Question about Hotpoint RGB745 Gas Kitchen Range
Pilot light are to high
Hotpoint rgb508ppa5wh we switched it to propane gas.
  • 640 Answers
If you didnt change the pilot, burner orfices and regulator this is your problem.the gas pressure is different.any ? let me know.
Posted on Jan 21, 2008
Napoleon Fireplace propane Pilot won't light main burner even though gas flows in?
  • I'm going to assume your fireplace has a pilot light.
  • Follow the little holes in the burner that lead to the pilot light.
  • Make sure the pilot flame is pointing directly at the closest burner hole. (adjust if necessary).
  • Often, you will need to sprinkle a layer of "glowing embers" in this area. The embers will help the gas travel to the pilot light and ignite.
  • Always start your propane appliance on "High" never "Low". Cold propane likes to drop to the bottom of the firebox and accumulate until it reaches the pilot (this is called delayed ignition). Keeping it on "high" will help the fuel travel over to the pilot without buildup.
Jan 21, 2013 | Napoleon 36" Zero Clearance Top/Rear Vent...
The pilot light won'jt light in my warm morning propane gas stove
If you dont have gas coming thru while holding down the button, you have one of the following; no gas, main valve off, or a bad gas valve.
Jul 21, 2017 | Heating & Cooling
Was preheating oven, while cooking on stove stop. heard a puff sound open up oven thought it was on but it never heated up. the electric light comes on but does not ignite. the broiler does the same. ...
Gas ovens are fitted with at least one safety device and it could be it has failed.
The safety device is bypassed while the pilot light is lit. The pilot light heats a thermocouple bulb which switches the gas on to the burner. As long as the pilot light continues to heat the bulb gas will continue to flow - until the thermocouple fails, they aren't long-lasting...
Feb 03, 2018 | Hotpoint 30" Self-Cleaning Freestanding...
Gas water heater with sealed front pilot lights turn to on lazy flame briefly goes out then pilot will not relite for awhile
If you have a propane or LP heater check the gas, you have run out... if you have a natural gas unit then check the regulator it has gone bad...
heatman101
Aug 22, 2010 | Hotpoint Kitchen Ranges
Propane doesn't seem to be coming out of the right place, thus I can't light the pilot. If I use a match to light the pilot, the flame is coming out of a hole in the valve lower than where I believe it...
IF THIS IS A WHITE ROGERS GAS VALVE AND IF GAS IS COMMING OUT OF PINHOLE AT SIDE OF GAS VALVE WHERE TWO PILOT PRESURE SWITCH  WIRES GO IN GAS VALVE THAN YOU HAVE TO REPLACE VALVE. AND THESE ARE HARD TO FIND . I BOUGHT ABOUT 10 OF THESE BECAUSE THY ARE PHASING OUT
Apr 21, 2010 | Endless Summer 1501 Patio Heater
I have a set of propane gas logs. The pilot light
Check the connection of the thermocouple or replace it if connections are tight.Pilot safety valve may be badreplace gas control valve.
Oct 24, 2009 | Desa International CCL3924PTA 24" LP Gas...
Propane to control box but pilot won't light. No propane going to pilot. Model#rmc50lpt.
Remove pilot tubing from gas valve and push the pilot knob to verify gas makes it out of the valve. If not, bad gas valve, if you do get gas, replace pilot orifice located in pilot assembly.
Oct 03, 2009 | Dyna-Glo Heating & Cooling
Pilot will light but main burner will not light
if burner lights after jumping valve you have something wrong in thermostat loop. disconnect the 2 thermostat wires on gas valve and use multimeter on continuity setting. if all wires ,connectors and components are good,you will get a tone.since you have jumped out each component in thermostat loop with no success ,i would suspect a bad wire or oxidation on a terminal .
Sep 24, 2009 | Teledyne Laars Laars Lite 2 Pool Heater...
Pilot light on but heater will not start
check the high-limit switches. Under the inlet/outlet header. if either is open it will not allow you to fire up. my 150 degree switch was corroded and after jump9ng out, bam it worked.
May 25, 2009 | Teledyne Laars Laars Lite 2 Pool Heater...
Hotpoint RGB745 Gas Kitchen Range Logo
105 people viewed this question
Top Hotpoint Kitchen Ranges Experts
Sal De
Justin Duby
Justin Duby
Ismael Rodriguez...
Are you a Hotpoint Kitchen Range Expert? Answer questions, earn points and help others
