Question about Fujitsu Siemens SCALEO C772 17" CRT Monitor
I have a Scaleoview T17-2 monitor. The picture
I have a Scaleoview T17-2 monitor. The picture frequently goes ''scrambled''. If the monitor is tilted back and forward the normal picture restores, but goes scrambled at frequent periods. Have just put a new lead on it to connect to PC, so the lead doesn't seem to be the fault. Seems to be something in the monitor itself. Any suggestions to sort out?
Scrambled picture on my Asus vw266h
This seems to be a recurring problem with this model. If you came across this page by searching for 'asus monitor scrambled picture' then you too must be suffering from this issue. Fortunately there are several youtube videos on how to disassemble the monitor and install a new board which can be purchased on ebay for around $23 from China or $50 from USA. If you are handy with a screwdriver this just might be the money saving solution for you.
Mar 24, 2013 | ASUS VW266H - VW266H 25.5 LCD Monitor -...
Soyo DYLM1988 vertical hold/jittering picture problems when starting up. Clears when warmed up & playing with monitor settings helps.
How old is the screen? if more than 5 years, the circuitry can go bad. I had this with one of mine, it would jitter for about 10 mins before it warmed up. Just get a new one, they are cheap as chips
Sep 27, 2017 | Soyo DYLM1988 Monitor
Westinghouse Flat Screen Goes Blurry/has Scrambled Picture
tried first with re seating the lvds cable in the t-con board, the t-con board is mounted covered with metal shield. if can get with fixing the cable, then your t-con board has defective component parts.
Aug 13, 2012 | Westinghouse Televison & Video
Hi I have a Fujitsu Siemens Scaleoview C19-6 monitor. Recently it started going black randomly while I am using the PC. The green light at the bottom is still on and to get the picture back I must switch...
christelledt, When black screen of death rears it's ugly face, the first thing to do is look at the "date of manufacture" on rear of the unit! If unit has lots of "ON" time (300 days/year x 8 hrs/day x years in service) it may need to be replaced or refurbished. 7 to 10 thousand hours is middle to old age in monitor life. If unit performs in same way when connected to different pc then you will trade-in for new or investigate a DIY refurbishment of the units internal ac to dc switch-mode-power-supply/CCFL inverter printed circuit board. unit may need $5 in capacitors replaced to fix it. Plenty of info and videos on that on the web and here at fixya. 12fixlouie
Aug 18, 2010 | Fujitsu Siemens Computers & Internet
The picture is scramble
I see the pictures, you need new screen, the LCD panel is cracked, sorry for the bad news! The screen will cost more tahn the new monitor.
Jun 07, 2010 | Gateway 24" Widescreen Flat Panel TFT LCD...
FujitsuSiemens TFT goes out after 2 seconds
josexcruz, While you were busy replacing all the electrolytic filter capacitors did you think to closely examine all the other "LEADS" of the surface mount and through-hole components to make sure they ALL look bright and "mirror finished" ??? Try looking for solder joints that have thinner than hair circular thermal fractures around the solderd leads. May need inspection microscope (10x 15x) to see them. Also check the semiconductors package (body) for cracks or swelling due to thermal overstress. Let me know what you find!!! 12fixlouie
Mar 18, 2010 | Computers & Internet
RCA 40 in
Are you using just one box on this set. I suspect a bad set-top box...accordianman
Jan 08, 2008 | RCA Scenium D40W20 40" Rear Projection...
When you say scrambled, What or how is scrambled?
Sep 02, 2006 | Toshiba 53H71 53 in. Rear Projection...
Fujitsu Siemens SCALEO C772 17" CRT Monitor Logo
179 people viewed this question
Top Fujitsu Computers & Internet Experts
Alun Cox
Computer Links
Are you a Fujitsu Computer and Internet Expert? Answer questions, earn points and help others
