Expert
- Posted on Dec 12, 2009
Re: I can't get it to charge
This is typically caused by one of two issues:
- (Most likely) The battery has failed and needs to be replaced. If the battery is older than a year and seen heavy use or been plugged in to the charger for long periods of time, this is likely the problem. Verify that the power adaptor is not bad (below) and purchase a new battery from a local retailer or online.
- The power adaptor is bad. Plug in your power adaptor and verify that the power LED is lit. If it is not, then it is bad and will need to be replaced or alternately, you can purchase an inexpensive external battery charger. They are available online or often from your local retailer.
A couple good sources for batteries/chargers:
http://everydaysource.com
http://www.all-battery.com/
Hope this helps.
-Tor
