Question about Tomtom GO 510 GPS Receiver
Battery replacement for TomTom 710
How do you replace the battery on the TomTom 710?
  • Anonymous Mar 11, 2008
    my tomtom 710 battery will not charge up and now it will not switch on I have tried to charge it several times in different cars and also at my home through electricity but it wont charge.
    Brian Kiely
  • bechaso Apr 21, 2009
    I have a tomtom 710. the battery was dead so I bough a new one I charged and it was fine again but after 2 or 3 hours was dead I tough something wrong with the new battery but is not.
    any help plesae.
    thanks
I have found a trick for those bad battery ,but you lose your waranty
you need to open your tomtom , behind the screen you wil find the battery(for the Go 710 it is an 3.7 V ,2400mAh,samsung ICR18650-24)
you find 3 wires : red, black,yellow cut them of at the half of the wire size
, then cut off your car loader wire (tomtom)(5v), you will see again 3 wires inside :red,black,white
connect the red with red, black with black, white with yellow
(the best thing is to make a little hole in the cover to pass the wire, so it will be beter for closing the all thing)
I did it and it works pretty fine ,I had save 30 dollars ;) :D
I did in approximatly 30 min
remember you will have no battery any more and no waranty of tomtom!
It only whorks then with your car loader tomtom
Posted on May 29, 2008
  • Jeff Luo Nov 09, 2010
    The yellow or white one does not matter. What you need to do is to connect the back and white wires from the power supply (from either the car charger itself, or find the corresponding wiring from the TomTom winshield mount base) directly to the white and black battery connector wires inside the GSP device. Make sure you remove the battery itself to avoid overcharging it. I did this to my own and it worked fine.
  • Paul
    Paul Jul 09, 2016
    So what happens to the RED wire ????
  • 4 Answers
Here is a video that demonstrates how to replace the battery:
The company that produced the video sells a kit which includes the battery and tools necessary to do this yourself if you'd like. See: http://www.newpower99.com/ProductDetails.asp?ProductCode=TOMTOM+GO+510&Show=ExtInfo I swapped the battery of a friend's dying GPS using the aforementioned kit and all went well. His Go 510 is back up and running smoothly.
Hope this Helps, Tim
Posted on Aug 14, 2010
  • fieldingfixa Mar 18, 2011
    Brilliant thanks - wouldn't couldn't have done it without the video - all sorted and working again
My GO710 looks to have a dead (faulty) battery when it hasn't been used for a while ( I also have a GO720 now). I have found if I leave it on charge for a long period, say 1 day, then disconnect/reconnect the power a few times it comes back to life and can be charged as normal. I have done this about three times over the past 18 months, it comes good each time.
Posted on Dec 18, 2009
    Problem Solver:
  • 3 Answers
You need to remove the front facia plate, then the four T6 screws from the rear. The main body of the tomtom will then come out (with a little help!) You then need to remove the screen (small screwdriver) and the two electronic boards (T6 screws) the battery will be visible right in the center of the unit. You unplug the connection and then the battery just un clips. It is quite an easy process though make sure its deff. the batt 1st!! I replaced mine and it didn't change anythin, still wouldn't charge correctly came on for short bursts and then the low batt light would come on again. I then found out it was the pins on the main connection that were at fault and they can't be changed!! TYPICAL!!!!!
Posted on Jun 18, 2009
I bought a brand new battery of of ebay. Installed it and my GO710 fired right up. After about 2 hours it was dead. The problem was the charging circuit which is part of the motherboard and not the battery. I decided to try bypassing the battery which apparently also bypasses the charging circuit. Works like a champ now as long as it's plugged in.
Posted on Jul 19, 2008
My TomTom Go 710 was not switching on but the green light would come on when charging. I replaced the battery and it worked fine....for a couple of hours. It then went back to previous state. I then followed the procedure to bypass the battery and it has worked a treat.
Just to say, I passed the cable to the connector on the unit through the same hole as the speaker cable but i had to enlarge the hole using a small file. I made a hole in the casing to allow the cable to come out from behind the speaker.
It is a fairly straightforward job when you have the tools ( T6 bit, small file, wire cutter, soldering iron (to connect the cables), drill to make hole in casing) and should take 30 minutes.
    Problem Solver:
  • 7 Answers
I had a Tomtom 710 with the battery problem as above, i 'hardwired' the car charger, and tadar it works a treat, i drill a hole in the side casing inline with the end of the battery, through both plastic and Ally housing, threaded the hardwire through both bits, soldered to the battery wires and refit in reverse.
Posted on Sep 04, 2009
You can buy the battery and replace yourself
Posted on Feb 15, 2008
    President:
  • 4,402 Answers
You cant you have to send it in.
Posted on Jan 25, 2008
    Problem Solver:
  • 12 Answers
Here is a battery with tools and installation instruction solution at NewPower99.com
http://www.newpower99.com/Battery_for_TomTom_Go_710_p/tomtom%20go%20710.htm
Posted on Nov 21, 2010
4 Suggested Answers
SOURCE: tomtom 710 broken
Pin idea close but bad, due to pointyness.
use a paperclip to press the RESET button.
this won't junk the gel button you are trying to press.
soft reset, push & you feel a 'click' action of button - press & release
hard reset, push (feel 'click' action) and hold for 20 secs or so
Also, remove card can trigger a soft reset.
Possible battery shot or board defective...
Posted on Jul 31, 2008
  • 121 Answers
SOURCE: changing the battery tomtom go 710
wow go to the nearest tomtom store
Posted on May 03, 2009
  • 9 Answers
SOURCE: my tomtom go 710 4v00 will not switch on
Fix it yourself, you need either a new battery and or motherboard. Relativly easy to do! 10 small torx screws for motherboard and 2 ribbons, then a few more screws and loosen the harddrive and screen for battery
Battey and motherboard for less than £50 pounds off ebay
Posted on Aug 22, 2009
Tomtom 710 will not turn on . I can't find a reset, is there one if so where
If battery gas been completely flat, you will need to hold the power button for a few seconds
Oct 03, 2010 | Tomtom GO 700 GPS Receiver
My tomtom go 710 4v00 will not switch on
Aug 09, 2009 | Tomtom GO 700 GPS Receiver
Hi, Tom Tom 710 has not come on for weeks.
it doesnt get better by itself. Despite having a green light doesnt mean it is charged. try changing the battery
Jul 05, 2009 | Tomtom GO 700 GPS Receiver
How do I replace an Olympus Stylus 710 Battery Door?
Please visit this site and order a new batterydoor for your Olympus camera www.lutoncameras.co.uk
regards Rob NL
Apr 15, 2009 | Olympus Stylus 710 Digital Camera
Changing the battery tomtom go 710
Apr 10, 2009 | Tomtom GO 720 GPS Receiver
Tom Tom Go 710 - Won't turn on
not sure but try an other device on the car plug to see if it works??????????? could be the plug.
Dec 17, 2008 | Tomtom GO 700 GPS Receiver
Tomtom 710 broken
What seems to be the nature of the problem?
Feb 01, 2008 | Tomtom GO 700 GPS Receiver
Will not take a charge
I have just the same problem. Initially the battery was flashing to say that it was low on charge even when it was plugged in, then it flashed that the battery was empty and switched itself off. When plugged in the green light comes on, but still cannot turn TomTom 710 on. Also it will not connect to the computer.
Nov 14, 2007 | Tomtom GO 510 GPS Receiver
GPS Logo
8,132 people viewed this question
Top Tomtom GPS Experts
LP
k24674
Marvin
Marvin
Are you a Tomtom GPS Expert? Answer questions, earn points and help others
