Question about Maytag Washing Machines
Maytag model# LAT8026AAE - it fills and Dial
Maytag model# LAT8026AAE - it fills and Dial moves but machine does not go to next function
vest6
  • 196 Answers
SOURCE: Maytag Performa...It fills up and will not spin.
There are to devices that can cause this. The lid switch and the water level control valve.
Posted on Jan 13, 2008
SOURCE: Maytag Washing Machine Problem
MY MAYTAG WASHER HAS STARTED TO LEAK I JUST WANT TO KNOW IF I SHOULD REPLACE THE CENTER SEAL AND TUB SEAL
Posted on Jun 26, 2008
  • 51 Answers
SOURCE: Lower washing machine function inoperative in Maytag stackable
This is very odd, and probably isn't going to be any help,,,, but i know that most top loading washers have motors that spin in 2 directions. 1 direction engages the transmission/gearbox which than makes the agitator go back and forth while also turning the water pump in a direction that actually sucks in air, or water. When the motor spins in the other direction the transmission/gearbox engages so that only the drum spins and the water pump now does its job and pumps out any water in the drum before and while its spinning. With this in mind, and the fact that you say the washer only spins,,,, its possible that the motor is only spinning in one direction allowing the washer to drain and spin,,,, but not agitate.
Posted on Mar 13, 2009
localwonder
  • 6784 Answers
SOURCE: Maytag PAV2300 washing machine
Hi. this will occur when the water level pressure switch is malfunctioning. you will have to replace this device in order to restore optimal performance.
Please rate and have a great weekend:)
Posted on May 16, 2009
  • 132 Answers
SOURCE: My GE washing machine is stuck on agiation mode.
HUMMING NOISE MAYBE OVERLOAD ON MOTOR OR PUMP SO DEAL NOW WITH DRAIN PROBLEM 1ST IT MAYBE NEED TO DRAIN FILTER CLEAN
THANKS
Posted on Jul 15, 2009
I have a Maytag Ensignia washer that will fill with water and start working but will not advance to the next cycle without manually advancing the dial. once helped into the next cycle the washer works...
First you need to list the model number in order for me to figure out what type of washer it is then i can help you. The reason I ask is some Maytag Ensignia's come with electronic timers and some models have old style timers...
Mar 10, 2013 | Washing Machines
Have a Maytag washer LAT9635AAE. It fills with water and does not proceed. The timer seems to move the dial around but doesn't engage the washing functions. At first I thought it was simply not...
Remove the timer and get the outer skin off of it. Twist the timer around and hunt for burn marks on the barrel. I suspect it is the timer. To get it off you pop the cap on the knob and under it is a keeper and spring you remove. Then the knob and skirt will come off and you can get to the screws which hold the timer to the consolethemobilian_29.png
If the timer turns out to be ok then the motor is suspect.
Note: This washer is well worth repairing. Anything out there on the market now is trash compared to this machine. Invest in repairing it. You will be glad you did.
May 18, 2011 | Maytag Washing Machines
Washer only works by manually advancing the dial.
yes this sounds like a timer it sounds like it is getting stuck in the cycle. replace the timer and this will clear up the problem
Dec 29, 2008 | Maytag SAV3710AWW Washer
Maytag Lat 8434 Top Loader will not cycle
sorry but i dont have much experience with this particular model, so i really have no advice for you, please repost
Dec 03, 2008 | Washing Machines
Maytag washing machine
humm, is it advancing to spin on its own or are you manualy moving it?
model serial is on the top of machine stand on tip toes and look over the top
could just be the lid switch
May 16, 2008 | Washing Machines
Jan 09, 2008 | Maytag Performa PAV3200
Maytag stacked washer/dryer Model LS7804
OK it may be one of 2 things. I would check the lid switch first. On some maytags the have a lid switch that if it is not working properly it will not let the washer fill. If it will not fill the washer will not wash because the pressure switch did not activate the timer to wash. If the switch checks good you might have a bad timer. If you open the control panel you will find a tech sheet with the wiring diagram. I would follow the fill cycle and check the components. You might also check the water valve to make sure its ok too. But its very rear that both the hot and cold would go at the same time. Good luck!
Jul 11, 2007 | Maytag LSE7806A Top Load Stacked...
Washer fills with water , then shuts off , doesn't move to another cycle
Since you know about the lid and check switches, they are located under the splash (control)panel. unplug the machine and remove the screws holding the panel on. Using a meter check the switches for continuity and replace if they've gone bad.
Jun 06, 2007 | Maytag Neptune MAH5500B Front Load Washer
Washing Machines Logo
88 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
