Question about Panasonic PT-43LC14 43" Rear Projection HDTV
PT43LC14 Bulb Replacement
My red light stayed on but the TV would not come on. Manual suggested to replace the lamp. Bought the lamp and now trying to install lamp, but appears to complicated. Is there a good source for dismantling the TV so you can install the lamp, such as a service manual?
  • 4 more comments
  • Anonymous Jan 27, 2008
    It is complicated to get the lamp housing out to replace the lamp.
    anybody knows how to do it?
  • Kenny E Jan 27, 2008
    It is complicated to get the lamp housing out and replace the lamp.
    anybody has replaced the lamp on this model?
  • okewillie Mar 02, 2008
    The basic thing is to know where to look for the housing which is in the bottom left hand portion of the base of the TV. We took the entire real panel off before finding it in the front.
    A long screw driver particularly with a magnetic tip is necessary, but its is simple. I suggest to get a diagram from any dealer if you want to fix it yourself.
  • WeeKnow Apr 10, 2008
    I received a message on my tv that said the lamp is about the expire and it needs to be replaced and the timer needs to be reset. I replaced the lamp. Now the white light on the power button on te front of the tv is on. It blinks twice every five seconds. The fan is running, but the tv screen won't come on. I can't reset the timer until the tv screen light up. 'Any ideas?
  • Anonymous Apr 25, 2008
    the red light was still on and would turn green when I pressed it, but the screen won't come on. how do you know which bulb to get if in fact it needs replacing?
  • cbajar569 Sep 27, 2008
    i just replace for tv but when i turn it on the green light comes on for like 2 seconds thren the yellow light start blinking.what is this suppose to mean?di i put the bulbs wrong or there is another problem with the tv?i need advice pls.thanks..
Long screwdriver? maybe if you consider about 3" being long (explains why wifes upset). I have replaced the bulb only and the housing with bulb several times with this pos tv. The housing and bulb is one philips screw behind the front snap off panel (the big front piece that has the hdtv stamp in bottom right corner, just pull out it has push in plastic stubs) then remove the philips screw next to the big white warning label where there is a small half circle cutout around it in the label. then one screw on the big black piece of plastic with a fold down metal handle. Then just pull strait out, little snug but as long as you loosen the screw it should slide right out. to replace just slide in whole housing replacement and tighten the 2 screws back up. As for just replacing the bulb, I buy mine off ebay and they have all come with real ez instructions. I believe there is 2 screws holding the clip for the 2 wires coming off the housing, just take that out as the new one comes with wires. you just screw on the 2 wires to new bulb tighten down the wire clip and put it back together. The housing can be just pried open with a flat head screwdriver (think there was a couple tack welds) then after new bulbs in just bend back in as much as you can, it will clear in the tv and be fine so it doesnt need to be exact. Hope this helps and if anyone wants another one of these tv's you can have mine!
stripclubgm
Posted on Oct 24, 2008
Huge thanks to whoever said the unit is replaced in the front, not the back. Ignore the instructions that come with the full replacement lamp unit. Just pull the front panel off and it takes 30 seconds to swap out!
Posted on Jun 29, 2008
Question about this model? I need to replace the bulb do I need to replace the housing. There are 2 seperate costs for bulbs out there. One cost for bulb alone and one cost for bulb and housing... Sugggestions?
Mark
drbabbitt@verizon.net
Posted on Sep 29, 2008
How to replace blub in aa pt-43-lc14
Posted on Jun 03, 2008
Seems it all went fine for me. Just make sure you have a nice LONG phillips head screwdriver. Only problem I'm having is the bulb timer won't reset. Pictures working fine though
Posted on Mar 01, 2008
  • 397 Answers
Yes there is a service manual, but it is not complicated all you have to do is reverse order, you have to attempt this so you will be able to fix this yourself, dont think it is complicated, just go for it, it is easier than you think
Posted on Jan 20, 2008
The lamp light is blinking once every 5 seconds. The manual says that " Lamp will not light or light is abnormal"
HI,
Panasonic PT50LC13 lamp indicator blinks to tell you the lamp is faulty.
You need to replace the bulb or TY-LA1000 lamp assembly. This link displays all Panasonic TV Lamps and TV Bulbs. This page shows Panasonic lamp location and How to Replace TYLA1000 bulb. TY-LA1000 Bulb Replacement requires the use of a long Philips Screwdriver to reach screws within the lamp cage.
Unplug AC power before removing the lamp and re-install all doors, etc, correctly before starting the TV. Vacuum any visible dust or lint from air vents and lamp area. Do not used forced air to blow out dust, big problems may result.
The user's manual has a description of what the Blinking LED indicators mean.
Image of TYLA1000 lamp.
Robert
Apr 14, 2011 | Panasonic PT-50LC13 50" Rear Projection...
I have a pt43lc14 unit and the power light comes on but i do not have a picture. the temp light flashes 2 times every 5 seconds. can you please tell me what the problem is?
The "LAMP" LED light indication flashes or stay on too?Yes,than the tv projection lamp on the tv life are over.Tv require a replacement of new projection lamp.
Nov 23, 2010 | Panasonic PT-43LC14 43" Rear Projection...
I've replaced the bulb in my tv and the red lamp light is staying on with no picture or sound. What can i do to get my picture back?
Did you put back lamp cover after lamp replacement?
Make sure lamp cover has been fixed in its place securely after lamp replacement.
Aug 17, 2010 | Mitsubishi WD-52525 52" Rear Projection...
Tv is getting power (flashing green light says so) pix never comes up and now the lamp light is flashing red. HELP the set is not very old. what should I do?
Need to replace lamp in TV as lamp seems dead/ broken and will be replaced.
Lamp replacement procedure is written in user manual and it is very easy.
Thanks.
Sep 28, 2009 | Sony KDF-E60A20 60 in. LCD HDTV
Samsung 50" DLP - Lamp Light Blinking after bulb replacement
Listen closely. The tv should make a high pitch whine as it turns on. If it does wait and see if it tries this a few times. If yes then check the bulb, I have seen cases where the lamp shoves the power connector back into the set. If the tv starts with a grown or heavy vibration noise, then your color wheel may have broken and needs replaced.
Jul 11, 2009 | Samsung HL-P5063W 50" Rear Projection HDTV
Panasonic PT43LC14, blinking green light on the power button
Depends on how much tv you watch, lamps burn out after anywhere from 5,000 up to 8,000 hours also you xould have a bad fan if fan does not work lamp will not come on.
Dec 03, 2008 | Panasonic PT-43LC14 43" Rear Projection...
XL-2100U lamp cycles on and off
Hi
I recently had a similar problem after replacing my lamp the set would work for 22 mins then go into standby for 30 sec then come back on, then repeats, I decided to experiment with the lamp housing, I removed the new lamp, unscrewed the top of the lamp that holds the actual bulb then switched out the main housing (bottom part) with the original housing, that seemingly has corrected my problem, you may want to try if the replacement lamp did not come from Sony...good luck
Sep 10, 2008 | Sony LAMP BLOCK XL2100U Projector Lamp
Best but repleace bulb but red light still on
So far I have entered the service menu (both menus together) then selected Lamp Replace (option 14) and then pres ok to reset. Version and Lamp (option 11) now reads Lamp life (Khr) = 8 and Lamp use (Hr) = 0.
Jan 19, 2008 | LG RU-44SZ51D 44" Rear Projection...
Mitsubishi WD-52327 52 in. Rear Projection DLP
I have a 2 year old Mitsubishi Rear Projection 52" model WD-52525. I recently experienced the same problem as you. My TV quit without any warning and the red lamp light came on. I bought a replacement lamp just like you did, did everything you did too, but it still didn't work either. Since it's past the 1 yr warranty (of course), I took it in to an authorized service center for an estimate. They determined the light engine failed and it will cost me $816.35 to repair. I already shelled out $240+ for a lamp, $48 for the repair estimate and I said "hell" no, I'm not going to fix it for another $800+ and bought a new TV. I'm writing a letter to Mitsubishi expressing my deep dissatisfaction (to put it mildly) with this faulty product and will be requesting reimbursement, which I probably won't get. I sincerely hope this is not the same problem your TV has, but if it is be prepared for a costly fix.
Aug 06, 2007 | Mitsubishi WD-52327 52" Rear Projection...
Panasonic PT-43LC14 43" Rear Projection HDTV Logo
2,092 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
