Question about Kensington PocketMouse Pro 72117 Wireless 113227
I can't locate the receptacle for the batteries. I have had the mouse for a few years and haven't used it for about 12 months. In the meantime, can't locate the area for the batteries. The opening on the side is too small even for AAA's and as I recall it uses AA's. Even my 9 year old son, who can usually diagnose all of my tech issues, is baffled.
    Sniper:
  • 105 Answers
PocketMouse Pro Wireless User Manual
Posted on Dec 13, 2009
    Scholar:
  • 77 Answers
The mouse is powered by two AA batteries found under the mouse shell, which is released by a spring-loaded, slotted latch on the underside of the mouse. A coin or thumbnail will suffice to turn the latch counter-clockwise about 45 degrees to release the back, which then pops off revealing the battery compartment.
You can see a picture here:
http://www.mymac.com/img/archives/mcpheeters/pocketmouse2.jpg
Good Luck
Posted on Dec 17, 2009
I haven't started my 1988 Chevy 305 truck in a few years. I put a squirt of lubricate in each cylinder, made sure there was oil and coolant, and a new battery. When I tried to turn the key it wou
I would check to see if you are getting 12 volts at the starter. You should have one wire coming from the ignition that gets system voltage when you turn the key to the start position. You'll also have one from the battery that will be hot all the time.
Dec 21, 2017 | 1988 Chevrolet K2500
My wireless logitech mouse will not work on my computer how do i get it to update it or what im using an ancient mouse of my mothers and i just purchased the logitech about a 3 months ago and it was...
Hi Melissa,
Check the batteries in the mouse itself, see that they haven't dislodged in the move, and make sure the mouse can find the sensor from the USB port. Let me know if that works. If not, I'll ask my son, he's a genius when it comes to that, he gave me his old Logi USB mouse cuz my old one failed too..
Hope this helps
Joe
Aug 30, 2011 | Computers & Internet
Gucci 8400m watch not working. I haven't used it for years and it only ticks when i shake it. As soon as i stop shaking it it stops working.
This watch is a swiss quartz model and runs on a small battery located inside the case.
These batteries normally only last approximately 2-3 years and then must be replaced.
You can bring the watch into any decent jewellery store and they will probably be able to replace the battery for you for less than $20 inclusive.
Here are some links to a few short videos which demonstrate the basic process of changing the battery in a watch:
http://www.youtube.com/watch?v=rm9AZwtTCK8
http://www.youtube.com/watch?v=1bqATsw7Jvw
Just use your mouse to click on the links, which are the underlined and highlighted text just above. This will open a new web browser page automatically for you and allow you to view the information and videos indicated.
Please comment back here to this page if you have any details to add, have any questions, have difficulty accessing the links, or just require further general assistance and I will respond as soon as I see it.
I hope that was helpful to you, good luck and take care.
Joe.
Aug 14, 2011 | Watches
I have a Garmin Nuvi 1300t, I tried to enter my UK post code which has been valid for 25 years and I get a different street example I type in MK15 8PL select 12 and I get 12 St Stephens Drive MK15 8QB and...
My nuvi 1300t will not find satellite. I did as is says by taking outside away from buildings/trees. Haven't used it in a few months. Updated it. still doesn't find satellite. It says it's at the last location that I used it.
Sep 21, 2010 | Garmin GPS
The mouse won't work at all. I've plugged the usb into all the ports and it just won't work. It won't move scroll or click. The green light comes on then gently fades away. The batteries are new and I've...
The light is supposed to go dim after few seconds. it's not lit all the time. So it works propperly.
2 of my arc mouses stopped working too after 6-12 months and i got new ones but now after 4 months with the new ones, they failed too.
The problem is within connection between USB-device and mouse. the USB device gets overheated and destroys it self in extensive use.
Get it back to store and swap it to new one.
Jun 17, 2010 | Microsoft ARC Mouse
The red laser pointer underneath the mouse isn't coming on? put new batteries in and the receiver is showing the green light once plugged into my laptop.
I doubt the problem is the battery. I have this same mouse and it has worked beautifully for two years now EXCEPT for one problem: most of the time, the mouse does not turn on when the receiver is removed from the receptacle on the bottom of the mouse. There is a tiny little switch built into that receptacle, along the side wall of the receptacle not far from the light. I have to wiggle this little switch (gently!) by hand a few times until the light comes on. From that point, the mouse will work fine until the receiver is placed back in the receptacle.
Dec 07, 2009 | Microsoft Wireless Notebook Optical Mouse...
Optical mouse no longer works
I doubt the problem is the battery, and you do NOT have to press the Connect button each time you use the mouse - it will connect all by itself if it can. The Connect button is only used to re-establish connection if for some reason it cannot connect automatically.
I have this same mouse and it has worked beautifully for two years now EXCEPT for one problem: most of the time, the mouse does not turn on when the receiver is removed from the receptacle on the bottom of the mouse. There is a tiny little switch built into that receptacle, along the side wall of the receptacle not far from the light, so that it gets pressed when the receiver is inside the receptacle. I have to wiggle this little switch (gently!) by hand a few times until the light comes on. From that point, the mouse will work fine until the receiver is placed back in the receptacle.
Nov 05, 2009 | Microsoft Wireless Notebook Optical Mouse...
I have a clight problem with my mouse and keyboard set i got it from a friend of the families becasue it was getting interferance when they tried to use it (can't change the freqency it uses) anyway long...
Wireless connections are not reliable. One solution is to buy a wired keyboard and a wired mouse. Depending on where you live, they can be obtained for $10 and last for years.
May 01, 2017 | Microsoft Wireless Optical Mouse
Keyboard works, mouse not
Are the batteries in the mouse charged?
If you are not using rechargable batteries replace the batteries with alkaline batteries, they only last about 1 month...
Jun 28, 2009 | Labtec 9675120403 Keyboard
Batteries in mouse
THERE MUST BE A DEFECTIVE PART IN THE MOUSE BECAUSE YOU SOULDNT HAVE TO CHANGE THE MOUSE BATTERY ONCE EVERY 6 MONTH TO A YEAR, AND THE KB THE SAME 6 MONTHS TO A YEAR.
YOU CAN GO ON LINE EMIAL LOGITECH AND ASK THEM WHAT THE PROBLEM IS, HERE IS THE WEB SITE:
WWW.LOGITECH.COM/SERVICE
RODGANDYSR
Mar 03, 2009 | Logitech Cordless Optical Keyboard/Mouse...
Kensington PocketMouse Pro 72117 Wireless 113227 Logo
166 people viewed this question
Top Kensington Computers & Internet Experts
dctocali
Level 1 Expert
Alun Cox
Are you a Kensington Computer and Internet Expert? Answer questions, earn points and help others
