Question about Apple iPod nano
How long does should it take to charge the unit out of the box?
  • 6,831 Answers
Hello
It is usually around 4 to 6 hours.
Kind regards
Andrea
Posted on Dec 12, 2009
I just got my new jam speaker. To charge unit I kep the unit off? How long does it take to charge..
7-8 hours to full charge from out of the box. Do not use it until it is fully charged.
Jan 20, 2017 | The Audio Players & Recorders
Have New battery and Alternator, battery still won't stay charged.
Since you are having a new battery and alternator the charging circuit of the electronic charging unit is a possible suspect.
All what is required is to check the charging voltage when the engine is started, if there is no increment of voltage when the engine runs the alternator then the connection from the alternator must be checked. Check the output from alternator, check the relay box which contains the charging unit. It can be a failure of the rectification or the stabilising circuit, the unit must be replaced.
Sep 21, 2011 | 1993 Buick Park Avenue
How long should i charge my jump box
I'm not familiar with this model, but other boxes I've used have all had some kind of power level indicator to show their charge level. I'm sure yours does too. Charge it at least until the indicator shows it's full. You can leave the unit charging for as long as you want, actually. The charging circuitry drops to a low trickle when the unit is fully charged, and won't damage anything by overcharging. (We have one where I work. As soon as we're done jumping something it goes back on charge, and it's over three years old now.)
Aug 11, 2011 | Xantrex Technology XPower Powerpack 200...
I have a olympus fe 20 how do i charge it? can i use the usb?
No, you cannot use the USB to charge it. Your camera uses a LI-42b battery, which looks like this:
You need to open the battery compartment, take the battery out, and put the battery in the charging unit. I'm not posting a picture of a charging unit because they vary, but generally it's just a small box that has a slot to take the battery, and plugs in to a wall outlet. There's usually a LED indicator on it, to tell you when it's charging/charged.
I'm afraid that if you don't have a charging unit, you'll need to get one, you can't charge the battery any other way.
Jan 21, 2011 | Olympus FE-20 Digital Camera
Brand new Garmin Nuvi 1490 T out of the box. How do I charge it? The only devices in box were a car charger (my commute is 5 minutes daily) and a USB connector? Should I just plug the USB into my computer?...
Garmin satnavs come with a charge out of the box.
In some cases your device may have lost a charge during shelf life. In this case you can charge these units in three ways:
  1. Place unit on computer with USB cable for approximately 8-12 hours
  2. Place unit on Garmin specified AC adaptor for approximately 4-6 hours
  3. Place unit on 12V vehicle adaptor for approximately 4-6 hours.
Some cars continue to supply power to the cigarette lighter socket when turned off and others don't. If yours doesn't you can charge it from your computer. There's no indicator to show that it's charging or when it's charged. However when you disconnect the satnav from the computer and turn it on there's a battery state indicator which shows if it's fully charged or not.
Aug 16, 2010 | Garmin nuvi 1490T GPS Receiver
How long does it take to charge up we just bought a new one and it was plugged in the car for 2 hrs and only lasted about 2 hrs
Garmin satnavs come with a charge out of the box. In most instances you will not need to charge before using. Your device will charge while attached to your 12V vehicle power cable.
Your device should be fully charged after applying one of the steps from above.
Aug 09, 2010 | Garmin nuvi 250W GPS Receiver
How do i activate the set?
There is no charge to activate a Garmin GPS. Purchase the unit, turn it on and it works right out of the box. You will need to charge it as the unit only comes with a partial charge from the factory, but it will work immediately.
Jul 02, 2010 | Garmin nuvi 255W GPS Receiver
The Device does not say if it is charging
It usually needs to be left for a while until it start recharging, a few minutes or so. If this does not solve anything then it would be best for You to bring it back for servicing.
Jan 12, 2009 | Magellan Maestro 4250 GPS
Unit won't remain powered-up
You are absolutely correct Jim. Low Battery
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} There are three ways to charge the internal battery in your automotive GPS unit.1
  1. Use the provided vehicle power cable that came with your GPS unit. The unit will charge while powered on and using the device as well as when the GPS unit is powered off and plugged into a running vehicle. About 3 hrs for a full charge.
  2. Use an AC power adaptor. Some units come with this power cable to plug the GPS unit into a wall outlet allowing the GPS unit to take a charge. For units that do not come with this cable, one can be purchased from Garmin's online store.
  3. For most units, the final way of charging the battery is to plug the GPS into a powered on computer with a USB cable2. This method of charging will be a trickle charge and it may take longer (like a full day) than the other two options, however it will still charge the battery. A USB cable is provided with a few GPS models. For those that don't come with this cable, one can either be ordered from the online store or you can use a standard USB to mini-USB cable that fits the unit and plugs into your computer.
1 - Please note that temperature can play an effect on the charging of a device. If the battery registers a temperature of 0°C and below or 45°C and above (32°F and 113°F
Dec 25, 2008 | Garmin nuvi 260W GPS Receiver
Frozen NS-8V24
I pulled the battrery cover off and removed the battery. Leaved out for a couple of minutes then replaced and reversed the order. Then I turned it back on, and it still stays at the "Profiling media files" box. What should I do?
May 10, 2008 | Insignia Pilot MP3 Player
Apple iPod nano Logo
21 people viewed this question
Top Apple Audio Players & Recorders Experts
Nagendra Baliga
Parshiv Luthra
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
