My washer won't drain
My washer will fill and agitate, but will not drain. I dont hear it "click"as before when it switched from the "wash" to "spin" cycle. I opened the lid and put a screw driver into the slot that located on the top side of the washer (that when it makes contact with the lid causes it to run, or stop when the lid is lifted.) That didn't help.I mannually turned the control knob and heard some clicking but still no change. I hope that you have a solution to why my washer wont drain or spin.
  • Anonymous May 14, 2009
    my washer washer but don't spin and drain. Its a Kenmore
I just had the same problem and it was the lid switch. I disconnected it so to bypass the switch and now it works. A friend at work also had the same problem and called sears out and it was a stocking stuck in the drain hose. you can google a fix my washing machine and it will tell you how to repair it yourself. That is what I did with the lid switch.
Posted on Jan 20, 2008
My roper top load washer model rtw4440vq fills with water but wont wash, spin or drain
see this causes and fix it. God bless you
Motor Coupling If the washer won't spin or agitate the motor coupling might have failed. The motor coupling connects the motor to the washer transmission. It is designed to fail if the washer is overloaded in order to protect both the motor and
Drive Belt If the washer won't spin or agitate, check the drive belt. If the belt is broken or if it isn't tight on the pulleys the washer won't spin or agitate properly.
Drive Motor If the washer won't spin or agitate the drive motor might be defective. This is not common. Check all of the other related parts to this symptom before replacing the motor. If the motor is visibly burned out or physically damaged, replace it.
Stator Assembly If the washer won't spin or agitate the stator assembly might be burned out. The stator is essentially one half of a motor, it interacts with the tub by creating a strong electro-magnet. If the stator burns out the washer won't spin or agitate. Check the stator for continuity. This part is often misdiagnosed.
Door or Lid Latch Assembly If the washer won't spin or agitate the lid switch assembly might be defective. This is a very common problem. The lid switch assembly can fail either mechanically or electrically. Test any electrical switches with an Ohm meter for continuity. The switches should have continuity according to their design.
Door Lock Motor and Switch Assembly If the washer won't spin or agitate the door lock assembly should be checked. The door lock can fail either mechanically or electrically. Test any switches on the door lock with an Ohm meter. The switches should have continuity according to their design.
Motor Control Board If the washer won't spin or agitate the motor control board might be defective. The motor control board provides power to the motor as well as direction and force. If the motor control board is defective the washer may not work at all or function properly.
Sep 30, 2012 | Roper Washing Machines
My Kenmore washer 20432990 will fill and agitate but won't drain or spin. When I push down on the lid switch I hear nothing but when I let it go I hear a faint click.
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Jun 15, 2011 | Kenmore Washing Machines
WASHER FILLS WITH WATER, THEN WON'T AGITATE. TURN KNOB TO SPIN AND IT DRAINS THEN SPINS. STILL WON'T AGITATE
WASHER FILLS WITH WATER, THEN WON'T AGITATE. TURN KNOB TO SPIN AND IT DRAINS THEN SPINS. STILL WON'T AGITATE please show me a diagram
Jun 14, 2011 | Whirlpool LSR7333 Top Load Washer
Washer won;t drain or start spinning
check the lid switch if its ok
you have a problem with the timer
replace it
Jul 05, 2009 | Kenmore 24032\24036 Top Load Washer
My Kenmore washer ain't working right.
no definalty not!!! will not drain if the lid switch is bad will however fill and agitate.. you would hear the click as you just about close teh door if indeed the switch was working corrctly
Feb 24, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore washer will not drain
I would check the lid switch first using a pen open the lid set into spin and depress down on the lid sw if you dont hear it click then it is bad
Aug 17, 2008 | Kenmore 24032\24036 Top Load Washer
Washer problems
if it wont drain , check your lid switch, check out your motor coupler, if it will not agitate and spin, replace your motor coupler, if it agitates and dont spin, replace your lid switch.
alot of times the washer will drain but we hurriedly cut it off when we hear noise or the water is out but it never spinned and so the clothes are soapy wet...
Nov 12, 2007 | Roper RAX7244KQ Top Load Washer
Washer clothes
Does the washer fill normally and just stop? Or, does the washer fill, go through a complete cycle, and just won't drain? There could be a couple of problems that cause a no drain issue. 1. FILL NORMALLY & STOPS, WILL NOT SPIN - This is usually a bad lid switch. If you open and close the lid, you should hear a "click", indicating the switch is working. 2. FILL NORMALLY, AGITATES, WILL NOT DRAIN - This could be a clogged drain pump, pinched hose, clogged rain line. Also, you need to make sure timer is advancing properly. If the timer never advances, the washer will fill, but won't go into agitate or spin. Let me know if this is helpful.
Aug 09, 2007 | Whirlpool LSR5132J Top Load Washer
Washing Machines Logo
168 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
