Question about Nikon COOLPIX L3 Digital Camera
I dropped my NIKON COOLPIX L10!!
I dropped my NIKON COOLPIX L10 and the lens are stuck and they won't go back in! How can i fix it?
  • 797 Answers
Sometimes to push the extended lens (with battery out) gently to the opposite side it is bending...may help. If it snaps back into the channel, fine, other wise you may not be able to do anything, and consider it a loss. That is because the cost to repair is too much. What you can do if the lens is broken is to sell the camera on Ebay as a broken or as is, or repair item. That way you may get some good money (up to $40.00) for this camera. There are those looking for parts cameras on Ebay.
Posted on Mar 18, 2008
I fixed mine by gently pulling out on the lens and then gently pressing it back in. It was just jammed a bit. Good luck.
Posted on Mar 12, 2008
  • 3 Answers
The camera is very probably beyond economical repair (check your house hold insurance for accidental cover though) and I'd advise you to give it a good yank. You will find it sometimes clicks back into place. If its not covered under any insurance you have little to loose.
Posted on Jan 24, 2008
6ya staff
SOURCE:
What replaces pictureproject with the coolpix L10 ? will nikon view NX2 work for coolpix L10 ?
Picture Project was replaced by Nikon Transfer and Nikon ViewNX2. Both of those programs will work perfectly well with the L10. You can download the current versions of all (free) Nikon software from
http://support.nikontech.com/app/answers/detail/a_id/61
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use Nikon Transfer or any other photo cataloging program.
Once the pictures are on your computer, you can use View NX2 to look at them and do some editing.
Jul 22, 2011 | Nikon COOLPIX L10 Digital Camera
Hi I have a Nikon coolpix L10. Took 2 photos, turned it off. Wont start up and red light stays on, any ideas
There is a capacitor dump that you can try.
Remove the batteries, wait 5-10 minutes.
With the batteries out, press and hold the power button for 10 seconds or so.
Put the batteries back in and your camera will start over (re-boot). You will know if it worked if you have to reset the date. But if that lens is really stuck you may be out of luck. The cost to repair it will exceed the cost of a new camera.
Sep 19, 2010 | Nikon COOLPIX L10 Digital Camera
How can i fix broken lens on nikon l10 coolpix
You can obviously try to pull the lens and twist it, I'm assuming you did that, it fixes the issue in 20% of the cases but usually the mechanism is permanently damaged and needs replacement. There is a third party company in new york that carries a parts for small point& shoot digital cameras, : Camera Repair NYC
Aug 11, 2009 | Nikon COOLPIX L10 Digital Camera
Nikon Coolpix L10 Lens Stuck
My 4 year old child step on it and now the lents is stuck
Jul 26, 2009 | Nikon COOLPIX L10 Digital Camera
Lens error on nikon coolpix s210
This is probably THE most common failure among digital cameras. There's a halfway chance of fixing it yourself, described here: http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Jun 15, 2009 | Nikon COOLPIX L10 Digital Camera
Lens stuck/lens error
Hello
there are tiny plastic gears inside and may have chipped or a small piece of sand got in causing the lens to jamb. "very fragile"
one solution is to ask a camera repair shop how much a lens mechanism would be to replace. (if cost is more than 1/2 of what you paid dont bother)
another solution is to have someone sell your camera on an auction site for parts, to make some money towards another camera purchase
Aug 19, 2008 | Nikon COOLPIX L10 Digital Camera
Camera
Anything you would try to do yourself would void your warranty. I suggest taking the camera back and see if they won't give you a replacement.
Usually, zoom errors occur when the lens is extended and gets bumped or dropped. Liquid and or sand can also cause these problems
Jan 02, 2008 | Nikon COOLPIX L10 Digital Camera
Dropped camera and now lens will not move
This worked for my camera, Nikon Coolpix L10!! I'm so happy I didn't go out and buy another camera!!!
Remove the batteries, then remove the memory card. Then install the new batteries, when you turn it on it should come back to life. Error E30 means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Kathy
Dec 10, 2007 | Nikon COOLPIX L3 Digital Camera
Nikon COOLPIX L3 Digital Camera Logo
78 people viewed this question
Top Nikon Cameras Experts
Ric Donato
Ekse
pictureman4u
Are you a Nikon Camera Expert? Answer questions, earn points and help others
