. Save this into memory 'A'. Now do the same for x2,y2 to x3,y3 and add this to the number saved in 'A' and do it once more for x3, y3 to x1, y1 and add to the number in 'A' to get the result.
Nov 08, 2008 | Office Equipment & Supplies
Graphing issue
Damn dude i had the same problem, after a while searching for something that can put this problem away i've finnaly found the way \o/! Try APPS->TRANSFRM-> UNNINSTALL! Hope u can make it!
cheers
Feb 04, 2008 | Texas Instruments TI-84 Plus Calculator
HELP!!
Arrow to the left of the Y= until you have highlighted the triangle, and press enter until you see what you are looking for. The triangle you are referring to is probably to graph an inequality and I think you are looking for a regular line.
Jan 28, 2008 | Texas Instruments TI-84 Plus Calculator
Table problem
I have had the same problem luckily i figured out what to do. 1. press the apps button 2. then there should be an unwanted app(it was the only one on mine) 3. pick it and hit enter 4. go to uninstall on the top of ur screen problem solved!!!! hope this helped
Sep 08, 2007 | Texas Instruments TI-84 Plus Silver...
Texas Instruments TI-84 Plus Calculator Logo
88 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Stevan Milanovic
Steve Allison
Steve Allison
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
