Question about Dell 3100MP Multimedia Projector
I can't get the power to turn on in the 3100MP projector (DELL). I plug it in and it is not even powering up. No fan, no power, no light. Is there a fuse or do I need to change the bulb? Do you know what might cause this problem?
  • 11,896 Answers
Either the fuse burnt out, or the power supply/voltage transformer is bad. You can test it with a voltmeter very carefully not to hurt yourself to see if there is power going to main motherboard.
Posted on Dec 12, 2009
SOURCE:
Power supply fuse
HI,
Do you need to know the rating of fuse used in the power supply. Or do you mean that Power supply is not working.
Jan 04, 2013 | Dell 3100MP Multimedia Projector
Dell 1209S Projector, tries to turn on, and the fan comes on for 30 seconds and then goes off again. It tries this several times and then the light bulb icon comes off and it doesn't do antything else
Lamp is burned out or makes a popping sound.
When the lamp reaches its end of life, it may burn out and may make a loud popping sound.
If this occurs, the projector does not turn back on. To replace the lamp, see on page 38.
LAMP light is solid amber If the LAMP light is solid amber, replace the lamp.
LAMP light is blinking amber If the LAMP light and the Power light are blinking amber, the lamp driver has failed and the projector will automatically shut down.
If the LAMP light is blinking amber and Power light is solid blue, the color wheel has
Unplug the power cord after 3minutes then turn the display on again. If this problem
persists, contact Dell™.
TEMP light is solid amber The projector has overheated. The display automatically shuts down. Turn the display on again after the projector cools down. If the problem persists, contact Dell™.
TEMP light is blinking amber A projector fan has failed and the projector will automatically shut down. If the problem persists, contact Dell™.
Oct 23, 2011 | Dell 1209S DLP Projector
Dell 3100MP just powers off
check the heating of your laptop. it more heat chek your fan or cfu fan, if work properly.. shuting down is a lot of cause. over heating, fan not work properly case over heating... processor.. or board..
Jun 19, 2009 | Dell 3100MP Multimedia Projector
No Sound
check the setting of sound.. if its okay check the speaker wire connector or the chips.. but be care full for opening if you can open and fix no problem..
or look qualified technician for projector
Feb 03, 2009 | Dell 3100MP Multimedia Projector
I have a second- hand dell 3100MP projector which I use during church services to project songs and other material. Recently it has been showing a predominalty green image , particularly when showing...
sir
the lamp is not at problem, but the dlp engine is at fault, u may have to replace it.since u bought it 2nd hand,it is not worth changing the same as it will cost u more than ur buying price.when u plan to buy ur next projector, make sure u buy a new one as it will come with a fresh lamp & manufaturers warranty on the unit & at 4000 / 5000 hours of projector usage is guaranteed!
Jan 05, 2009 | Dell 3100MP Multimedia Projector
Dell 3100MP Projector - No Signal Check Cable
Make sure you have the right input source selected. It may be looking for a signal from some input other than the one you're connected to. Beyond that, if it truly isn't seeing the input then you'll need to have the projector serviced.
Dec 17, 2008 | Dell 3100MP Multimedia Projector
Dell 2300mp projector
check this out...
http://www.ihatedell.net/forum/phpBB2/viewtopic,p,36316.html
have almost the same problem. lamp light turned on-->replaced the bulb, now when you turn it on tryies to boot and then the lamp light is on again (but the bulb is brand new).... and no light at all coming out of thing... I guess dell just don't know how to built projectors right way.... and theirs tech support guys are.... they just don't know about projectors more then manual
Jun 20, 2008 | Dell 2300MP Multimedia Projector
Projector
A couple of things...
If the fan is not working, the lamp will not fire. If you have the owner's manual, it should indicate what the flashing lights mean. Check to make sure that the panels are seated properly. When you replaced the lamp, the outer cover was removed. If that is not seated back 100%, the unit will not work. There are a number of safety "checks" built into the unit to prevent damage and possibly fire as the lamps get really hot.
Check the items above and let us know your progress.
Dan
Jun 19, 2008 | Dell 2300MP Multimedia Projector
Dell 2300MO NOT STARTING UP Problem
Try the remote control.  You may have a problem with the contact switch in the power button.
Oct 02, 2007 | Dell 2300MP Multimedia Projector
Dell 3100MP Multimedia Projector Logo
257 people viewed this question
Top Dell Office Equipment & Supplies Experts
David Patricia James
Marvin
Marvin
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
