Question about Kitchen Ranges
Fan continues running and door is locked. I tried to use the clean function. I have a two stove stand up Kenmore duel flow stove that slides into a gap in my cabinets. Last night I wanted to use the clean function. The machine asked me about the door. I closed the door and attempted to cancel the cleaning. I have tried to clear the problem using button pushes and disconnecting the power.
  • 11,896 Answers
Disconnect power source for 8 hours, Press and hold cancel or bake/start button of any kind for 5 seconds, wait half hour more and plug back in and see if it resets then. If not, the control board will have to be replaced. One can be purchased at repairclinic.com or partselect.com
Posted on Dec 12, 2009
Kenmore electric range model 790 door lock light flashing
Hi, When door locks, This is when oven is in self clean mode. After the heat has cooled down the door should release again. If this does not work try turning the power off to the stove (breaker) This should reset the stove to normal. Call a repair man if this continues. Good luck.
Jun 01, 2015 | Kenmore Kitchen Ranges
After cleaning the outside surfaces of the stove, the oven door is locked and does not unlock if we push the stop button. Display reads LOC. No self cleaning cycle was initiated. The stove is a Kenmore...
What about child lock? Read user manual or try holding button for 10 seconds, might be two at once.
(I bought a $200 control board and travelled 150 kilometers for that one....)
Oct 15, 2013 | Kenmore 49043 Electric Single Oven
I have a Kenmore model 790.95592 30" free standing range with self-cleaning function that I think has an eletronic function problem. The oven burner elements start on its own and fluctuates to danger
Dear Ernie,
I am very glad you asked. As a retired firefighter, and an electrician, I can say you were just about to have a fire.
The most likely problem is a "meltdown".
Something has melted, and is causing a direct short circuit.
Lightning or power surges can do this.
Please turn off the circuit breaker, and unplug, or disconnect the wires to the back of the stove.
Start by looking where the wires go into the back of the stove.
See if there is visible burning or smoke or blackness.
You might be able to fix this, buy re-wiring the stove, but if the controls are melted, you may be needing a replacement stove.
An electric meter will be really helpful to find the problem, but with the way you have described this, you may be able to see or smell the burned part.
God bless your efforts.
Jul 10, 2017 | Kenmore Kitchen Ranges
Kenmore elite stove duel fuel lock
please see the next steps and proceed with common sense: God bless you
Door Latch/ Motor
The door latch may be stuck in a latched position or misaligned in this case just readjust the latch. In the case of a self cleaning oven that got stuck the motor or switch that controls the latch has failed. You will need to acess the motor. On some this is on the back, remove the back panel and you will see the small motor with a actuator rod attached to this. The first thing to try is to plug the oven in and with a rubber handle screwdriver push the microswitch tab down to activate the switch. If this does not get it working unplug and check switches for continuity. Check the motor for continuity. If you seee any burn marks on the motor or wiring replace the motor.
Main Control
First try to reset the control by unplugging or shutting off the breaker for 5 minutes. If this does not clear it check the motor and switches listed above. If all above is good the control has failed and will need to be replaced.
Jul 27, 2012 | Kenmore 46123 Stainless Steel Electric...
How do you use the self-cleaning ??? i lost my manual within minutes of getting....
we have a sears kenmore model and this is how we do it. remove everything from stove including the racks, close oven door, slide door lock latch to the right till it locks the door. turn knob to clean. when it is done cleaning it will turn off by itself. on some models the door latch will not slide open when done. just wait for it to cool if this is the case. it should tell on the touch pad on stove the hours that it takes to clean it. good-day !
Jan 20, 2012 | Whirlpool 30" Self-Cleaning Freestanding...
When cleaning the stove i touched my accident the
F90 Maximum oven door unlock time exceeded.
F91 Maximum oven door unlock attempts exceeded.
F92 Maximum oven door open time exceeded.
F93 Maximum oven door lock time exceeded.
F94 Maximum oven door lock attempts exceeded.
1. (F90, 91, 92, 93 & 94) Check the wiring between EOC & Lock Motor Micro Switch.
2. (F90, 91, 92, 93 & 94) Replace the Motor Door Latch assembly if necessary.
3. (F90, 91, 92, 93 & 94) Check for binding of the Latch Cam, Lock Motor Rod & Lock Motor Cam.
4. (F90, 91, 92, 93 & 94) Check to see if Lock Motor Coil is open. If open, replace Lock Motor Assembly.
5. (F90, 91, 92, 93 & 94) Lock Motor continuously runs - if Micro Switch is open, replace Lock Motor Assembly.
6. (F92, 93 & 94) Check oven door Light Switch - if open, replace Switch.
7. If all situations above do not solve problem, replace EOC.
F90 is a door lock code, Try this...
unplug the range.
wait 1 minute.
turn the range back on,
then while holding in on the oven door.
start another self clean.
wait 2 minutes.
then cancel the self clean.
do not release the door until the door lock light goes out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Nov 25, 2009 | Frigidaire 30" Self-Cleaning Slide-In Gas...
Stove has locked down /frozen
turn off the circut breaker for the stove. I JUST had to do this myself.
Jan 23, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
Oven, broiler don't work
The main control board is what you need to replace here.Please Rate This !
Jul 06, 2008 | Kenmore Kitchen Ranges
Self cleaning oven
It may have sliders inside the oven door .Open the door and look at each side for metal slide plates that when pulled upward they seal off the glass for self cleaning. If you dont have those ,I just wasted alot of typing.
Jun 07, 2008 | Kenmore Kitchen Ranges
Amana stove stuck in 'lock' mode, door won't open
try hitting cancel is it displaying any error codes like e2 f3 try turning the breaker for five seconds then back on
Dec 28, 2007 | Whirlpool RF378 Electric Kitchen Range
Kitchen Ranges Logo
53 people viewed this question
Top Kitchen Ranges Experts
Oloyede Monsuru
Marvin
Marvin
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
