Question about Maytag Neptune MDE5500AY Electric Dryer
I need to know what size vent tubing i need for an maytag neptune dryer
  • Maytag Master
  • 8,404 Answers
I believe 3 inch vent will fit this. Use a metal or aluminized vent if at all possible.
Posted on Dec 12, 2009
SOURCE:
Where can I locate the vent tube for maytag mde9700ayw neptune dryer
the vent tube is on the back bottom of the dryer
Jul 15, 2011 | Dryers
The senser for Moisture only reads less go's through shuts down in about 5 min.
may have a clogged vent or dirty sensor, first disconnect vent tube run dry, if it works normal then clean vent tube, if not clean sensor which is located underneath lint trap. Good Luck Tim
Mar 06, 2011 | Maytag Neptune MDE5500AY Electric Dryer
Dum turns to fast for cloths to tumble, 2 hrs. to dry!!
don't know about the drum turning to fast, but the two hours to dry I do know. Disconnect the vent tube and dry a load of clothes, as there is a restriction in your vent tube. You will need to clean the tube out with a vacuum or leaf blower, you may want to clean the inside of the dryer out,also. Good Luck Tim
Jan 06, 2011 | Maytag Neptune MDG9700A Gas Dryer
I have a neptune dryer I bought from a used appliance store about 6 months ago. The cycle comes on but there is no hot air. Clothes are not dry after 3 full cycles. I am not even sure if its gas. Don't...
you will need to get behind the dryer and disconnect the vent tube, try drying a load of clothes with the vent tube disconnected if it drys then the tube is the problem and needs to be cleaned out. If it is not drying at all then it is a few things, I am assuming its electric here is a website that will help:
http://www.partselect.com/dryer+dryer-wont-heat+repair.htm
Nov 29, 2010 | Maytag Neptune MDE5500AY Electric Dryer
Electric Maytag Neptune Dryer not heating up.
If the dryer won't heat up, the problem is typically either a blown thermal fuse or a faulty heating element. The thermal fuse is located just inside the back of the dryer on or near the exhaust duct. It is about one inch long. The thermal fuse and heating element can be tested using an ohm meter or multimeter. These components should have continuity. If either does not, that component is faulty. There is no telling if the moving around of the machine caused the problem or if the timing of the problem was coincidental. Sure hope this helps ya and best wishes.
Jul 21, 2009 | Maytag Neptune MDE4000 Electric Dryer
Maytag Neptune sensor and time drying settings
Fixed the problem, not the machine, needed a new dryer vent. Just unhooked the vent and
the dryer worked perfectly. V
Feb 08, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Dryer doioesn,t dry in a 90 minute cyclr
you need to clean out the back vent hole on the dryer and the wall vent,you are keeping the moist hot air in the dryer that needs to be vented out so the dryers not drying like it should,let me know how you do-mike
Nov 12, 2008 | Maytag Neptune MDE5500AY Electric Dryer
Maytag Neptune MDE5500AY Electric Dryer Logo
55 people viewed this question
Top Maytag Dryers Experts
Marvin
Marvin
Sal De
Archie Ferrarini
Archie Ferrarini
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
