Question about Microsoft HannsG HU171D 17" LCD Monitor
Monitor will not respond to computer.
My wife restarted her computer. While this was going on she dusted off our 2 years old HANNS G LCD Monitor. She did not notice any static discharge with the dish towel she used, and we have tile floors, without a carpet at the desks. The computer came on but the monitor won't respond. Gives signal of no input. I plugged her computer into my monitor and it worked. Also used my cable to her computer and monitor with no positive result. Any ideas? Thanks for your time.
Craig S. Chisesi
  • 430 Answers
TRY UNPLUGGING MONITOR FOR APROX10 MINS AND RETRY
Posted on Dec 12, 2009
I have a hanns g hg281d just over a year old. It has started blinking on and off several times when it comes out of sleep mode in the am. Is the power supply going bad? I have talked to other people having...
your monitors pwr supply has been worn down, you need a new one (most just get a new monitor) in order to avoid this problem in the future, make sure the screen is placed in a vell ventilated area, and that you turn the power off every once in a while.
Sep 26, 2010 | Hanns.G Corporation 27.5" Widescreen...
Hanns-g JC199d monitor displays 2 messages periodically
install an AGP card into an AGP slot because internal display card does not support high resolution because of insufficient memory . use 8X AGP card for better result . then you can see high resolution ,3D games ,and movies .
Apr 17, 2010 | Hannspree HANNS·G JC199DP LCD Monitor 19...
My Hanns-G LCD monitor goes black with the word "ADJUSTING" every 2 minutes or so. Whats wrong with it? How do i fix it?
this probably the auto key stucked, or defective. Use a small tool to release key with extreme care.
Jan 15, 2010 | Hanns.G Corporation HW191D 19" LCD Monitor
My Hanns Monitor keeps going to a green screen and telling me that I have no signal. I have unplugged everything and plugged it back in and it keeps doing the same thing.
change your montior and plug another monitor to check if it is doing the same problem, if it is not working then check your cpu, if is is working then reservice your lcd, if it is cheap..
Oct 25, 2009 | Hanns.G Corporation JW-199DPB 19" LCD...
Help make speakers work
raggedyan184 -
You can find the driver for your monitor here:
http://www.howtodrivers.com/model501390.html
(You will have to enter in the numbers shown above the "Download" button in order to download, security measure for the site)
The following instructions (from the site) are also listed for installation:
Step-by-step guide for install HANNS.G HU171D driver.
1. Download file for HANNS.G HU171D from our site, save it on your computer and unzip.
2. Connect your HANNS.G HU171D to computer.
3. Right click on My computer and click Properties. Go to Hardware tab. Click to Device Manager button.
4. Find your new HANNS.G HU171D on Lcd monitors category double click on device and press Reinstall Driver button.
5. Select Install from specific location, check Include this location and click Browse button to select the Hanns.gdriver click Next button to continue and click Finish button to finish installation.
6. After this procedure you should see new HANNS.G HU171D in Lcd monitors inside device manager.
Hope this helps!
-- RT
PS - If this was useful, don't forget to vote!
Sep 08, 2009 | Microsoft HannsG HU171D 17" LCD Monitor
I-inc CY199 monitor will not turn on
It sounds like you have a monitor with a common problem, we have repaired many Hanns-G monitors with this problem. After a few years some LCD monitors will blow a power supply. The problem is caused by parts called capacitors overheating in the confined space of the monitor. If you are good at electronics repair/soldering you can usually fix the problem. Check out a few pictures on my web site www.ccl-la.com/badcaps.htm You can take the back cover off your monitor and look for the bad parts,replace any that look like the pictures and your monitor should work fine. The capacitors do need to be installed with the correct + and - connections, note the stripe on the old one and insert the new one the same way. If you can't do the repair we offer a repair service, contact us for more details.
I hope this helps, if so please rate my solution.
Buddy
Corporate Computer
www.ccl-la.com
Over 21 years of computer and printer support/repair
Aug 10, 2009 | Hanns.G Corporation JW-199DPB 19" LCD...
Hanns 17" LCD MONITOR
internal power supply failure,the AC power supply that powers the backlight fails every time you turn it on. Unfortunatly electronic repair is costly, A new monitor is cheaper.
Dec 25, 2007 | Hanns.G Corporation HU-196DP LCD Monitor
Microsoft HannsG HU171D 17" LCD Monitor Logo
209 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
