Question about Dell Microsoft Windows XP Home Edition
Lost admin password for PC. I don't have a Dell Op Sys. disk but have access to Gateway XP Op. Sys disk. Will that work if I re install windows XP on the Dell ? thank-you
  • philipnflori Dec 14, 2009
    Solution one is one of the best I found on the web , TY but .... no luck ! the disc I have is recognized on other PC's but not this on, I can even find the disc drive under My Computer,it's show new hardware found but as Floppy drive on start-up. Unable to install it because of NOT having admin rights tho ! What a mess!!!
    I'll be trying solution 2 shortly , I'll keep you all posted and TY for offering your time and info.
    Solution 3 will be a Dell Tech for 90 dollars which I'm trying to avoid!! My own stupid fault for letting it happen tho, what can ya do ? TY
  • philipnflori Dec 16, 2009
    Solution #2 Did the trick, TYVM ..... I'm amazed how ez things went , brought the PC back to new.
    I did loose all files but kept what was needed.
    I don't need to try the other suggestions but I thank you all for the help, greatly appreciated !
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 22 Answers
HAVE YOU TRIED PC RESTOE...ALL DELL COMPUTERS WHICH WERE SHIPPED AFTER 2004 HAS THIS FEATURE,ALL YOU NEED TO DO IS RESTART THE COMPURTER AND ON DELL LOGO PRESS AND HOLD DOWN CTRL KEY AND TAP F11 KEY MANY TIMES....U WILL GET THE OPTION FOR PC RESTORE..THEN RESTORE THE COMPUTER TO THE FACTORY SETTINGS..ur computer will became brand new as you bought it on day 1 ,all info would be lost....but it will only take 10mins hardly...try this njoy
Posted on Dec 14, 2009
    Scholar:
  • 27 Answers
Windows Password Buster is reliable Windows password recovery software which allows you to recover lost Windows administrator password and user password on all popular Windows OS like Win 7/Vista/XP/Server 2008/2003. By burning a bootable CD/DVD or USB flash drive with it, you can easily recover your Windows password. Following are the steps to recover Windows 7 password.
Step 1: Download and install Windows Password Buster Standard in any available computer. Step 2: Burn a bootable CD/DVD or USB flash drive with this Windows password recovery software Step 3: Set your locked computer to boot from CD ROM or USB. Step 4: Remove Windows 7 password with the burned CD/DVD or USB flash drive. Step 5: Log on your computer without password and reset your Windows 7 administrator password.
Posted on Nov 05, 2011
    Guru:
  • 243 Answers
You can remove your password with windows password recovery tool. I know a tool named "windows login recovery" that can recover windows administrator password without losing any data and you needn't reinstall windows OS. Download it from http://www.windowsloginrecovery.com and burn the program to a blank CD or a usb flash drive, insert the CD into the problem computer and reset your password to “Blank”.
Posted on Feb 24, 2010
  • 57 Answers
You can use the windows password recovery tool "Any Windows Password Recovery 3.0 " to help reset windows password to blank,it need not to reformat and reinstall windows OS,then with no data losing.Its easily.
Posted on Jan 18, 2010
    Sniper:
  • 50 Answers
Please go through the below steps for changing the password of administrator if forget------
The next technique makes use of a loophole in the Windows XP repair process you’ll need a bootable XP CD
Place your Windows XP CD in your CD-ROM and start your computer (You need your XP CD is bootable as it should be - and that you have your bios set to boot from CD)
Keep your eye on the screen messages for booting to your cd Typically, it will be Press any key to boot from cd
Once you get in, the first screen will indicate that Setup is inspecting your system and loading files.
When you get to the Welcome to Setup screen, press ENTER to Setup Windows now
The Licensing Agreement comes next - Press F8 to accept it.
The next screen is the Setup screen which gives you the option to do a Repair.
It should read something like If one of the following Windows XP installations is damaged, Setup can try to repair it
Use the up and down arrow keys to select your XP installation (if you only have one, it should already be selected) and press R to begin the Repair process.
Let the Repair run. Setup will now check your disks and then start copying files which can take several minutes.
Shortly after the Copying Files stage, you will be required to reboot. (this will happen automatically you will see a progress bar stating Your computer will reboot in 15 seconds
During the reboot, do not make the mistake of pressing any key to boot from the CD again! Setup will resume automatically with the standard billboard screens and you will notice Installing Windows is highlighted.
Keep your eye on the lower left hand side of the screen and when you see the Installing Devices progress bar, press SHIFT + F10. This is the security hole! A command console will now open up giving you the potential for wide access to your system.
At the prompt, type NUSRMGR.CPL and press Enter. Voila! You have just gained graphical access to your User Accounts in the Control Panel.
Now simply pick the account you need to change and remove or change your password as you prefer. If you want to log on without having to enter your new password, you can type control userpasswords2 at the prompt and choose to log on without being asked for password. After you ve made your changes close the windows, exit the command box and continue on with the Repair (have your Product key handy).
Once the Repair is done, you will be able to log on with your new password (or without a password if you chose not to use one or if you chose not to be asked for a password). Your programs and personalized settings should remain intact.
I tested the above on Windows XP Pro with and without SP1 and also used this method in a real situation where someone could not remember their password and it worked like a charm to fix the problem.
And in case you are wondering, NO, you cannot cancel install after making the changes and expect to logon with your new password. Cancelling will just result in Setup resuming at bootup and your changes will be lost.
Regard,
Abhay Singh
Posted on Dec 12, 2009
Forgot admin password cannot how to reset admin password gateway lt2104u
Look on Ebay for a password reset disk. Many vendors on Ebay sell a bootable "linux" disk that you boot from and then you can edit your password file on Windows. I have versions for XP/ Vista.Windows 7.
Be sure to get one that works for your version of windows. You must set the BIOS to boot from the CD drive first for this to work. About $5 to $10 for the reset disk.
Regards,
Dennis
Apr 18, 2014 | Gateway LT2104u Netbook
Tip
How to Reset Password on Latitude?
We have usually had no idea on problems, such as: help reset password on Dell Latitude laptop , Dell Latitude admin password hack, bios password reset Dell Latitude, how do I reset my dell Latitude notebook back to the factory, etc. Once problem comes with password, we will hopefully get easy and quickly solutions supported for us! Now, we collect some ways to reset Dell Latitude password if forgot password again.
1. With created Dell Latitude password reset disk to recover lost Windows XP, 7, etc. password.
Though it maybe the most efficient way to help us in case we meet such password problem, most of us may not make sense of the importance of the disk for us PC users. The disk needs to be created before we forgot Dell Latitude password or once we set the account. If you did not have one, now look for Dell Password Reset Disk.
2. Unlock Dell Latitude password in Safe Mode (in XP)
Step 1. Press F8 when Latitude laptop starts. Select "Safe Mode with Command Prompt" and Enter.
Step 2. At the login screen with computer user accounts, choose an available account to login. Please note that the Administrator account (default/built-in) password is blank if never set password for it before.
Step 3. In Safe Mode, Dos command displays. Input "net user" and press Enter to list all the user names in Windows XP computer. Then input "net user Linda 123456" (Linda is the locked account name and 123456 is the new password set on this account) and press Enter. Then we will see "The command completed successfully."
Step 4. Input "shutdown -r" and press Enter to restart the system, then we can access "Linda" account in normal logon mode.
3. Easy to recover lost Dell Latitude Windows password by DIY a password reset disk.
DIY password reset disk is just to say, burn an .iso image file into a bootable CD/DVD/USB Flash Drive for the lost account after forgotten Windows password. The .iso file can be mainly got from professional password recovery software. Take one of the most popular software - Windows Password Recovery Corporation as example:
Step 1. Download Windows Password Recovery Corporation and burn .iso file to a bootable CD/DVD/USB via an accessible PC.
Step 2. Boot the target computer from CD/DVD/USB.
Step 3. Retrieve lost Dell Latitude password with the burned CD/DVD/USB.
In case we forget our Dell Latitude password or need to remove or break password on Dell Latitude, the above three methods may make sure that we get out of Latitude password reset problem easily and quickly!
Source: http://windowspasswordrecovery.net/article/dell-latitude-password-reset.html
on May 25, 2011 | Computers & Internet
Tip
How to Reset Gateway Password?
How to reset Gateway laptop password? I forgot my PC password Gateway Windows 7, I want to unlock laptop password urgently! Can you help me recover my lost power on password for Gateway? Now, we together share some ways to remove Gateway admin password.
Optional 1: DIY a CD/DVD/USB password reset disk instantly to recover lost Gateway password
The method is the most effective solution to get out of Windows password problem. It just needs burn an .iso image file to one of these media. Now, take one of most popular Windows Password Recovery tool as example:
A. Download Windows Password Recovery and burn its .iso file into a blank CD/DVD or USB Flash Drive on an accessible PC;
B. Boot the burned CD/DVD or USB Flash Drive from the PC lost password;
C. Reset a new Gateway password.
Whatever for Gateway Windows 7, Vista, XP, Server 2000, Server 2008, etc. the above Ainorsoft Windows Password Recovery has its different versions to suit for these OS.
Optional 2: Gateway password recovery disk helps remove lost laptop password
It is the most convenient way to retrieve Gateway PC password and while, is maybe suitable for little part of computer users. The Gateway recovery disks should be created once our Windows account is created. Also, one account password responds to one password reset disk. Take Gateway Windows 7 as example:
A. Insert a CD/DVD/USB Flash Drive into the driver.
B. Click Start - Control Panel - User Accounts and Family Safety - User Accounts.
C. On the left pane, select "Create a password reset disk" - "Forgotten Password Wizard".
D. Click "Next" and follow the Wizard to create password reset disk.
Now, the Gateway Windows 7 password recovery disk is created. When we need break Gateway Win 7 laptop or notebook password on the login screen and input an incorrect password, click "Reset Windows Password" and insert the password reset disk. The Password Reset Wizard will help you create a new password to override lost Gateway password.
Optional 3: Reset Gateway password by accounts with administrative privileges
Accounts with administrative rights or the default and built-in account can help us to remove Gateway password. Take Gateway Windows XP as example, there is a default Administrator account. We can use it to unlock locked account if this built-in account is still blank or accessible.
A. Press Ctrl+Alt+Del twice when PC starts and then input "Administrator" in the username field and leave the password filed blank at the classic login screen. Press Enter and login PC.
B. Start -> Control Panel -> Administrative Tools -> Computer Management -> Local Users and Groups -> folder Users
C. Right click the account user name which password was lost, and then click Set Password -> Reset password -> keep New Password and Confirm Password blank.
D. Right-click locked account and select Reset password.
E. After finished, restart PC and login.
Optional 4: Ophcrack Windows Password Recovery software
Ophcrack is a free Windows password recovery tool which only works for passwords with less than 14 individual characteristics.
A. Download the Ophcrack LiveCD and burn its .iso file to a CD on an accessible PC.
B. Insert the CD into the locked computer and restart it.
C. When computer starts, we have to press the correct key to enter the boot menu.
D. After select the drive that the CD is in at start menu, do as the following instructions.
If we forgot Gateway laptop password and need Gateway password reset, we can easily reset Windows 7, XP, Vista password on Gateway PC or netbook with the above 4 optional methods.
Source: http://windowspasswordrecovery.net/article/gateway-password-reset.html
on May 06, 2011 | Computers & Internet
How to do if locked out of Windows 8 laptop?
1. Run "lusrmgr.msc" to reset Dell Windows password.
In Windows 8/7/Vista/XP, there is an easy way to reset a forgotten user account password by just run the lusrmgr.msc. But you need to login your server or laptop with an account which has admin privileges. Note that resetting password with this tip might cause irreversible loss of information for the user account. This data loss will occur the next time the user logs off. You should use this command only if a user has forgotten his or her password and does not have a password reset disk.
Step 1. Start your PC and log on with an available user account which has admin privileges.
Step 2. Click "start" button, press "Win+R" to open "Run box". Type in "lusrmgr.msc" and hit Enter.
Step 3. Local Users and Computers appears, all user accounts of your computer will be list, right-click your user name and select "reset password".
Step 4. Type in a new password and type it again to confirm it, click OK.
After restarting you can login that user account with new password.
2. Remove Dell password by using a Windows password recovery tool.
This is a universal way to reset forgotten Windows password on HP Server or PC, no matter what your Windows system is, Windows 8/7/vista/XP. iSunshare Windows Password Genius is designed to recover Windows password for any kinds of PC, such as hp, dell, acer, Toshiba, Lenovo, IBM etc. It not only can help reset server or laptop password Windows 8, but also Windows 7, Vista, XP and Windows 2000.
Step 1: Download and install Windows Password Genius Advanced on another computer you have access to.
Step 2: Run the software to create a Windows password recovery disk with CD/DVD or USB drive.
Step 3: Insert the Windows password recovery disk to your PC or Server and set the laptop to boot from the disk by changing devices boot order in BIOS SETUP.
Step 4: After boot from the password recovery disk, Windows password recovery tool will start automatically and display a friendly window. Then you can reset whichever account password of your PC or Server by a few clicks.
Windows Password Genius also allows user to create new admin account for your Dell Windows system without logging. With this new user, you can login your Dell computer directly and access control panel to reset other user password.
Jul 29, 2013 | Computers & Internet
Windows password lost
When forgot Windows password, you can follow these ways to reset Windows password. You can firstly check your password hints left when created password or use password reset disk created before forgetting the password. Besides, using password reset tools such as Windows Login Recovery, Ophcrack, LCP, etc. 3fd69b51-01ae-4778-8353-a121b193d6fd.jpg
Oct 26, 2012 | Dell Inspiron 4150 Notebook
Lost my acer mini aspire one laptop
Lost Acer admin password? Don't worry about it, you can reset lost acer admin password with Smartkey Windows Password Recovery Professional by the following steps,
Step1: Download Windows Password Recovery Professional from http://www.recoverlostpassword.com/products/windowspasswordrecovery.html.
Step2: Install and launch it to any accessible computer.
Step3: Use a blank and writable CD/DVD/USB to burn Windows password reset disk with the tool.
Step4: Boot the locked computer from CD/DVD/USB.
Step5: Start to reset acer administrator password with the burned disk.
Step6: Reboot computer and login to the locked PC without password.
Jul 09, 2012 | Acer Aspire One Netbook 8.9" Notebook
Forgot password on dell laptop with windows 7?
emm, forgot Windows 7 password?
There are some methods for you to reset it, just follow the info and have a try
Option 1: Use a password reset disk to reset lost password if you have created one before forgtting the password.
requirement: USB flash drive or floppy
time: a few minutes
Note: This password reset disk can be only created when you can log on with the lost windows password.
Option 2: use a freeware to crack lost windows admin password, then you can get back the password, like Ophcrack
requirement: download Ophcrack live cd,
time: more than i hour
Option 3; a high efficient and easy-to-use low affordable shareware, like Windows Password Recovery Tool, which can reset windows 7 password quickly and successfully.
Requirement: a bootable CD/DVD or USB flash drive.
Time: within a few minutes.
Visit http://www.windowspasswordsrecovery.com
Step 1: Download and install Windows Password Recovery Tool in any available computer.
Step 2: Burn a bootable CD/DVD to remove lost Windows password. (or USB Flash drive)
Step 3: BIOS settings
Step 4: Recover forgotten Windows password with the burned CD/DVD (or USB Flash drive)
good luck ~
Dec 02, 2011 | Dell Inspiron N5030 Notebook PC
I have a dell inspiron 6400 laptop and dont have the administrator password. please help. my service tag no. is 3LR6Y2J-595B
To get your administrator password reset, you can make use of some practical and powerful tools like Windows Password Killer. It's the most effficient and the safeset way93e3c8eb-02f8-4544-b24f-5126c7e225d7.jpg.
Jan 17, 2011 | Dell Inspiron 6400 Notebook
How to unlock a dell windows XP home adition laptop when turning on laptop?
Do not worry, we can use dell password recovery tool to complete this task. Windows Password Rescuer is designed for resetting dell Windows 7/vista/XP password. What you should do is prepare a bootable CD/DVD or USB drive and a computer you have access to. Follow four steps help you reset dell windows password without lose anything:
Note: You also can use Windows Password Rescuer to reset Windows 2008/2003/2000 local or domain password easily by these steps on dell computer.
Step 1: Download and install Windows Password Rescuer on another computer you have access to.
Step 2: Run the software to create a Windows password recovery disk. You just need to burn it to a blank CD/DVD or USB drive.
Step 3: Insert the Windows password recovery disk to your dell laptop or dell computer, and set the computer boot from the password recovery disk by BIOS setting. If you have trouble in BIOS setting, refer to:
How to set computer boot from CD/DVD.
How to set computer boot from USB drive.
Step 4: After boot from the password recovery disk, Windows Password Rescuer will start up and display a friendly operating window. Then you can reset whichever account password of your dell computer just by a few clicks.
You also can use Windows Password Rescuer to create a new user with administrator privileges for your dell OEM Windows without login. With this new user, you can login your dell computer directly and access control panel to reset other user password.
Jul 11, 2010 | Dell Microsoft Windows XP Home Edition
Computers & Internet Logo
257 people viewed this question
Alun Cox
