Question about Toys
How hard is it to replace the water pump on a 250 HPDI
    Problem Solver:
  • 17 Answers
Very easy, take lower unit off and pump will be right there, when you buy the pump it will have some basic instructions that will help, order a service manual also, they are nice to have around
Posted on Dec 13, 2009
SOURCE:
2003 Yamaha outboard HPDI will start but will not
Many possibilities. Mine had been sitting. Old fuel in HP fuel pump reservoir was clogging HP pump. I was able to disassemble, soak and clear pump and get running. New pumps, big money. My boat, twin 150 HP HPDI
Sep 23, 2014 | Boating
2010 yamaha 200 hpdi
Have you replaced all three filters under the cowling?
1. Primary Filter (1st one in the Plastic Bowl)
Reference # 12 in "Prim Fuel" Image
2. Screen on the bottom of the Fuel pump-Inside the VST
Reference # 27 in "VST" image
3. Filter between the VST and the HPDI Pump
Reference # 19 in "VST" Image
Number 2 and 3 get overlooked often, and they are pricy, but they do need to be changed.
If that has been done, the problem most likely is in the fuel pumps
Reference # 24 in the "Prim Fuel" image.
The can be tested by removing them from the powerhead, DO NOT remove the fuel lines, just unbolt them from their mounting leaving the fuel lines attached. Then squeeze the primer bulb until firm. If fuel leaks from the center hole on the fuel pump, Replace them both.
e87e836d-4c03-41b2-984e-2496eb73ed3c.jpg 7cff4158-0f6c-4620-803c-7841ea37bc6a.jpg
Jul 07, 2014 | Boating
2005 Kawasaki KX 250 F how to replace the water pump seals
Hi, Anonymous for this scenario you will need your service manual, parts fiche, and owners manual if you can't find the best tool you ever bought for your Kawasaki, despair not, for a mere zero $0 you can download another one.
For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
Water pump seal replacement
Kawasaki Kx250 Part 6 Replacing the water pump Seal
http://www.mx-sport.ru/files/servicemanual-KX250f-06.pdf
OEM Parts for Kawasaki
2005 Kawasaki KX250F Owner Manual
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
Aug 11, 2012 | 2005 kawasaki KX 250 F
Replacing the timing cover gasket 0n 1988 f-250 with 120,000 miles shoiuld i replace the water pump while i have it out?
while the cover is off with 120k i would replace the timing chain and gears but if the pump is dry and the bearing feels smooth then leave it on
Jun 09, 2012 | Cars & Trucks
Yamaha 2005 150 HPDI wiring diagram
Looking for wiring diagrams for digital tachometer with trim indicators and warning signals. Mine had the plastic trip arm break. No trim reading on Tach face. Replaced trip arm forsensor arm and now have no reading on the tach at all except extremely light tach Number. All other electrical components work OK.
Jan 24, 2012 | Yamaha Motorcycles
Yamaha 200HP, HPDI lifts out of the water when shifting
sounds like something got put together backward . most motors will lift when put in reverse if not locked down . this is to prevent getting swamped by the rush of water going backward .
Mar 13, 2010 | Boating
Beeping sound when starter is turning over for the
Have u replaced the spark plugs? Is this the beeping noise you hear when you first turn your key over the same as past times you have started the motor? It just keeps going though right? I would make sure you have the right level of fluids and make sure your fuel pump works, fuel filter isn't clogged and plugs and wires are in good shape.
If that is all good then you might have a bad coil pack. Test it and make sure you are getting correct voltages, if not then replace it.
Also did you winterize your motor after the last time you used it? If not you could of cause some internal damage to the motor.
Good Luck,
Subikid90
Mar 04, 2010 | Boating
Toys Logo
74 people viewed this question
Top Toys Experts
Marvin
Marvin
Andrew Taylor
Andrew Taylor
ray gallant
ray gallant
Are you a Toy Expert? Answer questions, earn points and help others
