Question about Panasonic Home Theater System System
Repeated F61 fault code on Panasonic Home cinema system Model: SC-HT990 Is it the fan in the sub woofer?
  • clanmarti887 Dec 12, 2009
    Just to let you know, both fans, cleaned and dusted and all parts are back together and it all seems to be working again fine!! Many thanks, you have saved us an expensive trip to the manufacturer's repair shop.
  • 6,831 Answers
Hello
F 61 error means the failure of FAN
most probably dust in the fan made it to stop working so clean the dust and connect the fan to an external supply of 12v(using red and black wire) for 5 minutes and reconnect it to the unit otherwise replace the fan with new one.
Surely this will solve the problem.
Kind regards
Andrea
Posted on Dec 12, 2009
Testimonial: "Sounds most probable, so have just finished dusting it and will let you know outcome, many thanks. H"
  • Andrea Lock
    Andrea Lock Dec 12, 2009
    Hello
    I am very glad that i could be of assistance.
    Kind regards
    Andrea
Hi Andrea,
Wish you Happy Prosperous New Year ahead of you!
I have a problem with my Panasonic Home Theater SC MT1 whose Woffer module is SB WA340. When I play it shows F61.
I have checked and noticed Fan is not working. Neither it is getting 12 V.
Secondly, one of the channel ( Central one) is making hum sound before going to F61. In cold, I mean when I try I t will play for 30 to 60 sec before going to F61 and the channel is also making hum sound. When I remove the speaker it does not make sound.
Do you think it is Fan problem or with its power module RSN311W64BP
Pl. suggest how do I rectify this problem.
Regards,
Apurba
Posted on Dec 28, 2009
    New Friend:
  • 4 Answers
I have problem with my home cinema Panasonic home cinema SA-HT 870. I can't turn on. when i push the buton on/off i hear zzzzzz and i see on display EROR F61 and after 3 sec system is turn off. I checked my fan on sub. and check cable speakers, but still doesn't work. Can i get help for this problem, thank you!
Posted on Oct 17, 2013
I have problem with my home cinema Panasonic home cinema SA-HT 870. I can't turn on. when i push the buton on/off i hear zzzzzzzzzzzzzzzzzzzzzz and i see on display EROR F61 and after 3 sec system is turn...
Hi
this error comes when you keep your device powered all the time.
Definition: power is constant to components always on so it heats up.
look for condensers that are popped up or seems to be
change it with same type and voltage
Description of Error Code. F61
State, Condition
When the power is turned on, the unit is automatically
turned off. The power does not turn on.
· Cause, Troubleshooting
Power circuit system failure and/or direct current flown to
speaker terminal
Good Luck
Nov 19, 2017 | Panasonic SC-HT740 System
I have the f61 code on a panasonic surround sound. should both fans spin on power up?
Pretty sure both fans should turn. If the unit senses the fan not turning, it will shut down as you are describing. Try taking the label off of the fan so you can see the bearing, and put a couple drops of oil in there. This sometimes get them to turn freely again.
Dec 28, 2012 | Peerless "Panasonic Sc-Ht990 Home...
Turn on dvd panasonic sc-ht440 the display see me f61
Hi, F61 is and amp error code. probably needs an output ic. could be a shorted speaker or bad cooling fan. Disconnect all speakers and turn it on. if the fans run and it still displays f61 then odds are very good an amp ic is bad.'''Hope it helped.
Have a nice day..
Feb 24, 2011 | Panasonic SC-HT440 System
Fault code fg1
If it's a panasonic the number are f61 and means the audio amplifier's IC's are damaged and need to be replaced
Feb 02, 2010 | Audio Players & Recorders
Home cinema panasonic sc-bt100 error code f61 what does it mean
I have same F61 issue, purchased a new fan fitted it today, and I have the same error code??
Dec 13, 2009 | Panasonic Audio Players & Recorders
F61 error code
Sorry to hear about your error code F61
This code refers to a High Limit Temp. condition.
This is most likely caused by the cooling fan.
If the Fan has stopped running or not running at full speed, you will recv. this error message and the temp. reaches high-end limit.
Please check the cooling fan, any possible air flow restrictions and correct running RPM.
Hope this information has helped you.
Readers, please rate your technicians information.
Thanks,
John Ray
john@johnrraycomputer.com
Jun 30, 2009 | Panasonic SC-HT740 System
NOISEY FAN
You may need a new fan, but you can try cleaning the fan. Remove fan from player. use a few drops of WD-40 or another similar lubricant, the fans label may need to be removed. Note Panasonic fans must be rotating or f61 code will appear. Hope this helps.
Jan 10, 2009 | Panasonic Home Theater System System
Error Message F61
Hi guys,
just had the f61 error code on my home theatre system, now i work with samsung dvds and tv's so the background knowledge is there ( i hope), i dont know if u guys noticed the fans making a noise whenever you switched it on before the fault happened but mine were making a hell of a noise, this prompted me to have a look inside and find 2 fans both of which were very dusty, just a 10 minute clean and a 10 min reassemble and im back up and running on all channels.
hope this helps guys
Aug 08, 2008 | Panasonic Home Theater System System
Panasonic Home Theater System System Logo
2,303 people viewed this question
Top Panasonic Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
