Question about K40 Vehicle Parts & Accessories
I have the K40RCPP road case and was needing installation instructions
2003 Harley Davidson FLHRCI Road King Classic install a front fender rail instructions
Hi, Henry for more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below and for more specific information or questions at no charge please feel free to contact me at xlch@mail.com. Good luck and have a wonderful day.
Road King fender trim install Harley Davidson Forums
2003 Harley Davidson Touring Models Service Manual pdf
http://partsfinder.onlinemicrofiche.com/ronnies/showmodel.asp?make=hdmc
https://serviceinfo.harley-davidson.com/sip/vehicle/lookupForm free owners manual
Instant Tech Relief To speak to me personally absolutely free
Apr 18, 2018 | 2003 Harley Davidson FLHRCI Road King...
Installation instructions for yamaha road star saddlebag guards STR-5VN33-00-00
Hi, Anonymous for more information about your question and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
Re Tour Classic Saddlebag Guards eBay replacement Road Star Forum Yamaha...
Yamaha Star Accessories Saddlebag Guards
Yamaha XV16AL Service Manual
OEM parts for Yamaha
YAMAHA XV1600A Owner Manual
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
Sep 11, 2012 | Yamaha Motorcycles
Hi i was wondering if i could change my transfer case instead of changing the front and rear gear ratio? my transfer case is broke now and i do alot of mudding and sombody told me if i get a dfferent...
The output ratio of all the transfer cases I've seen is 1:1. (in "normal" 4wd) Low gear is different. As it says, it's lower than that. The ratio does differ but you'd have to check it to see what it is. I know there are aftermarket gear sets that are available for serious off-roading. Installing them would be a "standard rebuild" right out of the manual but you'd need to also have the gear manufacturers instructions as sometimes different thrust washers, spacers etc need to be installed to make them work without wearing or breaking. Before considering doing this yourself or having someone do it for you, I'd consider finding a few off roading forums on line and asking what other people have done and the results they got. Changing gearing changes stress loading of other components and many times what seems like a simple mod can require a lot of expensive changes you did not anticipate. Two weak links i can think of off-hand usually are the universal joints and axles.
So, likely you can change the ratio but only for low gear. It will change the final drive ratio but as I said you need really good information before going ahead with it!!!
By the way...there's also a cable system available that replaces the electronic actuator made for gm transfer cases. You might want to look into getting one. They are more reliable.
Jul 11, 2011 | 1998 GMC Sierra
Hello there, I bought a china brand gps with built in garmin mobile xt, how do install road maps. I'm from the philippines by the way.. Thanks for helping me...
Welcome to FixYa!
To update your map, go to https://my.garmin.com/maps/chooseDeviceType.htm? Choose your device type. I believe Garmin Mobile XT is under the "Phone Devices".
It will ask you to install the Garmin Communicator Plugin, install it and follow the instructions. You may need to connect your GPS to the computer during this process.
I'm not quite sure if a road map for Philippines is available though.
Thank you for using FixYa. Have a great day. Jas247
Note: CDRKing also released a less expensive GPS tailored for Philippines.
May 13, 2011 | Garmin Mobile XT GPS Receiver
I'm trying to install an air ride solo seat from a police Road King on a Road King, I can't seem to find any reference on installation. Can you help?
I'm sorry but I'm not familiar with the seat you are working with. If the seat is made by someone other than Harley Davidson, they may have a website at which you can get installation instructions. If they are not posted, contact the company via e-mail or telephone and ask for installation directions.
Good Luck
Steve
Aug 20, 2010 | 2002 Harley Davidson FLHR - FLHRCI Road...
Installation with off road lights baja champion bc-600
HI,,
ITS PROBLEM WITH URS OFFROAD BULBS,,,
CHECK LOOSE CONNECTION AND BULBS...
TNKS
RABBANEES
Nov 11, 2009 | 2001 Ford F150 Styleside SuperCrew
Men?s Schwinn 700C Prelude Road Bike Assembly
Pedals can be purchased in pairs and some road bikes do not come with pedals. They have 2 different axle sizes 9/16" and 1/2". There are road pedals and road clipless pedals.The ones with clips and quick bindings require special biking shoes that the cleats clip into.Quick releases come in various lengths for front and rear wheels depending on what wheel you have. This all means a trip to your local bicycle dealer. They will match the pedals to the axel size you need and the type of riding you will be doing. For a little extra cost they will install them.They will also match you up with the proper length of quick release skewer you will need and show you how to install and tighten it properly.Remember to take your bike and the front wheel. Hope this helps. Good riding.
Mar 15, 2009 | Schwinn Midmoor Men's Hybrid Bike
Replace clutch hand control
follow your cable down from your hand control. Pull the black rubber grommet up or down and loosen up your clutch cable once it has slack usually takes a 1/2 inch and 9/16 wrench then go up to your handle their is a snap ring under neath take it off. push the clip up and remove handle.
Mar 06, 2009 | Harley Davidson Road Tech HA90 MP3 Player
How do I recd instructions to proceed to route
"proceed to route:" means that the road you are now on is not part of the maps installed. You can get this when in a Mall parking lot or a new home sub division.
Simply put the GPS is saying to you, "I don't know how to get to a road I know from here so you need to get to it yourself once we are on a known road I'll start giving you directions"
Sep 22, 2007 | Magellan RoadMate 700 GPS Receiver
Vehicle Parts & Accessories Logo
96 people viewed this question
Top K40 Vehicle Parts & Accessories Experts
Marvin
Marvin
Thomas Perkins
Thomas Perkins
Are you a K40 Vehicle Part and Accessory Expert? Answer questions, earn points and help others
