Question about Garden
Where is the drain plug for a Tecumseh 5.0hp Snow King? Is it in the rear or underneath?
jrod1125420
  • 161 Answers
SOURCE: Leaking carburetor
replace to gaskets on the bowl and usually theres a screw/or spring release on the bottom of the bowl....replace those gaskets as well
Posted on Feb 27, 2009
  • 10865 Answers
SOURCE: My Tecumseh Snow King 8HP
In order to start it with an electric cord you must have a feature called an electric starter. If you dont have the electric starter on your machine now, one can be added at a dealership
Posted on Mar 29, 2009
wireguy212
  • 1627 Answers
SOURCE: where is the drain plug on a tecumseh 5.5 HP engine?
The plug is in the base of the engine so if there is a shroud in the way unfortunately you need to remove it.
Posted on Dec 16, 2009
  • 430 Answers
SOURCE: I have a tecumseh 7 horse (Snow King) motor that
That does not sound like a complete Tecumseh model number.
You have several options... Your first and probably best option would be your local small engine repair shop. They may even have the parts in stock, if not in stock will likely have it in a few days. Or you can look online at places like outdoordistributors.
No matter where you get the part from you will need a complete model and spec and maybe a serial number ( off of the motor itself). Also be aware that since Tecumseh went out of business a few years ago that certain parts are becoming increasingly hard to find.
Posted on Jan 02, 2010
  • 134 Answers
SOURCE: Where is the oil drain plug located on the 2000
Forward, front left side of oil pan.
Posted on Nov 01, 2010
Our snow blower with a Tecumseh model OHSK120 snow king engine starts but runs full throttle!! Any ideas?
Stuck or bent governor, governor linkage or throttle. Try moving the throttle and see if all the linkages move with it.
Jan 25, 2017 | Tecumseh Garden
Tecuseth Snow King Engine. Starts fine. When I engage snow blower engine dies.
couple of things come to mind. Safety switch. Engine not running at full speed or snow thrower is locked smooth up
Dec 17, 2013 | Tecumseh 5hp Engine Snow King Mtd Blowers...
The engine runs for alittle while then it quits
clamp off fuel line or drain tank ,there is a brass nut on bottom of carb.(holds on fuel bowl) the brass nut is also the jet for the carb.unscrew nut and check for dirt or foregin material plugging pick-up holes on side off nut body,also make sure center hole is opened (small straight pin size hole) be sure to wipe clean inside bowl before reassembly.
Dec 25, 2010 | Tecumseh 5hp Engine Snow King Mtd Blowers...
I have a 5hp tecumseh motor HS50-67324K on a craftman snow blower,could you please tell me the high and low RPM speed settings on this unit.
Here is a 70 page Tecumseh service guide. Locate the type of carburetor you have in the guide. All instructions with diagrams are available. This is a PDF file. Adobe Reader will be needed to view it.
http://www.smallenginesuppliers.com/html/engine-specs/tecumseh/Tecumseh_quick_reference.pdf
Dec 14, 2010 | Tecumseh 5hp Engine Snow King Mtd Blowers...
SNOW BLOWER/SEARS 247.887001-NEW CARBURETOR, DON'T START, GETTING GAS...
Have you checked for spark? You have drained the old fuel completely, and added brand new fuel,Right?
Is the spark plug getting wet or is it soaked?
Let me know, we'll get it started.
Dec 10, 2010 | Tecumseh 5hp Engine Snow King Mtd Blowers...
Tecumseh Snow King HS40 engine only runs on full choke, no power
i did and thanks - just picked up one that does the same thing and i plan to take your advise
Thank you Jerr
Jan 01, 2009 | Karcher 2500 PSI Pressure Washer
Garden Logo
51 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
